Topic: foobar available command line switches (Read 2431 times) previous topic - next topic
Hi.
I would like to know about all foobar command line switches to control the palyer from an external skin/interface.
I´ve made a search around including google but still hasn´t found any info.
Can someone help me with this?
Is tthere any way to get the track playing info trought the command line switches?
Thank you!
Just try foobar2000.exe /help on the command line.
Thank you Ganymed!
That´s exactly what i wanted
Althought i´m a little unsure how to get the playing tracK info from it.
Can you give me a hand on this?
Thank you!
Best regards
This is not possible via the command line.
But you can use foo_text for example, to write info about the track you're currently listening to to a file.
Best regards,
~ Florian
Thanks again Ganymed!
Yea that´s the way to go.
Best regards,
mikegraphik
