Topic: LAME versions (Read 37294 times) previous topic - next topic
LAME versions
Reply #52
First impressions...
The quality on the alpha 12 it's improved again,i've done a 96 kbps encoding,sounds more clear than alpha 11  No bitrate/speed tests yet
Edit: Bug,i guess...
with --alt-preset 112
the log reports
Encoding as 44.1 kHz average 111 kbps j-stereo MPEG-1 Layer III (12.6x) qval=5
111?
Edit n.2
There's a quality problem
Encoded with APS,but also with --alt-preset 96,112,128,160...even with 320,still problems with cbr @96kbps,112,128,160....less @224,no more problems @256 and above
http://djlux.altervista.org/base_a12.mp3
No problems with 3.97 Alpha 5
http://djlux.altervista.org/base_397.mp3
LAME versions
Reply #53
Is the Lame 4.0 alpha sourcecode available?
LAME versions
Reply #54
[a href="index.php?act=findpost&pid=265448"][{POST_SNAPBACK}][/a]
Yes, from the CVS. You'll need to check out by tag/branch - "takehiro-2002_05_07-experimental" (without the quotes).
LAME versions
Reply #56
Not sure if anyone is interested in this sort of bug with Lame4 at this stage but I'll post it here anyway. When I tryed to encode from Lame4 (both alpha 11 and 12) from the foobar2000 CLI diskwriter plugin then it failed to encode properly. Some files seemed to be encoded ok but others were zero bytes? The same files however all ecoded 100% fine when lame4 was rubn from a command line.
Any ideas?
