Topic: FLAC frontend 1.6 released (Read 3602 times) previous topic - next topic
I've just uploaded FLAC frontend 1.6. It now supports tagging of FLAC files through Tag.exe. Link: http://home.wanadoo.nl/~w.speek/flac.htm
BTW1: Are FLAC tags the same as Ogg comments?
BTW2: Is someone working on a FLAC Winamp plugin that can show the tags?
Nice
More or less. I decided to use name "FLAC tag" instead of "Vorbis comments" to avoid some confusion with tag handling, and also because Ogg and FLAC don't use them identically (for example vorbis libraries can't read comments from FLAC stream).
Apparently: http://www.hydrogenaudio.org/forums/showth...29126#post29126.
I can't find plugin sources... I was going to do some copy/pasting and include simple tagging support.
They're in CVS with everything else, under flac/src/plugin_*
If you're just browsing you can start with CVSweb here
Otherwise you can check out from CVS directly, instructions here
Josh
Well, I got the sources but my intentions were too optimistic. I can't even compile it, nmake complains about missing win32.mak and custom created project in MSVC doesn't want to work either.
Yeah, I'll try to get .dsp files for everything in 1.0.4.  The Winamp3 plugin has one though.
Josh
