Topic: Why the foobar2000.exe session doesn't end itself? (Read 3406 times) previous topic - next topic
it is annoying,
Every time I close the foobar window, it stays in my system, I have to end up with close the session in task management, or I cannot run it again.
Version: 0.8.3
In case you have foo_tunes installed please read this.
Quit using foo_tunes. Search in the forums. If it's anything else, give us details.
Life is Real...
(But not in audio :) )
[a href="index.php?act=findpost&pid=254612"][{POST_SNAPBACK}][/a]
After i delete foo_tune.dll from component directory, foobar2000.exe still stays in my system after I close foobar2000 window.
So, I don't think it is the reason.
Will samurize cause foobar2000 cannot end itself?
Solved.
I completely uninstalled it and reinstalled it. everything's ok.
Solved.
[a href="index.php?act=findpost&pid=254653"][{POST_SNAPBACK}][/a]
BUT. Samurize of showing the status of foobar does not work.. I reinstalled samurize again. Guess what happened? foobar2000.exe crashed again after close the main window.
What about trying a newer version of the Samurize plugin?
