Release 2.2.beta2
New Features
* reimplemented @fakelevel
* If the title formatting for a folder node uses non-playlist tag, it will try to find them in the first entry in the node. eliminates the need for a $first or @first function
* turn off window redrawing when doing a user requested refresh
* on playback skip files with meta tag SKIP (will not make it to the final release)
* turn off redrawing while a node is expanded. Less window flashing
* when removing a file from a auto refresh @queue query, remove it from the queue as well
* when removing a file from a auto refresh @playlist query, remove it from the playlist as well
* automatically store to a file in the foobar2000 directory
o This overrides previous settings, but you can re-load your previously saved file and it will handle the storage and retrieval on its own after that.
* multiple panels can swap contents from the context menu
* if you are changing the configuration in columns ui, some of the panel contents can get mixed up. if you remove a panel and a different panel seems to be affected, you can right click on the remaining panel and select which contents it has, including the contents of panels that have been removed.
Bug Fixes
* fixed bug in dropping multiple files onto auto refreshed @playlist/@queue query
* don't write the contents of @queue query, because queue is not saved between instances
If you install the new version and you had previously been using a save/restore file, its NOT going to load it automatically now... But manually load it using File/Open... and it should now manage the storage and retrieval of content on its own after that... it will save files in foobar2000 profile directory and the files are called playlist-tree-[n].pts, where n will be the panel instance.
You can swap panel contents around from the context menu now, by right clicking somewhere in the panel that is not on any node. This is also useful if things get mucked up by changing around columns ui layout...
