Topic: Foo_uie_albumart (Read 1111395 times) previous topic - next topic
Foo_uie_albumart
Reply #650
A bug:
With some images, broader than high, the thumbnail is truncated.
The component is broader than high too.
Component size: +- 230*175
Examples of badly posted images: 640*568, 800*703, 1082*982
Foo_uie_albumart
Reply #651
I have MSVCP71.dll installed and the configuration options appear in preferences and I have a folder.jpg file but I see no panel
Edit:
Nevermind! "Needs both MSVCP71.dll and MSVCR71.dll"
I was too tired
Edit 2:
Hmm, still doenst want to work
[a href="index.php?act=findpost&pid=310713"][{POST_SNAPBACK}][/a]
Where have you put the DLLs?
Foo_uie_albumart
Reply #652
The File seems to be down  Please upload it again
Foo_uie_albumart
Reply #653
Edit:
I was too tired
Edit 2:
[a href="index.php?act=findpost&pid=311005"][{POST_SNAPBACK}][/a]
They are in the windows/system32 folder.
Does it require Collumns UI to work?
Foo_uie_albumart
Reply #654
[a href="index.php?act=findpost&pid=311597"][{POST_SNAPBACK}][/a]
Yes, Columns UI is required, the latest version for 0.8.3, which I believe is Columns UI 0.1.2.
Foo_uie_albumart
Reply #655
Error 404 - page does not exist
Sorry, the page /storage/foo_uie_albumart.zip does not exist at www.egosphere.webplanethost.com
Is the file somewhere else?
EDIT:  [a href="http://foobar.nub4life.net/columns/pafiledb.php?action=file&id=76]http://foobar.nub4life.net/columns/pafiled...tion=file&id=76[/url]
There's a link to another source in post #648
Foo_uie_albumart
Reply #656
How do I config albumart to show one specific picture when there is no cover present?
And how do I make albumart to chose the picture containing the word front firstly?
Foo_uie_albumart
Reply #658
[span style='font-size:21pt;line-height:100%']SOLVED![/span]
http://www.hydrogenaudio.org/forums/index....c=29383&st=420#
^ explanation of how the source list works.
[a href="index.php?act=findpost&pid=313390"][{POST_SNAPBACK}][/a]
Thanks, but it didn't help me very much.
I just want a code that makes albumart show the first image containing the word "front" within the directory of the song that is currently being played.
Can someone help me?
Foo_uie_albumart
Reply #659
so can i get this to read the album art from the mp3 file?
edit: i didn't know this was such a difficult question.
Foo_uie_albumart
Reply #660
Hello,
I have just read the explanation given here, but it seems that I am missing something....
My sources definition is quite simple:
If I'm correct, 2 sources are defined. But the "next source" function does not change the source displayed...
(of course I can check it works with my current album, playing with precedence to display "front.jpg" or "back.jpg" => the sources are correct).
Thanks !
Foo_uie_albumart
Reply #661
Request: could you make your plugin display cover art embedded in mp3 files? Most of my files are organized in albums with a folder.jpg in their directory, but I also have a lot of loose tracks together in one folder, where the normal solution won't work. I use the Album Cover Art Downloader to download cover images, and I believe the source is also on the site, so that may help you find out how the cover art is stored in the files.
[a href="index.php?act=findpost&pid=306638"][{POST_SNAPBACK}][/a]
i agree. why is it so hard for anyone to do this?
Foo_uie_albumart
Reply #662
Is there any way to make album_art read a image file that as the same name of a compressed file?
eg:
d:\Music\Linkin park - Reanimation.rar
d:\Music\Linkin Park - Reanimation [Front].jpg
Foo_uie_albumart
Reply #663
How can I tell Albumart to ignore a folder?  I have one folder thats just a big pile of mp3s and other files, unorganized, and every time I play a file from that folder, it takes about 10 seconds before albumart gives up.
I want album art to NOT search for any art when a song is in a particular folder.
Foo_uie_albumart
Reply #664
[a href="index.php?act=findpost&pid=317245"][{POST_SNAPBACK}][/a]
I think it might be easier to have it display a "default" image if the song is in the folder:
$if($strcmp(%_directoryname%,'Folder Name'),'default.jpg','none')
Foo_uie_albumart
Reply #665
I've got a suggestion for a feature. Easy to implement (as far as I can judge), but I think it'd be nice.
What I have in mind is the possibility to display on the albumart panel the following image (the alphabetically next one in the album folder), e.g. with a simple click.
This feature is already used in Irfanview (where pressing space displays the alphabetically following image).
That would allow us to browse from within foobar through the different images in the album folder - e.g. a scanned booklet.
But even as the albumart panel is today, it's a great thing, and I'd like to thank the author for what he has accomplished.
Foo_uie_albumart
Reply #666
files dont seem to be up anymore. where else can i get them?
Foo_uie_albumart
Reply #667
I second that, links are down. If anyone can send it to me, i might be able to host it for awhile.
Foo_uie_albumart
Reply #669
Having some problems with this
It usually loads up fine and shows the relevant image for the current album on startup, and I can switch between the relevant image options for that album, but it never switches when I change album. It's like it always sees the current directory as being the directory of the album selected at startup.
It also gives error messages along the lines of "windows cannot find the file cover.jpg" occasionally when I click to refresh, but I'm not sure of the pattern behind it.
Win98SE, foobar 0.8.3, columns 0.1.2, albumart 0.045
And I have the 3 relevant dlls
Foo_uie_albumart
Reply #670
[a href="index.php?act=findpost&pid=319522"][{POST_SNAPBACK}][/a]
I've been getting this exact same behavior since .041.  (I posted about it way up somewhere in this thread)  I did get .044 working for some time, but I have no idea how, and when I upgraded to .045 this started happening again. (and then installing .044 again didn't help...)  I'm guessing it's something to do with win98, since that's what I'm using too.
stripe/ben
Foo_uie_albumart
Reply #671
Great plug, had to read through all the post (or was it only the 5 first page? ;])
but got it to work finally.
edit:
i think u should consider to add to your first post the fact that u need the newest version of Columns UI for this plug to work, saw it later but would have been nice to know that ahead :wink:
thx again for this great plug
Foo_uie_albumart
Reply #672
I wonder if someone could help me on this.
This is my search order:
If my frontinlay.jpg does not exist, i expect it to show backinlay.jpg when i left-click on it. (I assigned "Next Source" to left-click).
However, i have to click twice before backinlay.jpg shows up. This is even annoying if i only have front and back cover, i have to click 3 times before the back cover shows up!!
Is this something do with the albumart extension, or my config?
Anyway, here's my config..
$replace(%_path%,%_filename_ext%,)'frontcover.jpg'
$replace(%_path%,%_filename_ext%,)'frontinlay.jpg'
$replace(%_path%,%_filename_ext%,)'backinlay.jpg'
$replace(%_path%,%_filename_ext%,)'backcover.jpg'
Foo_uie_albumart
Reply #673
That's normal. They're different sources so you have to click once for every sourceswitch and that's where you're at right now. But if you lay them out like this instead, it automatically shows you whatever pic it finds of those four:
-$replace(%_path%,%_filename_ext%,)'frontinlay.jpg'
-$replace(%_path%,%_filename_ext%,)'backcover.jpg'
But why do you have backinlay before backcover?
Foo_uie_albumart
Reply #674
My album art crash my pc totaly (After i need restart my pc)
When i resize sidebar
Please help me
