Topic: Garf\'s tuned Ogg Vorbis GT encoder quality (was:The Definite (Read 6617 times) previous topic - next topic
Originally posted by George_007
http://sjeng.sourceforge.net/ftp/vorbis/
Which file with which  switches?
The OggDrop encoders have a graphical interface and should be self-explaining.
OggEnc GT1:
-b 999 activates the tuned 160kbps mode
OggEnc GT2:
-b 128
-b 999    <- EDIT !
-b 350
activate the tuned 128, 160 and 350 kbps modes
respectively.
The 128kbps mode isn't really tuned but contains a workaround for the (IMHO) most audible RC2 problems.
I personally use the GT1 160kbps mode, but the same mode in GT2 should be just as fine. I just haven't tested it as much.
The tuned 350kbps mode should be perfect on any music clip you throw at it, including preecho nasties. If it fails, you still get the no-good-money-back guarantee.
Edit: goofed up the gt2 160kbps commandline
GCP
Actually the last time I tried (which I believe was with the latest encoder currently available) the 350 mode, death2 still wasn't perfect (as in transparent) on pre-echo...
If it'd be of any use, I could go back and try it again.
If you wish, be sure to use the GT2 version. The 'stock'  350kbps mode isn't very good relatively speaking.
If you still hear problems, and I can't, I'll try to catch you on IRC someday (but not soon, too much work) and uptune it so you can give immediate feedback.
GCP
OggEnc GT1:
OggEnc GT2:
-b 128
-b 160
-b 350
respectively.
Hmmm? So there is a difference between the GT1 and GT2 160 modes?
Could you explain this more closely, Garf? I have encoded a damn lot of music with either OGGDrop GT2 in 160 mode or with OGGEnc GT2 -b 999, that's why I'm asking...
CU
Dominic
The modes themselves are identical, but the library where I put in the GT2 modes was RC2 + some fixes, whereas GT1 used a plain RC2.
The net effect is that GT2 files can come in about 5kbps smaller than GT1 files.
I know of no audible quality differences between GT1 160kbps and GT2 160kbps, so you might was well take the extra 5kbps savings.
I had already encoded a lot of CD's with GT1 before I made GT2. So most of my collection is GT1, not GT2. Thats why I said GT1 is better tested
GCP
I'm pretty sure it was with the GT2, the encoder I used to test with was the latest oggdrop I could find in one of your threads about the tuned encoder awhile back.
At any rate, later tonight I'll try to test again just to be sure.  I actually discussed this issue a little bit with ff123 and JohnV already, but I'm not sure if anyone else has tested/noticed this or not.  Admittedly, the problems are very slight (PsyTEL for example isn't perfect on that clip either, though both come out sounding pretty good).
Ok, I'll let you know what I find.
Phew, good, I was slightly worried...
This 160 mode is so cool, I think it beats everything else around for quality/size (OK, maybe not MPC, but then MPC isn't as flexible as Vorbis IMHO) - I love it!
One last question: You said that with OGGEnc GT2 "-b 128, -b 160, -b 350 activate the tuned 128, 160 and 350 kbps modes respectively". So that means I could just as well use -b 160 instead of -b 999 when encoding with OGGEnc GT2?
EDIT:
That takes care of my question then, thanks.
CU
Dominic
just lemme post an offtopic message:D
I love the GT2 160 mode
Blech!
I've encoded the first CD today where I'm not satisfied with the results.
Green Velet - Constant Chaos
Track 2 (Coitus) weighs in at 222kbps (the whole CD bloats my modes terribly) but still has preecho bad enough that I can easily hear it.
Also, track 8 (Technology's out of control) has noise masking issues just before the 5 minutes mark.
I haven't ABX'ed the problems, but the first one is obvious enough that I don't doubt it. I'm not as sure about the second one.
If you have the CD, you might want to check it out.
GCP
Hmm, well I've got one single track that causes trouble so far, but only one.
Ya want a sample, Garf (for testing)?
CU
Dominic
