Topic: Ogg Vorbis optimized for speed (Read 259661 times) previous topic - next topic
Reply #275
Changelog
2006/09/03 Lancer 20060903
Efficiency of the inline assembler cord/code for ICL detailed survey, deleting the slow part
Efficiency of cash control-related cord/code detailed survey, deleting the slow part
Efficiency of memory transfer type cord/code detailed survey and SSE optimization cord/code part revival
Improving the SSE optimization of bark_noise_hybridmp
Knocking down the renewal frequency of the lapse indication of oggenc2.
Regards
Franklin
Reply #276
Awesome... as always !
Reply #277
 trying to use the latest & best Lancer is like joining your Build-of-the-day club...
Reply #279
2006/09/15 Lancer 20060915
Because binary for multithread operation from profile edition usually modification (the profile optimization effect at the time of MT is low in edition,)
Correcting the description mistake of the cord/code for MT of mapping0_forward
Executing loop unrolling with mdct_forward, mdct_backward and mdct_butterfly_generic under multithread operation environment
Reply #280
You ain't kiddin'!
Lancer 2006 09-15 is out.
  uhhh ...
I haven't even yet unzipped the previous version... and now a new build...
*dies*
Not that I despise BlackSword and his (her?) attempts... domo arigato gozaimasu !
Reply #282
No sse build?
Reply #284
2006/10/05 Lancer 20061005:
- Updated ICL to 9.1.030
- Improved MT optimization code for mapping0_forward
- Tweaked compile options
- Suppress some compiling warnings
- Discontinue GCC support
This release is memorial to me as this binary (with -q4) runs faster than 100x on my new machine.
http://nyaochi.sakura.ne.jp/encoder-benchm...t-20061005.html
Many thanks to 637 (Blacksword) for the brilliant achievement!
Reply #285
This is really impressive. I remember the old time (pre-RC3 encoder) when Vorbis was painfully slow: x1,5 max on my Duron 800 - up to 3...4 time slower than musepack (not present in this big benchmark), and same speed than LAME --alt-preset extreme.
Reply #286
Sadly to read but it's more truely as a number of previous versions not worked after GCC correctly.
But under wine oggenc2.exe will work anyway.
Reply #287
Man, that truly sucks. This should be written with GCC intrinsics, not ICC. Anyone tried building it with the linux version of ICC?
Reply #288
My congratulations to you!
Reply #289
2006/10/13 Lancer 20061013
Correcting the problem of the memory management cord/code
Regards
Franklin
Reply #290
Hmm. On my AMD 2400 it is slower (1x-2x) than ver 2005 11 21
Is it ok?
Ogg Vorbis for music and speech [q-2.0 - q6.0]
FLAC for recordings to be edited
Speex for speech
Reply #291
Agreed
Reply #292
New version out (20061103), here's the -babelfished- changelog:
Based cord/code modification to aotuv-b5_20061024
Modifying the SSE optimization of _vp_offset_and_mix, _vp_noise_normalize_sort and _vp_couple
ICL in 9.1.032 version rise
Correcting the description mistake of the optimization cord/code
website
Reply #293
Release 20061110 is out:
2006/11/03 Lancer 20061110
    Correcting the trouble which cannot encode the monaural sound source in multithread operation edition.
    Improving the SSE optimization of _vp_couple.
    Modifying the calculation which disperses the load at the time of the multithread operation of _vp_couple.
    Reducing the cord/code of _vp_offset_and_mix.
Regards
Franklin
Reply #294
I've made a little comparison between standard
OggEnc Win32 aoTuV beta5 2006/11/11
and
oggenc283_sse3mt_lancer20061110
Results are quite impressive:
c:\ogg>oggenc -q2 "thom yorke - harrowdown hill.wav"
Opening with wav module: WAV file reader
Encoding "thom yorke - harrowdown hill.wav" to
         "thom yorke - harrowdown hill.ogg"
at quality 2,00
        [100,0%] [ 0m00s remaining] -
Done encoding file "thom yorke - harrowdown hill.ogg"
        File length:  4m 41,0s
        Elapsed time: 0m 15,0s
        Rate:         18,7956
        Average bitrate: 92,6 kb/s
c:\ogg>oggenc2 -q2 "thom yorke - harrowdown hill.wav"
at quality 2,00
        [100,0%] [ 0m00s remaining] \
        Elapsed time: 0m 2,834s
        Rate:         99,482475
Lancer is 5.5 times faster...
Reply #295
Anyone knows where to get one of these optimized vorbis builds for Linux?. Can this patch be applied to vorbis' source code and then be built? Using which compiler?
Thanks in advance!
Reply #296
Yeah, I wanted to modify the title of this thread but couldn't.
Intel C/C++ compiler. I'm not sure whether if it can be compiled with the linux version of the compiler.
Reply #297
He dropped GCC support a while back, didn't he? Or was it just code that's untested on gcc?
Reply #298
Current Lame versions (3.98) can be compiled in 64bits mode, that is how I am using it most of the time.
Using VC8 as a compiler, it increases encoding speed by about 20% compared to 32bits mode.
Reply #299
While trying to sound as un-redundant as possible, I observed speeds as high as 24.2x (primarily in the range of 16-20x), compared to only 10.0'ish from what I remember last... and while I didn't run actual comparisons of the files using any kind of sophisticated process, I did ABX and compare bitrates/qualities of files using both aotuv-b5 and the latest lancer build and was unable to distinguish between the two.  Beautiful  ... thanks guys!
