Topic: 32bit files (Read 9788 times) previous topic - next topic
32bit files
Can someone suggest me a good software and codec to create 32bit tracks.
32bit files
lossy files doesn't have a specific bit depth.
edit: the decoder decides the output bit depth.
32bit files
Normally audio is encoded in 8/12/16/24/32 oftenly the user chooses the bitdepth
since an 8bit track would sound different than a 32bit track. At least this is what I heard from some samples.
32bit files
Do you mean 32 bit resolution or 32 kilobits per second?
32bit files
Well, was this post really meant for "AAC - general" forum ?
32bit files
[a href="index.php?act=findpost&pid=252024"][{POST_SNAPBACK}][/a]
Since AAC is the high end of professional audio, I thought that it would fit in here, if you feel its out of place, don't bother moving, or delete it.
I meant 32bit resolution.
My apologies
32bit files
I entirely fail to see how your question is related to AAC format. Please learn to read forum descriptions instead of posting a question in a random forum then wondering why noone understands what you mean.
32bit files
why do you want to create 32bit files? there are no a/d converters that really reach 32bit resolution. i just heard that dsps can work better at high resolution / sample rate if you for example want to use equalizers in a recording software like cubase or samplitude...
32bit files
Perhaps 32bit files are better than 24bit ?
32bit files
For editing if you are going to do a lot of operations on them, possibly. For encoding, absolutely not.
32bit files
You officially have no idea what you're talking about. Somebody please delete this thread or move it.
32bit files
What does make you think that ?
32bit files
[a href="index.php?act=findpost&pid=252117"][{POST_SNAPBACK}][/a]
i tell you what: 64bit is even better.
32bit files
Strange guy who means 32kbps...
What does the conversion when recording directly to HDD ? Is it a soundcard's hardware A/D converter or is it the software ? If the latter, isn't it A/D converted to (say) 32bit directly ?
chaotic thread, really
I know that I know nothing. But how can I then know that ?
32bit files
I asked a simple question, just wanted an answer either a yes or a no.
Since I have been playing around with 8-24 bit audio and eventually saw a great difference whilst editing, I just wonderered if it would be a better choice encoding
directly to 32bit.
32bit files
If you use lossy codecs, you don't need to bother with bitdepth at all I think.
I don't know about 32bit capabilities of lossless codecs. Monkey's Audio can't.
Anyway, the quality will never become better during encoding by just increasing bitdepth, it stays the same then.
32bit files
What are you trying to do?
Lossy audiocodecs don't care about input bitdepth. The difference between using a 16bit or 32bit source stream will be inaudible/negligable, since most of the differences will be 'cut away' by the codec's psychoaccoustic model anyway.
32bit files
I want more bits! More more more! Infinity+1 bits of sweet sweet music!
32bit files
On the input side, the highest resolution you will find out there is 24bit, 96kHz. Maybe there are 32bit cards out there, but they will be mega expensive. And as some people have said before, those 24bit ADCs most likely won't give you a real full 24 bits of resolution.
If you want, capture at 24bit, or whatever, then resample to 32bit before messing around with the files. I mean, if it'll give you peace of mind.
On the lossy encoding side, in my experience, LAME will accept 32bit integer samples, and FAAC accepts 32bit floating point. These are both from experiments with Foobar2000 and its Diskwriter module sending data to the command-line versions of LAME and FAAC. I haven't tested any other codecs.
32bit files
[a href="index.php?act=findpost&pid=252269"][{POST_SNAPBACK}][/a]
Thanks LoKi128 thats the kind of answer I've expected.
You know whats the problem with some of you guys that actually you seem to be happy with the results achieved by 24bit audio samples, yes fine but a couple of years ago people where also happy with 16bit audio samples etc. If you think this is a stupid and chaoctic thread, you should be ashamed. 32bit is something uncommon thats why some of you pretend to know alot but in reality nothing.
In not a question of having more bits +1 (lamer) its a question of finding a way to improve and not just stick to what we find optimal.
Imagine this ---> Listen to an 8bit sample
                  NOW Listen to a 24bit sample
Different hey (assuming you have good ears) thats what i'm trying to explain.
Then comes 32bit which certainly has much more capablities to improve sound.
32bit files
I think maybe the point many a few of these guys were trying to make is that going from 24bit to 32bit is even more imperceptable than going from 16bit to 24bit. I know I can't tell the difference, either way. I imagine most people cannot.
32bit files
{sigh} TOS #8 anybody? I'll do the honors...
Around here, you are not allowed to make statements about audio quality without producing some kind of objective proof. You can't say 32 bits is better than 24 bits without showing us through double blind tests that you can tell the difference. Come back when you have.
I highly doubt you will be able to, however, due to the following simple math:
0 dB SPL is the threshold of human hearing, the quietest sound that anybody anywhere in the world has ever been recorded as perceiving. Your personal threshold is probably a bit higher. If you play back a 24 bit file so the peaks are at 144 dB SPL, the smallest details that were recorded will be at that threshold. However, you will not be able to perceive those details, since the blast of sound at 144 dB SPL will render you temporarily deaf within seconds. (For reference, a rock concert is about 100-120 dB SPL)
16 bits, with a dynamic range of 96 dB, is just fine for the final master product. Higher precision is only needed to avoid rounding errors when further processing will be done to the audio, as well as keeping the noise floor managable when mixing several tracks together.
32bit files
As I already explained, few applications can really support 32bit files and decoding them on common soundcards (16/24bit) would be a waste of time. Therfore my intention was to try to explain that this idea of using 32bit is still open in such a manner that only the future can really prove you the right answer.
32bit files
Perhaps a better place to start would be comparing 16-bit with 24-bit at the same sampling rate.  You'd need a soundcard capable of outputting at 24 bits per sample directly and you'd probably want to have a 24-bit recording to start with.  For getting the 16-bit version, you should create two versions, one made by simply truncating the last eight bits off the end of each sample and one dithered to see if that makes a difference.
If you're wondering, I'm not orchestrating a similar test for myself mainly because I don't have any 24-bit equipment to use with the test.
32bit files
I only have some samples 16/24, right now I'm trying to play some files, which seem to play but nothing is heard. Probably something to do with the soundcard.
