Topic: OGG X MP3PRO at 64kbps (Read 4635 times) previous topic - next topic
What's the best format at 64kbps, OGG or MP3Pro in terms of quality?
That's what I thought. MP3Pro is still the champion at mailmusic (64kbps)!
Indeed.
I compared Vorbis and Mp3pro VBR, at -q0 for Vorbis (07.13.02), and quality 10 for CoolEdit2 Codec. Samples (6) were only classical music (chorus, gregorian, early chamber, orchestral...) : not loudy music, and very dynamic one, randomly selected. No critical or representative samples.
At theses settings, bitrate is really similar : 35-55 kb/s only !
Ogg v1 - -q0 = (40 - 53 - 45 - 41 - 32 - 49) => 7,92 MO
mp3pro VBR10 =  (42 - 48 - 43 - 44 - 39 - 46) => 7,90 MO
Sample 5 is a piano solo movement
mp3pro VBR did a « good » job when Vorbis did a bad one. Difference is obvious (but for both codecs, quality is shity, of course) : on every samples, Vorbis annoyance were clearly biggest : bad and artificial noise (like a temporal mosaic), more artifacts, more distorsion. Sound was strangy a bit loudest, and background noise different (I can easily hear this strange but not annoying difference up to -q4 - I don't try -q5 and above)
I can't say anything about metal, jazz, pop : loudy music. But on classical, I'm sure taht mp3VBR is the winner (at least for my taste).
Note that at 75-80 kb/s, Vorbis began to be better on most tracks, and really « explode » Thomson codec at 100 kb/s and above. Vorbis is impressive over 80kb/s - Mp3pro VBR is impressive under 70 kb/s.
Read This:
http://www.infoanarchy.org/story/2002/9/8/23472/23921
http://www.zeropaid.com/news/articles/auto...o/09082002e.php
And This:
http://www.mp3licensing.com/royalty/index.html
OGG wins again, mp3PRO sucks!!!
mp3PRO at 96kbps does not cut frequencies...
... but above 9500Hz mp3PRO does weird things with sound. Above 16-20 Khz (I don`t remember) wav and mp3PRO are totally different (look at any spectrum comparations: mp3PRO 96kbps HQ vs normal WAV).
mp3Pro's spectral band replication (SBR) works reasonably well at low bitrates. Nobody can expect near perfect sound at very low bitrates.. SBR is advantageous at low bitrates because it allows relative quality improvements but at higher bitrates it is a deficiency, when you are aiming for near transparency.
Juha Laaksonheimo
I heard MP3 Pro had a new encoder out a few days ago... and it improves a lot according to some sources......
BTW is the decoder free??
And how does MP3 PRO ( 64 or 96 Kbps ) compare against MP3 @ 128Kbps??
Well these are the mp3pro patent licence fees, so I imagine any potential encoder/decoder would have to cost more:
PC Software Applications
Decoder: US$ 1.25 per unit or US$ 90 000.00 one-time paid-up
Encoder / Codec: US$ 5.00 per unit
Hardware Products
Games: US$ 3 750.00 per title
Electronic Music Distribution / Broadcasting / Streaming: 3.0 % of related revenue
(taken from mp3licensing.com)
Are there any free MP3 Pro Decoder??
nop
Made in Portugal
There's the Thomson Player, and the Winamp input plugin, both here
http://www.thomson-multimedia.com/gb/00/index.htm (click on the "Download mp3pro player/encoder ).
Those are completely free to download and to use. The encoder is limited to up to 64kbps if I remember well. (or maybe it was 56? I am not sure)
Thomson says that MP3pro at 64 compares to mp3 at 96, but that could be unnacurate due to lowpass filters applied at 96kbps
Please reread the test carefully. ff123's test does *NOT* conclude that.
it's right the site says:
Then I performed a Friedman non-parametric analysis. The results are graphed below. Mp3pro wins overall ranking points, but it's not significantly better than oggq0 or ogg64. On the other hand, wma8 and aac are definitely ranked at the bottom
