Topic: foo_uie_tabs (Read 231037 times) previous topic - next topic
foo_uie_tabs
Reply #200
No one knows about making the database search plugin (dbsearch) into a tab???? Please.
foo_uie_tabs
Reply #201
An updated version of the album list panel for Columns UI 0.1.3 is available now:
http://music.morbo.org/beta.php
Any chance of seeing the recent syntax improvements being incorporated into the panel?
Well that's be quickly!!!
foo_uie_tabs
Reply #202
Do you always add the updates to the first page as well?
foo_uie_tabs
Reply #203
The links from the first post should always point to the latest version. Updates have been, um, infrequent of late.
foo_uie_tabs
Reply #204
I found another problem:
I defined a key shortcut:
  F1 (or another) :[main] components/Columns UI/Enabled sidebar
Before using foo_uie_tabs, the key shortcut works very well.
When Tabs is enabled, I have some problem hiding the sidebar.
I press F1 when sidebar is not visibled. Then it shows.
Press F1 again, the sidebar doesn't hide.
I found it is the FOCUS problem.
After showing the sidebar, I click at the playlist to make it got focus. Then the key shortcut works.
foo_uie_tabs
Reply #205
Thanks for the report. The Track info plugin does the same thing.
You may be better off using the Show sidebar action rather than Enable sidebar, as it is faster and not affected by the bug.
foo_uie_tabs
Reply #206
I use your tabbed panels in the side bar and it works perfectly. Great plug in.
Could tell me how to place the tabbed panel side bar in the top right corner of the foobar? I would like to have the playlist column filling the bottom half of the foobar window, and in the top half of foobar window there should be one or two tabbed pannels.
Thank you
bye
foo_uie_tabs
Reply #208
thanks
foo_uie_tabs
Reply #209
[a href="index.php?act=findpost&pid=364060"][{POST_SNAPBACK}][/a]
Thanks for the reply.
According to the Column UI changlog,
Column UI plugin had the problem and has been fixed.
As I cannot install MSVC6(I don't know why), I can't edit or compile your source.
I hope you can fix the problem soon.
I had use Show hidebar but I found it just hide the sidebar but not close or destroy the windows.
However, Enable sidebar can close the window.
Some plugins, such as Lyric Show Panel, uses a timer control which is always active until the windows is not existed.
So I want to close the windows rather than just hide them. I do not care the speed.
That is why I use Enable sidebar.
By the way, you mentioned the bug. What is it?
foo_uie_tabs
Reply #210
Which problem is that? I'm not sure that it's related to the behaviour you reported.
foo_uie_tabs steals keyboard focus when its window is first created (by returning TRUE in response to WM_INITDIALOG).
foo_uie_tabs
Reply #211
I misunderstood the changelog of Columns UI
foo_uie_tabs
Reply #212
hi there...
can plz anyone tell me why i can't change the font of the tabs? in the preferences i can change it i know... but nothing happens. should i change some other settings to get the tabs working with an other font!?
..::l0ve is needed::..
foo_uie_tabs
Reply #213
is a version compatible with foobar2000 0.9.x planned? The 0.9 RC is already released, so I believe the plugin SDK shouldn't change with final.
foo_uie_tabs
Reply #214
is a version compatible with foobar2000 0.9.x planned? The 0.9 RC is already released, so I believe the plugin SDK shouldn't change with final.[a href="index.php?act=findpost&pid=367437"][{POST_SNAPBACK}][/a]
The SDK won't be released until the final version is out.
foo_uie_tabs
Reply #215
I'd like to have two (or more) different playlists - one for albums, one for live bootlegs, one for...  But when I make a new playlist,  it's a clone of the existing one.  If I clear the new one, the old one clears also.  Am I missing something, or will it just not do this?
voted 'Most likely to veer your thread' three straight years!
foo_uie_tabs
Reply #216
What does creating playlists have to do with foo_uie_tabs? You wouldn't be confusing the tabs from this component (which contain panels) with playlist tabs, would you?
foo_uie_tabs
Reply #217
OMG, I'm in the wrong thread!  Sorry 'bout that - it was late, and I was sleepy...
- edit - As long as I'm here; love the way this works!
foo_uie_tabs
Reply #218
Hmm... any plans for a 0.9 update?
foo_uie_tabs
Reply #219
[a href="index.php?act=findpost&pid=375380"][{POST_SNAPBACK}][/a]
Not sure, but if I understood musicmusic correctly he wanted to implement that feature natively into columns_ui. It could be that I misunderstood him though.
foo_uie_tabs
Reply #220
[a href="index.php?act=findpost&pid=375387"][{POST_SNAPBACK}][/a]
I don't think I ever said such a thing
foo_uie_tabs
Reply #221
[a href="index.php?act=findpost&pid=375507"][{POST_SNAPBACK}][/a]
Sorry for spreading wrong information! I thought to have heard sth. about tabs being implemented as a splitter or sth. like that. But since I can't even find a corresponding posting I think that I must have dreamed.
foo_uie_tabs
Reply #222
musicmusic any chance?
foo_uie_tabs
Reply #223
I'd like to see a port of this to 0.9 too.  I use it frequently in 0.8.3 with the history plugin and a few others, and it comes in very handy
Bostitch vs. Swingline; Choose your stapler wisely.
foo_uie_tabs
Reply #224
A 0.9 version would be nice
-foobar2000 + Burrrn + EAC
-HD 80Gb using High QualityVBR MP3s
