Topic: TTA CLI 3.2 Released (Read 6221 times) previous topic - next topic
Good....a request for the next releases : pipeencoding command will be great
And what about the Liisachan question ??
Thinking about it ;-) Please wait for TTA 3.3 in a month.
I have updated the damaged TTA binary for Linux right now.
Does TTA support APEv2 tags?
TTA codec and all of the plugins can work with APEv2 tags. Officially supported ID3v1/v2 tags only.
WAV file decoded from TTA using Tau Producer 1.1 doesnt play, because Tau Producer tries to copy tags into WAV by default
OK. You are right. I will disable this mode by default.
-- Alexander
Added support for unicode file names.
[a href="index.php?act=findpost&pid=248297"][{POST_SNAPBACK}][/a]
Wow
I thought you'd just add MultiByte Chars support, by skipping the next byte if the first byte is the leading byte of DBCS... but Unicode _is_ supported too! Thanks so much. This version-up is more than what I had expected.
But will this work on WIn98 too???? Maybe thru MSLU?
Wow  I thought you'd just add MultiByte Chars support..
We just start the work with multibyte support. I think that the 3.3 codec will to support it more completely.
As I know this one should work under Win98/98Me/NT-All/Linux/BSD/Mac and maybe somewhere else  I will test it under Win98 tomorrow.
-- Alexander
