Topic: Columns UI (Read 4610450 times) previous topic - next topic
0 Members and 12 Guests are viewing this topic.
Re: Columns UI
Reply #8000
Thanks, that's a good idea. Come to think of it, if I black it all out I don't even need lines, black space would be sufficient to separate albums.
Problem is, it only hides the titles, so the whole thing looks like this:
Re: Columns UI
Reply #8001
Also, if someone can recommend a cool idea to modify the toolbar area to match the rest of the window (maybe a waveform seekbar or better buttons or something), I'd be grateful
Have you tried the dark theme in Foobar2000 options ?
Unfortunately options page is also using dark theme, but at least, toolbars with dark theme will look better with your dark theme.
Re: Columns UI
Reply #8002
You can hide the lines behind the text by adding $tab() at the end.
Re: Columns UI
Reply #8003
Thanks, everyone. I have more or less what I wanted. I tried some seekbar components, but they have some padding problems, so I decided to stick with the stock one.
Re: Columns UI
Reply #8004
Looks great!
Think millionaire, but with cannons.
Re: Columns UI
Reply #8005
To be honest, not using Waveform Minibar (mod) as a seekbar is a crime !  :P
I don't know what's your problem with padding, maybe you missed it but you can use Waveform Minibar as a panel without borders (and not inside an ugly toolbar).
Re: Columns UI
Reply #8006
Hi :)
Please add "Playlist Switcher" to the standard toolbar.
for foobar2000 v2.0 64bit.
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD 490 PRO, DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
Re: Columns UI
Reply #8007
But Playlist Switcher is a list, it's not a dropdown, like this one (unfortunately dead) ? So how can it appear in a toolbar ?
Re: Columns UI
Reply #8008
"Playlist Switcher"is dropdown format.
I'm asking musicmusic now.
Re: Columns UI
Reply #8010
Default UI Toolbar (64bit).
I would like the Columns UI to have a similar feature.
(for foobar2000 v2.0 64bit)
Re: Columns UI
Reply #8011
OK, sorry. I didn't know this element. Thanks for the info, I've tried Default UI in the past, but never managed to stay 5 minutes with it, CUI has too much useful panels (in-components) for me.
Re: Columns UI
Reply #8012
foobar2000 v2.0 64bit, Columns UI (v2.0.0)
"JScript Panel 3" can be displayed on the toolbar.
If I could write the Script, there would be no problem.
Re: Columns UI
Reply #8013
Message to music music:
I want to report a small bug I have detected in the Playlist View.
foobar2000 v2.1 preview 2023-07-10 : 64-bit
Image1:
In a playlist I edit in-line any column (in the image1 the playlist "Favorites" and the title column). But instead of modifying the metadata content I decide not to do it and instead of pressing the scape key I decide to activate another playlist.
Image2:
I activate the playlist "Libr. View" and it remains as if it were a balloon the title field pending modification. If I press scape it disappears. But if you decide to modify the title metadata of the playlist "Favorites" is modified.
This problem does not exist in foobar2000 v2.1 preview 2023-07-10 : 32-bit
Re: Columns UI
Reply #8014
i think, that titleformatting of the Playlist switcher in Columns UI does not work correct.
In the previous foobar2000 version (< 2.0) the playlist was a dropdown and has shown the number of items from the playlist itself in clamps.
I tried this also with: %title% (%size%). But it still shows only the name. Do i missunderstand the behaviour of the titleformatting or is this a bug?
I have foobar2000 (x64) in version 2.0 and ColumnsUI in version: 2.0.0
Re: Columns UI
Reply #8015
Hi :)
That's already been implemented and will be in the next version. The changes for the next version are in the change log.
Thanks, have reproduced that. It's not related to 32- or 64-bit, your 32-bit layout may be different.
Re: Columns UI
Reply #8016
Playlist switcher and playlist tabs are two different panels. The settings on that tab are for the former.
Re: Columns UI
Reply #8017
Try this script:
%title% (%filesize%)
Re: Columns UI
Reply #8018
Reply #8016 : Ah, i see. But i like to now, how many items are in my play lists. Do you see a possibility, that this "titleformatting" also could used for the play list tabs? This would be great.
Re: Columns UI
Reply #8019
Try this script:
Thanks josemescud,
I tried it, but as musicmusic mentioned, this is not for the tabs. And %size% was correct, because on the additional playlist window, i saw the correct number of items.
Re: Columns UI
Reply #8020
@LoveAndMusic
Title Formatting Reference
Playlist-only fields
https://wiki.hydrogenaud.io/index.php?title=Foobar2000:Titleformat_Reference#Playlist-only_fields
%list_index%
%list_total%
foobar Preferences > Status bar tab > Status bar > Show number of select tracks
Playlist View Select All
Playlist switcher
Preferences > Display > Columns UI > Playlist switcher > Playlist switcher tab
Use title formatting for playlist titles:
Playlist switcher panel titleformatting reference
https://wiki.yuo.be/columns_ui:config:playlist_switcher_titleformatting
$if($strcmp(%size%,0),$upper(%title%), o %title%)
$tab()
$if(%is_active%,'[A]' ,)
$if(%is_playing%,'[P]' ,)
$if($strcmp(%size%,0),, %size% )
[ '[' %filesize% ']']
[ %length% ]
Re: Columns UI
Reply #8021
@Air KEN :
Thanks for the tip with the index in the playlist panel, this is helpful. I have add it.
Re: Columns UI
Reply #8022
Quote from: Changelog
The Item details panel no longer reads full metadata from non-playing files on foobar2000 2.0 and newer, as full metadata is always available on these versions.
Crossing my fingers that this will resolve the crashes I experience with the Item Details panels & kode's xSF decoders. Look forwards to trying it out.
Re: Columns UI
Reply #8023
HI :)
musicmusic
Columns UI 2.1.0-beta.2 (2023-07-23)
Add Toolbar > Playlist selectore
https://github.com/reupen/columns_ui/releases
Many Thanks.
Re: Columns UI
Reply #8024
I am experiencing new problems with sorting playlists with columns. It's slower than it was before, especially with larger playlists and especially if Show Groups is enabled, though more concerning is sometimes foobar2000 freezes altogether, forcing an exit. It's difficult for me to diagnose further because my copy takes a couple of minutes to re-open.
