Topic: Columns UI (Read 3906219 times) previous topic - next topic
Re: Columns UI
Reply #7200
How can I change make a picture the background of foobar instead of anything that's behind it?
Re: Columns UI
Reply #7201
Error Message received when attempting to export my Columns UI layout to an external file.
foobar2000 > Preferences > Column UI > Main Tab > FCL importing and exporting > Export...
All checkboxes are checked. Target is "Any foobar2000 installation". Enter any filename and I get the following error:
Error reading file "C:\Utilities\foobar\" : Object not found
C:\Utilities\foobar\ is the path where foobar2000 is located.
My component list:
Core (2016-12-21 21:14:22 UTC)
    foobar2000 core 1.3.14
foo_ac3.dll (2017-02-07 13:35:17 UTC)
    AC3 decoder 0.9.8
foo_albumlist.dll (2016-12-21 21:13:00 UTC)
    Album List 4.5
foo_cdda.dll (2016-12-21 21:12:32 UTC)
    CD Audio Decoder 3.0
foo_converter.dll (2016-12-21 21:12:30 UTC)
    Converter 1.5
foo_dbsearch.dll (2012-04-19 14:50:38 UTC)
    Database Search 1.4
foo_discogs.dll (2016-12-13 15:24:05 UTC)
    Discogs Tagger 2.12
foo_dsp_eq.dll (2016-12-21 21:13:06 UTC)
    Equalizer 1.2
foo_dsp_resampler_mod2.dll (2012-04-04 17:06:58 UTC)
    SoX Resampler mod2 0.7.8 mod2
foo_dsp_std.dll (2016-12-21 21:12:54 UTC)
    Standard DSP Array 1.3.1
foo_dynamic_range.dll (2015-06-18 15:06:48 UTC)
    Dynamic Range Meter 1.1.1
foo_dynamicdsp.dll (2013-03-25 12:51:04 UTC)
    Dynamic DSP 1.0
foo_fileops.dll (2016-12-21 21:12:02 UTC)
    File Operations 2.2.2
foo_freedb2.dll (2016-03-30 11:45:14 UTC)
    Online Tagger 0.7
foo_input_dvda.dll (2012-03-16 22:30:28 UTC)
    DVD-Audio Decoder and Watermark Detector 0.4.11
foo_input_sacd.dll (2015-12-14 13:23:38 UTC)
    Super Audio CD Decoder 0.9.6
foo_input_shorten.dll (2014-01-23 13:34:38 UTC)
    Shorten decoder 0.4.2.3
foo_input_std.dll (2016-12-21 21:12:48 UTC)
    FFmpeg Decoders 3.2.2
    Standard Input Array 1.0
foo_jesus.dll (2014-10-15 18:31:54 UTC)
    Autosave & Autobackup 10
foo_jscript_panel.dll (2017-02-07 13:35:17 UTC)
    JScript Panel 1.2.0
foo_masstag.dll (2011-10-14 12:56:22 UTC)
    Masstagger 1.8.4
foo_osd.dll (2017-02-07 13:35:17 UTC)
    On-Screen Display 1.74
foo_out_wasapi.dll (2013-03-15 12:30:14 UTC)
    WASAPI output support 3.2.3
foo_playcount.dll (2012-06-12 12:50:50 UTC)
    Playback Statistics 3.0.2
foo_playlist_attributes.dll (2013-12-05 17:09:12 UTC)
    Playlist Attributes 0.5.2
foo_popup_panels.dll (2015-09-22 17:59:22 UTC)
    Popup Panels 0.1.4
foo_queuecontents.dll (2012-12-10 16:24:36 UTC)
    Queue Contents Editor 0.5.1
foo_rgscan.dll (2016-03-30 11:44:24 UTC)
    ReplayGain Scanner 2.2.2
foo_run.dll (2014-02-20 15:30:50 UTC)
    Run services 0.3.7
foo_runcmd.dll (2012-05-02 13:50:50 UTC)
    Run Command 1.1
foo_stop_after_queue.dll (2016-08-26 12:27:09 UTC)
    Stop After Queue 0.7
foo_texttools.dll (2014-11-17 19:01:30 UTC)
    Text Tools 1.0.5
foo_tradersfriend.dll (2011-10-14 12:56:24 UTC)
    Live Show Tagger 0.7.1
foo_ui_columns.dll (2016-11-01 12:40:40 UTC)
    Columns UI 0.5.1
foo_ui_std.dll (2016-12-21 21:12:40 UTC)
    Default User Interface 0.9.5
foo_uie_albumlist.dll (2016-03-28 12:18:06 UTC)
    Album list panel 0.3.7
foo_whatsnew.dll (2014-08-13 13:07:22 UTC)
    Feature Watcher 1.1.1
foo_youtube.dll (2015-07-15 14:33:46 UTC)
    Youtube Source 1.11
Re: Columns UI
Reply #7202
Do you perhaps have 'C:\Utilities\foobar\' as a path of a button image in an instance of the buttons toolbar?
Re: Columns UI
Reply #7203
Damn, you're good. :)
That was it.  Even though I was displaying Text for my Stop After Current button, there was an empty custom image setup from a long, long time ago.
Thank you.  Export works now.
Re: Columns UI
Reply #7204
Ah, so it decides the blank path is a relative path and expands it out to the foobar2000 installation directory. I'm sure the behaviour could be improved in a few places.
No problem!
Re: Columns UI
Reply #7205
Everything is fine when playing local files, but when online radio is playing, %artist%, %title% showing only radio station name :(
Although if I enable status bar, there it works fine. That artist and title is everywhere - status bar, title bar, taskbar, scrolling and all, but in the skin it doesn't show up, only station name. What am I doing wrong?
Re: Columns UI
Reply #7206
Did you check your Preferences -> Networking?
HTH.
Alessandro
Re: Columns UI
Reply #7208
I like Custom UI but it haven't a function that I like and  that I can enable using the Default User interface, With the Default User interface I can click on the X (close) and foobar2000 go in my systray, with Custom UI is impossible :(
Re: Columns UI
Reply #7209
You refer to a skin, is that something you downloaded from somewhere? Is it in the playlist you mean it isn't showing up? Do you know what playlist view you are using?
Close should mean close, that's why close closes the player. Why do you want that behaviour?
Re: Columns UI
Reply #7210
Well, mystery solved. It is Panel Stack Splitter. %title% or %artist% must be in "Per second" section.
Re: Columns UI
Reply #7211
Hey :). I'm starting the development of a new component. I will use the ColumnsUI SDK. It's been a while since I developed using C++ so please be understanding. I have three questions:
1. I intend to create a panel that makes use of comboboxes. From what I've seen in the Columns UI SDK, there is an API for a Button. Does this mean that buttons get some sort of special treatment or does it mean that it's the only supported UI component? I suppose I can add any sort of WIN32 components I wish by using CreateWindowEx ?
2. What would you recommend in order to build a user interface as easy as possible? Can I use MFC for example?
3. I suppose I can debug my component by launching & attaching to Foobar? Any things I should know before I attempt that? I've noticed Foobar always warns me when I start it with a debug component. Can I get rid of that warning somehow?
Thank you in advance!
Re: Columns UI
Reply #7212
P.S.: I saw that Foobar components use ATL (& WTL). But does this mean I can't include MFC? (not that I care much about this at this point - I'm fine with whatever :) ).
Re: Columns UI
Reply #7213
P.P.S: there goes another of my questions :). I attached to the process and saw that Foobar doesn't warn about the DLL being in debug mode. Apparently it somehow detects that it was launched by Visual Studio. Awesome! :).
Re: Columns UI
Reply #7214
P.P.P.S :D. I finally got to unwrap the project enough to see you use MFC there. I looked in JSPanel source and saw it's used there as well. So I guess I have most my answers now. Sorry for spamming here. Would be good if a moderator can delete all my replies here and just leave one question:
Why is there a separate API for a Button in ColumnsUI but not for other UI elements?
Is it because toolbar buttons require a different behavior than a standard MFC button?
Re: Columns UI
Reply #7215
The button API is for customising buttons in the buttons toolbar for commands associated with your component e.g. a back button with a drop-down list of tracks, a play button that stays pressed during playback, or proving a default icon for your own menu commands. It's not related to putting buttons in your own windows (unless you were reimplementing the buttons toolbar...)
Also, these kinds of questions would better fit in the development forum :)
Re: Columns UI
Reply #7216
Hi, wondering if anyone got a working solution for being able to use ctrl+tab (and ctrl+shift+tab) to switch back and forward between playlists?
(Like how one can do with tabs in the browser).
Using Columns UI: tab, ctrl+tab and ctrl+shift+tab all does the same thing (switch the selection between the playlist and the tabs).
Using the Default User Interface: ctrl+tab and ctrl+shift+tab switches back and forward between playlists (like I want) and tab switches the selection between the playlist and the tabs (the same thing any tab-combination does in Columns UI).
Foobar wont let you do any custom bindings using the tab button.
Maybe I can edit Columns UI in some way? maybe there is a plugin that lets me bind the tab key? or I could somehow edit the configuration to enable me to bind the tab key?
Edit: just noticed that this already is in the feature requests ( https://wiki.yuo.be/columns_ui:requests:requests_list )
Sorry for bringing it up when you already know it is an issue.
Re: Columns UI
Reply #7217
The taskbar previews may be changed to cover instead of the interface thumbnail?  Or add a toggle option?
Re: Columns UI
Reply #7218
Hi today my microsoft defender suddently tell me that colums ui dll is the trojan virus .
Any solution?
Re: Columns UI
Reply #7219
Can't reproduce here. Could you post a hash of the file and do you know what version it is? Also try uploading the file to http://www.virustotal.com/.
Re: Columns UI
Reply #7220
I uploade the file to that site shows it's safe(0/65).
But In my computer , Microsoft defender detects it.
After I download the component agin from https://yuo.be/download/columns_ui/foo_ui_columns-0.5.1.fb2k-component
Chrome blocked the download file by the Microsoft defender scanning .
I found that it just happen on ver 0.5.1
0.5.0 has no problem though.
Here is the screenshot.
http://imgur.com/a/fvdSv
Re: Columns UI
Reply #7222
When a track's paused and I close FB2K.
The Status pane, (not the lower status bar) shows the track as still playing. Is there any way to edit this content?
There is, but not the playing: /pause: text. That's internal code. So a bug it seems.
Re: Columns UI
Reply #7223
Yes, you're right. It'll be fixed for the next version.
Re: Columns UI
Reply #7224
Since the filters preferences have been re-arranged, the 2nd option in the Filter precedence drop down could do with being reworded...
