Topic: Columns UI (Read 4609147 times) previous topic - next topic
0 Members and 8 Guests are viewing this topic.
Columns UI
Reply #5700
Version 0.3.8.2 released for testing.
Looks like there is a slight issue preserving a group internally when it only has one track and that track is modified (causing the flicker). Though that means something is triggering an 'item modified' notification when playback is starting for you, but anyway I'll check what I can do to fix this.. Thanks
Should be sorted now in 0.3.8.2.
I think the inline metadata editing in the "Filter" section can be very useful, but I would appreciate a possibility of disabling it.
Sometimes people come and browse my music collection, and I am afraid someone might accidentally double-click and change an artist's name or something--and not just for one file, but for all my files by the same artist.
Hi, I can understand someone might accidentally click twice on something. However would they really follow that up with typing..?
Lindows support, and big NO to Vista
  indeed...
Columns UI
Reply #5702
View>Status Pane. I don't know if the rest is configurable.
oh, and thanks musicmusic! it works well here.
Columns UI
Reply #5703
Just untick at View/Status pane.
Replaced 0.3.8.1 with 0.3.8.2 due to a bug with inline editing.
[edit] I should have added you can use $crlf() to gain access to the second line in status pane (it uses the same title formatting script as the status bar). You can't change its font at the moment, but I'll add that for the next version.
Columns UI
Reply #5704
I ran into this problem today: If a playlist is set to shuffle, and all the items in it are invalid (because the corresponding files have been removed, or the containing directory renamed), after starting playback, the player becomes unresponsive, and often cannot be stopped using the stop button, or closed, but has to be killed forcibly.
EDIT: I have v 0.3.8.2
Columns UI
Reply #5705
Make sure your components are all up-to-date including console panel.
Columns UI
Reply #5706
$tab() doesn't work in my status pane
Columns UI
Reply #5707
thanks for the update. but would it be possible to have an option to remove the "playing/paused" text in the status pane? i run a very narrow foobar window and it gets in the way.
Columns UI
Reply #5708
1) With 0.3.8.2 foo_grabber_python.dll crashes on Foobar startup. Crashdump sent. (Oh, as it don't look to be related with Colums UI, and it will not be sent to you, ctrl+V)
2) How turn off new status panel?
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 1E044F03h
Access violation, operation: read, address: 00000004h
Call path:
entry=>initquit::on_init
Code bytes (1E044F03h):
1E044EC3h:  C3 8B 57 18 56 52 E8 32 D2 03 00 83 C4 08 5F 5E
1E044ED3h:  C3 CC CC CC CC CC CC CC CC CC CC CC CC 83 EC 08
1E044EE3h:  53 55 56 8B 74 24 18 85 F6 57 75 0F E8 9C 16 02
1E044EF3h:  00 5F 5E 5D 33 C0 5B 83 C4 08 C3 A1 A0 46 1F 1E
1E044F03h:  8B 78 04 8B 47 18 85 C0 89 7C 24 14 75 0D E8 3A
1E044F13h:  FE FF FF 85 C0 0F 85 15 01 00 00 8B C6 E8 6B F5
1E044F23h:  FF FF 85 C0 89 44 24 10 0F 84 02 01 00 00 8D 4C
1E044F33h:  24 10 51 E8 95 CA 07 00 8B 54 24 14 8B 47 1C 52
Stack (0049F89Ch):
0049F87Ch:  00000000 00000000 00000000 00000000
0049F88Ch:  00000000 00000000 00000000 00000000
0049F89Ch:  00000000 6CCAF34C 0049F93C 6CCBD2D4
0049F8ACh:  6CC74503 0049F930 1E0DE59B 6CCAF34C
0049F8BCh:  00000013 6CC7489B 6CCAF34C 831875E6
0049F8CCh:  00000000 6CCBD2C0 00000000 00000001
0049F8DCh:  00000000 00000000 00000000 00000000
0049F8ECh:  00000000 6CCAF2DC 00000000 00000000
0049F8FCh:  00000000 00000013 0006F8F2 0799AE20
0049F90Ch:  0006F946 00000000 6CCBD33C 00000039
0049F91Ch:  6CCBD2D4 0006F5FC 8318755C 0049F7F8
0049F92Ch:  0049F8C8 0049FA08 6CCAACD0 00000000
0049F93Ch:  0049F950 6CC721B6 6CCBD2C0 00000000
0049F94Ch:  6CCBD2BC 0049FA14 6CC10539 0799AE24
0049F95Ch:  00000000 0049F9D4 8318E6FF 0049FA28
0049F96Ch:  0000000C 00000000 FFFFFFFF 6CC5387C
0049F97Ch:  00000000 00000000 00000000 00000013
0049F98Ch:  00000009 00000002 0049F9BC 6CC53680
0049F99Ch:  03950E38 00000030 00000040 0000002F
0049F9ACh:  00000002 01C753C8 6CC53910 0049F9BC
Registers:
EAX: 00000000, EBX: 6CCBD2D4, ECX: 00000001, EDX: 00000072
ESI: 6CCAF34C, EDI: 00000000, EBP: 0049F93C, ESP: 0049F89C
Crash location:
Module: python25
Offset: 44F03h
Symbol: "PyCodec_Lookup" (+23h)
Loaded modules:
foobar2000                      loaded at 00030000h - 001CA000h
ntdll                            loaded at 77770000h - 77897000h
kernel32                        loaded at 76320000h - 763FC000h
COMCTL32                        loaded at 74D80000h - 74F1E000h
msvcrt                          loaded at 760A0000h - 7614A000h
ADVAPI32                        loaded at 775B0000h - 77676000h
RPCRT4                          loaded at 76820000h - 768E3000h
GDI32                            loaded at 77980000h - 779CB000h
USER32                          loaded at 76400000h - 7649D000h
SHLWAPI                          loaded at 77400000h - 77459000h
DSOUND                          loaded at 6F430000h - 6F4A0000h
ole32                            loaded at 77460000h - 775A5000h
WINMM                            loaded at 74660000h - 74692000h
OLEAUT32                        loaded at 75F30000h - 75FBD000h
OLEACC                          loaded at 74620000h - 7465D000h
POWRPROF                        loaded at 75120000h - 7513A000h
SHELL32                          loaded at 768F0000h - 77400000h
shared                          loaded at 10000000h - 1002B000h
imagehlp                        loaded at 778C0000h - 778E9000h
UxTheme                          loaded at 74B00000h - 74B3F000h
dbghelp                          loaded at 72CF0000h - 72DCC000h
COMDLG32                        loaded at 75EA0000h - 75F13000h
IMM32                            loaded at 778A0000h - 778BE000h
MSCTF                            loaded at 75FD0000h - 76098000h
LPK                              loaded at 75FC0000h - 75FC9000h
USP10                            loaded at 76150000h - 761CD000h
CLBCatQ                          loaded at 778F0000h - 77974000h
MMDevApi                        loaded at 745E0000h - 74608000h
SETUPAPI                        loaded at 76690000h - 7681A000h
WINTRUST                        loaded at 74F70000h - 74F9D000h
CRYPT32                          loaded at 75770000h - 75862000h
MSASN1                          loaded at 758D0000h - 758E2000h
USERENV                          loaded at 75CD0000h - 75CEE000h
Secur32                          loaded at 75CB0000h - 75CC4000h
foo_dsp_vlevel                  loaded at 005B0000h - 005BB000h
MSVCR80                          loaded at 71270000h - 7130B000h
foo_rgscan                      loaded at 02800000h - 0284E000h
foo_input_std                    loaded at 02D80000h - 02EC1000h
foo_input_mslive                loaded at 02ED0000h - 02F11000h
WMVCore                          loaded at 6B860000h - 6BAAB000h
WMASF                            loaded at 6F4D0000h - 6F509000h
gdiplus                          loaded at 748C0000h - 74A6B000h
foo_uie_typefind                loaded at 01B60000h - 01B90000h
foo_discogs                      loaded at 02F50000h - 02FB5000h
WININET                          loaded at 77680000h - 77766000h
Normaliz                        loaded at 75F20000h - 75F23000h
urlmon                          loaded at 761D0000h - 76302000h
iertutil                        loaded at 764A0000h - 76688000h
foo_input_shorten                loaded at 01F30000h - 01F5D000h
foo_freedb2                      loaded at 03010000h - 03051000h
foo_osd                          loaded at 021C0000h - 021F4000h
foo_input_alac                  loaded at 02950000h - 02970000h
foo_lastfm_radio                loaded at 03080000h - 030C8000h
foo_stopaftercuralbum            loaded at 02FC0000h - 02FDF000h
foo_jesus                        loaded at 71420000h - 71447000h
foo_uie_console                  loaded at 030D0000h - 030EA000h
foo_ui_std                      loaded at 03490000h - 0359E000h
MSIMG32                          loaded at 75110000h - 75115000h
foo_playlist_manager            loaded at 03250000h - 03294000h
foo_uie_panel_splitter          loaded at 03410000h - 03469000h
foo_unpack                      loaded at 032C0000h - 032EE000h
foo_grabber_python              loaded at 6CC70000h - 6CCC7000h
python25                        loaded at 1E000000h - 1E208000h
MSVCR71                          loaded at 7C340000h - 7C396000h
foo_audioscrobbler              loaded at 03320000h - 03351000h
foo_uie_elplaylist              loaded at 035D0000h - 03641000h
foo_lyricsgrabber                loaded at 6CC00000h - 6CC65000h
WS2_32                          loaded at 75E20000h - 75E4D000h
NSI                              loaded at 76310000h - 76316000h
foo_dumb                        loaded at 038C0000h - 0394F000h
foo_stop_on_current              loaded at 73310000h - 7332C000h
foo_sid                          loaded at 03A00000h - 03A7D000h
foo_uie_albumart                loaded at 039A0000h - 039DD000h
foo_facets                      loaded at 03A90000h - 03B10000h
foo_cdda                        loaded at 03B10000h - 03B50000h
foo_input_monkey                loaded at 03BB0000h - 03BF8000h
foo_queuecontents                loaded at 03960000h - 03985000h
foo_converter                    loaded at 03DF0000h - 03E5C000h
foo_run                          loaded at 03C50000h - 03CAF000h
foo_ui_columns                  loaded at 04150000h - 042C2000h
foo_comserver2                  loaded at 03EB0000h - 03F06000h
foo_vis_shpeck                  loaded at 6C5C0000h - 6C601000h
foo_uie_trackinfo_mod            loaded at 03F10000h - 03F66000h
MSVCP80                          loaded at 6C750000h - 6C7D7000h
foo_albumlist                    loaded at 042D0000h - 0432B000h
foo_fileops                      loaded at 03F90000h - 03FD6000h
foo_removefromqueue              loaded at 03C10000h - 03C1A000h
foo_uie_lyrics2                  loaded at 04360000h - 043D7000h
foo_playcount                    loaded at 040F0000h - 04120000h
foo_uie_albumlist                loaded at 04430000h - 0446D000h
foo_uie_playlists_dropdown      loaded at 047A0000h - 047DC000h
foo_uie_quicksearch              loaded at 047F0000h - 04836000h
foo_abx                          loaded at 04840000h - 04872000h
foo_uie_bookmarks                loaded at 04B40000h - 04BA1000h
foo_uie_tabs                    loaded at 043E0000h - 04408000h
foo_dsp_std                      loaded at 04AE0000h - 04B29000h
foo_masstag                      loaded at 04BB0000h - 04BF3000h
foo_verifier                    loaded at 04C00000h - 04C43000h
foo_musicbrainz                  loaded at 6CB10000h - 6CB6C000h
WINHTTP                          loaded at 73720000h - 73780000h
foo_uie_graphical_browser        loaded at 6C260000h - 6C2F4000h
WindowsCodecs                    loaded at 73FE0000h - 740D4000h
apphelp                          loaded at 75C50000h - 75C7C000h
TortoiseOverlays                loaded at 04E10000h - 04E27000h
tortoisehg                      loaded at 04E40000h - 04E49000h
win32api                        loaded at 1E8F0000h - 1E908000h
VERSION                          loaded at 754E0000h - 754E8000h
pywintypes25                    loaded at 1E7D0000h - 1E7EC000h
pythoncom25                      loaded at 04F80000h - 04FD9000h
win32trace                      loaded at 1ED10000h - 1ED17000h
rsaenh                          loaded at 751E0000h - 7521B000h
win32file                        loaded at 1EA40000h - 1EA5A000h
MSWSOCK                          loaded at 75420000h - 7545B000h
sfc                              loaded at 73980000h - 73985000h
sfc_os                          loaded at 732A0000h - 732AD000h
win32process                    loaded at 1EC20000h - 1EC2B000h
Psapi                            loaded at 75D80000h - 75D87000h
shell                            loaded at 1E830000h - 1E86B000h
win32event                      loaded at 1E9E0000h - 1E9E8000h
win32ui                          loaded at 1E280000h - 1E33C000h
MFC71                            loaded at 7C140000h - 7C246000h
WINSPOOL                        loaded at 734F0000h - 73532000h
win32gui                        loaded at 1EA70000h - 1EA98000h
bz2                              loaded at 1D170000h - 1D183000h
bdiff                            loaded at 66A00000h - 66A09000h
mpatch                          loaded at 61F00000h - 61F09000h
_hashlib                        loaded at 05030000h - 05068000h
_socket                          loaded at 05000000h - 0500D000h
_ssl                            loaded at 08680000h - 086F6000h
WSOCK32                          loaded at 75040000h - 75047000h
win32net                        loaded at 1EB60000h - 1EB73000h
NETAPI32                        loaded at 75B20000h - 75B96000h
base85                          loaded at 69C40000h - 69C48000h
diffhelpers                      loaded at 688C0000h - 688C8000h
TortoiseStub                    loaded at 05200000h - 0520E000h
TortoiseSVN                      loaded at 08F90000h - 09058000h
SHFOLDER                        loaded at 75030000h - 75035000h
libapr_tsvn                      loaded at 6EEC0000h - 6EEE2000h
MSVCR90                          loaded at 74C80000h - 74D23000h
libaprutil_tsvn                  loaded at 6EE60000h - 6EE8F000h
WLDAP32                          loaded at 75E50000h - 75E99000h
intl3_tsvn                      loaded at 05470000h - 05482000h
MSVCP90                          loaded at 74BF0000h - 74C7E000h
DropboxExt.3                    loaded at 054A0000h - 054B3000h
MSVCP71                          loaded at 7C3A0000h - 7C41B000h
EhStorShell                      loaded at 74BD0000h - 74BEF000h
PROPSYS                          loaded at 74430000h - 744EB000h
IconCodecService                loaded at 74BB0000h - 74BB6000h
Stack dump analysis:
Address: 6CCAF34Ch (foo_grabber_python+3F34Ch), symbol: "foobar2000_get_interface" (+2F8FCh)
Address: 6CCBD2D4h (foo_grabber_python+4D2D4h), symbol: "foobar2000_get_interface" (+3D884h)
Address: 6CC74503h (foo_grabber_python+4503h)
Address: 1E0DE59Bh (python25+DE59Bh), symbol: "PyUnicodeUCS2_SetDefaultEncoding" (+Bh)
Address: 6CC7489Bh (foo_grabber_python+489Bh), symbol: "initgrabber" (+17Bh)
Address: 6CCBD2C0h (foo_grabber_python+4D2C0h), symbol: "foobar2000_get_interface" (+3D870h)
Address: 6CCAF2DCh (foo_grabber_python+3F2DCh), symbol: "foobar2000_get_interface" (+2F88Ch)
Address: 0006F8F2h (foobar2000+3F8F2h)
Address: 0006F946h (foobar2000+3F946h)
Address: 6CCBD33Ch (foo_grabber_python+4D33Ch), symbol: "foobar2000_get_interface" (+3D8ECh)
Address: 0006F5FCh (foobar2000+3F5FCh)
Address: 6CCAACD0h (foo_grabber_python+3ACD0h), symbol: "foobar2000_get_interface" (+2B280h)
Address: 6CC721B6h (foo_grabber_python+21B6h)
Address: 6CCBD2BCh (foo_grabber_python+4D2BCh), symbol: "foobar2000_get_interface" (+3D86Ch)
Address: 6CC10539h (foo_lyricsgrabber+10539h)
Address: 6CC5387Ch (foo_lyricsgrabber+5387Ch), symbol: "foobar2000_get_interface" (+3BA4Ch)
Address: 6CC53680h (foo_lyricsgrabber+53680h), symbol: "foobar2000_get_interface" (+3B850h)
Address: 6CC53910h (foo_lyricsgrabber+53910h), symbol: "foobar2000_get_interface" (+3BAE0h)
Address: 6CC53F60h (foo_lyricsgrabber+53F60h), symbol: "foobar2000_get_interface" (+3C130h)
Address: 74A47200h (gdiplus+187200h), symbol: "GdipCloneBitmapArea" (+DFF20h)
Address: 00055601h (foobar2000+25601h)
Address: 6CC4BAC3h (foo_lyricsgrabber+4BAC3h), symbol: "foobar2000_get_interface" (+33C93h)
Address: 0008CFDBh (foobar2000+5CFDBh)
Address: 6CC5B65Ch (foo_lyricsgrabber+5B65Ch), symbol: "foobar2000_get_interface" (+4382Ch)
Address: 00146301h (foobar2000+116301h)
Address: 0008E30Dh (foobar2000+5E30Dh)
Address: 001605FCh (foobar2000+1305FCh)
Address: 0017139Ch (foobar2000+14139Ch)
Address: 00070EC4h (foobar2000+40EC4h)
Address: 00030000h (foobar2000+0h)
Address: 777D6500h (ntdll+66500h), symbol: "RtlDeactivateActivationContextUnsafeFast" (+5Fh)
Address: 777799FAh (ntdll+99FAh), symbol: "WinSqmStartSession" (+27Bh)
Address: 777D68FDh (ntdll+668FDh), symbol: "RtlFreeHeap" (+28Dh)
Address: 777D661Fh (ntdll+6661Fh), symbol: "RtlAllocateHeap" (+AFh)
Address: 777D6570h (ntdll+66570h), symbol: "RtlAllocateHeap" (+0h)
Address: 00193CC0h (foobar2000+163CC0h)
Address: 0013223Bh (foobar2000+10223Bh)
Address: 00139717h (foobar2000+109717h)
Address: 0008001Fh (foobar2000+5001Fh)
Address: 00135670h (foobar2000+105670h)
Address: 00137BCEh (foobar2000+107BCEh)
Address: 00132928h (foobar2000+102928h)
Address: 1000260Dh (shared+260Dh), symbol: "uPrintCrashInfo_OnEvent" (+B0h)
Address: 00167688h (foobar2000+137688h)
Address: 001516B2h (foobar2000+1216B2h)
Address: 10002650h (shared+2650h), symbol: "uCallStackTracker::uCallStackTracker" (+2Fh)
Address: 0008E63Eh (foobar2000+5E63Eh)
Address: 00158850h (foobar2000+128850h)
Address: 000407A6h (foobar2000+107A6h)
Address: 00132786h (foobar2000+102786h)
Address: 0013279Ah (foobar2000+10279Ah)
Address: 00151955h (foobar2000+121955h)
Address: 001334CCh (foobar2000+1034CCh)
Address: 0013ADD7h (foobar2000+10ADD7h)
Address: 7636D0E9h (kernel32+4D0E9h), symbol: "BaseThreadInitThunk" (+12h)
Address: 777B19BBh (ntdll+419BBh), symbol: "RtlInitializeExceptionChain" (+63h)
Address: 763BFD89h (kernel32+9FD89h), symbol: "UnhandledExceptionFilter" (+0h)
Address: 777B198Eh (ntdll+4198Eh), symbol: "RtlInitializeExceptionChain" (+36h)
Address: 00133537h (foobar2000+103537h)
Address: 00040104h (foobar2000+10104h)
Address: 00080188h (foobar2000+50188h)
Address: 00080108h (foobar2000+50108h)
Address: 00050185h (foobar2000+20185h)
Address: 00050105h (foobar2000+20105h)
Address: 00100110h (foobar2000+D0110h)
Address: 000C020Ch (foobar2000+9020Ch)
Address: 000A018Ah (foobar2000+7018Ah)
Address: 000C010Ch (foobar2000+9010Ch)
Address: 00081008h (foobar2000+51008h)
Address: 00082D08h (foobar2000+52D08h)
Address: 00051305h (foobar2000+21305h)
Address: 00082E08h (foobar2000+52E08h)
Address: 00044204h (foobar2000+14204h)
Address: 0005A505h (foobar2000+2A505h)
Address: 00051A05h (foobar2000+21A05h)
Address: 00059D05h (foobar2000+29D05h)
Address: 0005CD05h (foobar2000+2CD05h)
Address: 00081508h (foobar2000+51508h)
Address: 0005CB05h (foobar2000+2CB05h)
Address: 00055805h (foobar2000+25805h)
Address: 000A010Ah (foobar2000+7010Ah)
Address: 00047004h (foobar2000+17004h)
Address: 00045B04h (foobar2000+15B04h)
Address: 00044104h (foobar2000+14104h)
Address: 000FD90Fh (foobar2000+CD90Fh)
Address: 000A060Ah (foobar2000+7060Ah)
Address: 00041104h (foobar2000+11104h)
Address: 0005F305h (foobar2000+2F305h)
Address: 00040204h (foobar2000+10204h)
Address: 00058005h (foobar2000+28005h)
Address: 00050905h (foobar2000+20905h)
Address: 00050585h (foobar2000+20585h)
Address: 00080708h (foobar2000+50708h)
Environment:
App: foobar2000 v0.9.6.9 beta 1
OS: Windows 6.0.6002 Service Pack 2 x86
CPU: Intel® Core™2 Duo CPU    E7200  @ 2.53GHz, features: MMX SSE SSE2 SSE3 SSE4.1
Audio: Głośniki (Creative SB Audigy); SPDIF Out (Creative SB Audigy); Cyfrowe urządzenie wyjściowe (SPDIF) (Urządzenie zgodne ze standardem High Definition Audio); Głośniki (Bluetooth AV Audio); Głośniki (Bluetooth SCO Audio)
UI: Columns UI 0.3.8.2
Components:
Core (2009-08-05 20:56:50)
    foobar2000 core 0.9.6.9 beta 1
foo_abx.dll (2009-06-07 13:25:26)
    ABX Comparator 1.3.4
foo_albumlist.dll (2009-08-05 20:55:12)
    Album List 4.3.1
foo_audioscrobbler.dll (2009-10-25 20:30:02)
    Audioscrobbler 1.4.3
foo_cdda.dll (2009-08-05 20:54:58)
    CD Audio Decoder 2.1.4
foo_comserver2.dll (2006-07-31 20:13:20)
    COM Automation server 0.7 alpha 6
foo_converter.dll (2009-08-05 20:54:54)
    Converter 1.2.1
foo_discogs.dll (2009-12-23 03:26:55)
    Discogs Tagger 1.22
foo_dsp_std.dll (2009-08-05 20:55:18)
    Standard DSP Array 1.0
foo_dsp_vlevel.dll (2008-03-02 23:42:06)
    VLevel 20080302.0
foo_dumb.dll (2009-11-28 11:13:44)
    DUMB module decoder 0.9.9.9
foo_facets.dll (2008-01-08 00:42:16)
    Facets 2008-01-04
foo_fileops.dll (2009-08-05 20:53:56)
    File Operations 2.1.2
foo_freedb2.dll (2009-08-05 20:54:16)
    freedb Tagger 0.6.1
foo_grabber_python.dll (2009-02-06 13:40:15)
    Lyrics Grabber Dances With Python 0.1.12 Alpha
foo_input_alac.dll (2009-03-22 14:15:46)
    ALAC Decoder 1.0.3
foo_input_monkey.dll (2009-05-01 13:40:52)
    Monkey's Audio Decoder 2.1.4
foo_input_mslive.dll (2009-01-05 19:46:44)
    mslive 0.4.9 (SSE)
foo_input_shorten.dll (2007-01-22 13:05:40)
    Shorten decoder 0.4.2a
foo_input_std.dll (2009-08-05 20:54:52)
    Standard Input Array 1.0
foo_jesus.dll (2010-01-03 13:41:18)
    Autosave & Autobackup 8
foo_lastfm_radio.dll (2009-02-25 22:05:24)
    Last.fm Radio 0.5.6b
foo_lyricsgrabber.dll (2009-02-07 07:12:47)
    Lyrics Grabber 0.3.0.7 Alpha
foo_masstag.dll (2008-11-29 12:13:26)
    Masstagger 1.7.1
foo_musicbrainz.dll (2009-04-10 21:27:28)
    MusicBrainz Tagger 0.2
foo_osd.dll (2007-01-25 13:58:44)
    On-Screen Display GDI+ 1.52
foo_playcount.dll (2009-04-29 19:09:32)
    Playback Statistics 2.1.9
foo_playlist_manager.dll (2007-01-22 12:05:12)
    Playlist Manager 1.0.2
foo_queuecontents.dll (2009-07-28 07:33:04)
    Queue Contents Editor 0.1.1
foo_removefromqueue.dll (2007-07-14 13:30:00)
    Remove from Queue 1
foo_rgscan.dll (2009-08-05 20:54:44)
    ReplayGain Scanner 2.0.9
foo_run.dll (2009-06-07 14:15:18)
    Run services 0.3.7
foo_sid.dll (2009-04-16 13:30:28)
    sidplay2 1.14
foo_stop_on_current.dll (2009-06-10 17:23:28)
    Stop on Current 0.2
foo_stopaftercuralbum.dll (2009-06-01 08:50:42)
    foo_stopaftercuralbum 0.2
foo_ui_columns.dll (2010-01-05 23:03:59)
    Columns UI 0.3.8.2
foo_ui_std.dll (2009-08-05 20:55:16)
    Default User Interface 0.9.5
foo_uie_albumart.dll (2007-12-15 23:22:24)
    Album Art Panel 0.2.7.1
foo_uie_albumlist.dll (2009-03-28 16:14:17)
    Album list panel 0.3.4
foo_uie_bookmarks.dll (2008-07-19 17:29:50)
    Bookmarks 0.2.6
foo_uie_console.dll (2009-08-29 17:06:24)
    Console panel 0.4
foo_uie_elplaylist.dll (2009-12-11 23:35:40)
    ELPlaylist 0.6.6.4(beta)
foo_uie_graphical_browser.dll (2008-04-19 20:37:52)
    Graphical Browser rev015
foo_uie_lyrics2.dll (2009-12-23 13:31:04)
    Lyric Show Panel 2 0.4.5
foo_uie_panel_splitter.dll (2009-12-10 00:16:12)
    Panel Stack Splitter 0.3.8.3(alpha)
foo_uie_playlists_dropdown.dll (2008-12-08 02:43:24)
    Playlists Dropdown 0.7 beta 1
foo_uie_quicksearch.dll (2007-05-18 12:31:10)
    Quick Search Toolbar 2.8l
foo_uie_tabs.dll (2008-12-10 23:06:50)
    Tabbed Panel Modified 0.2.7
foo_uie_trackinfo_mod.dll (2007-01-05 14:36:20)
    Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]
foo_uie_typefind.dll (2007-10-22 22:30:44)
    Typefind 0.2 beta 2
foo_unpack.dll (2009-08-05 20:53:42)
    RAR reader 1.2
    ZIP/GZIP reader 1.0
foo_verifier.dll (2009-10-05 10:39:20)
    File Integrity Verifier 1.1
foo_vis_shpeck.dll (2009-09-25 14:08:48)
    Shpeck - Winamp vis plugins wrapper 0.3.6
Recent events:
Watching: H:\Alternative
Watching: H:\Mp3
Watching: H:\Oldies
Watching: H:\Metal
Watching: H:\OST
Watching: H:\Punk
Watching: H:\Rock
Watching: H:\Sorted
Watching: H:\Techno
Columns UI
Reply #5709
Working fine for me, just one request would it be possible to include the Filter Panel : Column Titles to the Colours section of the Colours & Fonts Preferences settings.
Thanks for all the hard work and making foobar almost perfect for my simple config
Columns UI
Reply #5710
Great that NG artwork stops flickering on one item/group
DSP manager commands (introduced in foobar betas) are still not accessible as button commands
status bar OR status pane? one accepts $tab(), and other $crlf(), but both use same title formatting, and status bar has playlist lock status
I personally like to see dB value instead of graphical volume bar, but seems that status pane is more easily readable
[edit] musicmusic can you add option to dock auto-hiding panel?
like when I hover over hidden panel caption and it shows up, than when I click on the caption let it stay on top (or double click or right click and select stay on top)?
Columns UI
Reply #5711
OK, I can probably add it..
Hmm, I'll try and make it work a bit better at smaller sizes, and I'll think about some customisation options.
1. Nothing in that log I can check. Report to foo_grabber_python developer first, and also submit the crash online.
2. View menu.
Haven't quite had a look at this yet, will do for one of the next versions.
There's a %is_status_pane% that the default script uses, but yes I would expect you to use one or the other. It's not ideal having the same script, but the variable is a compromise. Playlist lock status - better suited to playlist switcher I think?
I will probably make the tooltip show up on mouse over (the "thumb") as a compromise.
I[edit] musicmusic can you add option to dock auto-hiding panel?
I'll keep it in mind.
Columns UI
Reply #5712
musicmusic,
so do you consider to move the playlist lock status visualization from the status bar to the playlist switcher?
I am using neither the playlist switcher nor the status pane in my layouts and instead most of the time a simple playlist view with status bar, so that I then would miss that information.
Columns UI
Reply #5713
No the status bar is unchanged (with the ugly icon..) I may add it to the status pane I am just not sure where..
Columns UI
Reply #5714
double-click on "total length" part of status bar, selected all playlist items
can that be added to status pane?
maybe at the number of items/length part?
Columns UI
Reply #5715
<dumb question>
How can I customize status panel?
</dumb question>
Item details panel inconvenience. When we set "display track" to currently selected fields concerning playback (e.g. %playback_time%, %_time_elapsed_seconds%, %_time_total_seconds%, %playback_time_remaining%, etc.) are not availible/displayed even if the currently selected track is being played (functionality I miss from foo_uie_trackinfo).
I would just like to see playback information without adding another panel with different track mode or enabling status pane.
Moderation: Merge requested.
Columns UI
Reply #5716
when using Album List, i can use buttons to perform actions on selections.
when using Filters, this is not possible.
can this be fixed?
example: i have a button to add selected tracks to my ipod. if i select an artist or album in the Album List, the button works. if i do the same in Filters, it does not.
Columns UI
Reply #5717
What do you mean by selecting in Album list?
Like you have auto-sending enabled, and when you click on a node it's items are added and selected in playlist view?
If that's the case, you can set filters to "Add" it's items to playlist so that they can be selected when directed in playlist view and context menu actions (your buttons) will be valid
Columns UI
Reply #5718
oh, now i understand.
i have both set to auto send, but Album List selects all, while Filters does not
Columns UI
Reply #5719
Whenever I update the columns ui layout (and press apply) the display becomes bugged. Each panel seems to get a gray empty area beneath it and there aren't any working grippers to resize them.
Example: http://img69.imageshack.us/img69/7771/cui1.png
This effect disappears when the playlist is re-rendered (e.g. resizing foobar, showing/hiding the status bar/pane).
Happens with 0.3.8.0 and 0.3.8.2.
Columns UI
Reply #5720
You'd be amazed how often "unlikely" things like this happen, especially when people are doing several things at once. At my day job I deal with databases at a call center, and I find lots of examples of people doing/clicking/entering strange things when they're on the phone. Same thing can happen when several people are in my room clicking through my music collection. I'd like to be able to prevent it as much as possible. I hope you can add an option to disable inline editing in Filter. After all, such an option exists for columns.
Columns UI
Reply #5721
having some problems with the new status pane. i was trying to decide which to use, switching back and forth a bit.
now, foobar has 'reserved' space for the status pane, no matter what i use. if i keep just the status bar, or if i turn everything off, the space is still there.
restarting foobar didn't solve the problem.
http://imgkk.com/i/5Upx4t.png
Columns UI
Reply #5724
thanks musicmusic, a locked splitter was to blame.
chiwou, if you mean the group headers in my playlist, well i cheated
i just found a character that looks similar to the line, and repeated it a few times...
