Topic: Columns UI (Read 3870167 times) previous topic - next topic
Columns UI
Reply #5400
$tab() does now work in group titles
FOR SURE??? Wohooo... have to update and try out right noooow
edit:
Well it works but that line which seperates the groups disappears. Is it possible to keep it in between?
And with the newest Version I don't see my stars and other special characters anymore!! ★♫▶ are only squares now
fb2k on OSX: flac q8 > rockboxed Sansa e280v1: Vorbis q5.0
Columns UI
Reply #5402
Well, why did it work before without a problem? And I still can see the icons in my titleformatting (no $char() string used)
Columns UI
Reply #5403
Ask whoever wrote the emulation/whatever software you are using..?
Columns UI
Reply #5404
Sry to bother... as I'm using it not on Windows I know that there are other things that might have an impact on this.
But since I didn't change anything besides your plugin and I know that you made some changes to the code regarding special characters I thought it could have something to do with it.
I'll try to fix it another way then...
But what about that seperation line, possible?
Columns UI
Reply #5406
Hi all.
I'm new to Columns UI and I'm almost done setting up my configuration for it, I just need some assistance with a few more things.
  • Where can I find a star ratings system? I see it in a lot of configurations but don't know where to find it.
  • How do I create tabs for switching between a Media Library, Playlist and whatever other display I want?
  • Am I able to make use of Global Hotkeys under the UI? If so, how?
  • What's the script that I need to input so that the grouping will display the disc number (Planetary Pieces: Sonic World Adventure Original Soundtrack -Disc 1-)?
I hope that this is the correct place to ask these questions. Thanks musicmusic for creating such an awesome UI, I'm really liking it.
Columns UI
Reply #5407
Thanks - I'm not sure I want to mess with any convoluted delayed reactions, as it would get quite complicated.
The main delay from generating the playlist is from sorting, if possible changing the script for it in Filter prefs can help. I may be able to use some tricks here to help (e.g. caching and things). I'll have a look if there is anything else I can do to speed things up for such large datasets.
$tab() does now work in group titles. Thank you very much, musicmusic. Alas the horizontal line disappears when $tab() is used. I guess I can't have everything though or is there something you can do?
Yes, I enabled it since it didn't seem to hurt.  As for the line, maybe, I didn't want to mess around with this for these releases but I may be able to make it work.
Columns UI
Reply #5408
What about simply enclosing the "All" item with parentheses instead? This way, you could safely type "A" and only ever hit "All" if you really wanted it (after all, how many artists have names beginning with a parenthesis?)
Columns UI
Reply #5409
Star Ratings in CUI Playlist:
File - Preferences - Display - Columns UI - Playlist view - Columns
(Scripts/Display section of a new column)
$repeat(?,%rating%)
Edit: I should mention that this method writes the ratings to the files. There is an official component that handles ratings and saves them to the database: http://www.foobar2000.org/?page=Download ("Playback Statistics")
Tabs: Use a Tab Stack:
*Right Click*
Insert panel - Splitters - Tab stack
Disc number:
[ -Disc %discnumber%-]
Columns UI
Reply #5410
Good idea. Talking of parentheses, I'd like to be able to assign to them a different color. I first saw that in the default UI component "Facets". Everything in brackets is gray there. It's a nice feature that helps speeding up the reading process.
Columns UI
Reply #5411
I'm running CUI 0.3.7.3 and Vista 64 SP2. It seems with new track notification balloon enabled, after getting my monitor locked and turn off by screensaver and power management. Sometimes I can't bring foobar back from the tray with double mouse clicks on the tray icon (likely after new track), had to use the keyboard shortcut. Please look into it.
The same problem occurs with the latest version, 0.3.7.8. This time, I'm pretty sure it happens whether foobar was playing music or not. So I don't think "Show popup notification balloons" has anything to do with it.
Columns UI
Reply #5412
Would it be possible to implement option "Don't display albumart when number of items in grup is less than X" (ideally - automatically check that height of all items in group is less than height of albumart and automatically disable it for that group) (:
Columns UI
Reply #5414
--- sorry if this has been asked before, I didn´t read the 217 pages of this thread ...  ---
I guess it´s not possible in NG Playlist to have a "footer" for each column to sum up values there like %length% or %size% (as you can do in the playlist switcher).
Don´t you think this would be a nice feature to add to future versions?
Columns UI
Reply #5415
I think so! Nice idea. I'd also like to see how many items one selected and how many are in the current playlist.
Columns UI
Reply #5416
Playlist Dropdown and Playlist switcher already have that ability, why not use them?
Columns UI
Reply #5417
@musicmusic: Are you ever going to implement a ratings column like in this WMP 12 screenshot where you can hover with the mouse and alter ratings with a single left click? I really prefer Columns UI's NG Playlist over ELPlaylist because of its much better performance, but I miss that feature. It's not too comfy having to enter values from 1 to 5 with keyboard keys for each song.
Columns UI
Reply #5418
Why not use Quick Tagger in order to rate your songs?  Then you can right-click one song or a whole group of songs and set the rating.  Maybe it's not quite the answer you're looking for, but it might be quicker than editing the rating with the keyboard.
Columns UI
Reply #5419
yes, that´s what I do now, but adding %size% AND %length% there produces a very big string and doesn´t look nice, whereas in NG playlist there would be needed one additional line to have it displayed clearly - just an idea...
Columns UI
Reply #5420
Since there is already information about the length of the selected items in the status bar, it might be a good idea to put any additional info concerning amount of selected/total tracks into the status bar as well.
Columns UI
Reply #5421
hmm, I don´t use the status bar, because it´s ugly, but of course to display it there makes sense for those who use it.
Just to be shure, my proposal was meant to add it to NG Playlist as an OPTION (like the column headers), so you don´t HAVE to use it there
Columns UI
Reply #5422
I need DUI's spectrum analyzer panel in CUI layout. How can I insert this panel to the layout?
Columns UI
Reply #5424
I tried this plugin. But I need EXACTLY the same appearence like in DUI plugin.
P.S. Sorry for my English
