Topic: Columns UI (Read 4610517 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
Columns UI
Reply #4800
what is NG Playlist? the wiki didnt show anything...neither did the columns ui page.
Columns UI
Reply #4801
i mean the grouping playlist
Columns UI
Reply #4802
Hi folks!
I´m playing with Columns UI, but i can´t view my embedded artwork of a single mp3 file.
I don´t know what source path i must use to view the embedded artwork of a single mp3 file (album artwork works like a charm).
Any one can give me a posible solution?
Thanks in advance, and sorry for my bad english
Columns UI
Reply #4803
Hi musicmusic,
With 0.9.6 the converter's context menus are blank on the command editing window for custom buttons. Otherwise it is working
EDIT: using foobar 0.9.6 b3, CUI 0.3.4.2, on DUI it is OK.
Columns UI
Reply #4804
Arrghh help! I've been playing around with a new layout, but I just went to change base from horizontal splitter to vertical, and all the panels below it have disappeared! If I click close it'll apply it, if I kill the foobar process I'll go back to my old layout! Ctrl-Z does nothing, am I completely screwed, will I have to start from scratch? How annoying! Plz help!
Columns UI
Reply #4805
Hi folks!
You mean a song from a single as opposed to an album? Where are you trying to display the artwork (playlist, or a dedicated panel, or...?)?
I added a fix for the next build.
Columns UI
Reply #4807
I'm having a little problem with my filters.  Two out of three are showing up blank every time I start foobar2000.  Resizing the horizontal splitter makes them pop into view.  I don't remember changing anything that would make this happen, I've updated to the latest 0.9.6 beta but that had no effect.  Any idea what could cause this?
Columns UI
Reply #4808
I had similar issues once. Updated display driver fixed it afair.
Columns UI
Reply #4809
Are you using the 64-bit version of Vista?
Columns UI
Reply #4810
Yes I am.
And it's interesting that you mention display drivers odyssey since I did update those recently, could've been when this started happening.
Columns UI
Reply #4811
is it possible to use Filter for any playlist, or can you only view the Filter Playlist when browsing with Filter?
I'm asking because I also use foo_dop for my ipod, and using Filter to browse my ipod media library would be SO nice!
Columns UI
Reply #4812
Yes I am.
Last time someone has drawing issues like this with the Filter Panel it was "that" Wow64 bug. If you disable programs that install a certain type of global hook (most common: Logitech Setpoint. Others include multiple display utilities, which have been included with display drivers in the past) it will go away if this is the problem. You can usually kill the relevant processes in task manager (and restart foobar2000) to test.
Columns UI
Reply #4813
Thanks, through process of elimination I found it was a program called IHateThisKey which disables the windows key when fullscreen games are running.
Columns UI
Reply #4814
Album List Panel 0.3.3 released. This should clear up the loose ends in 0.3.2. All settings should also now apply with the need for refresh tree or a restart, and item indices/sub-item counts should also update correctly with media library changes. Please report any issues here, thanks
Columns UI
Reply #4815
musicmusic, Thank you so much for all your hard work.
I love Columns UI. But, for me, it's still missing the "configurable splitters' size" feature. Any plans to implement this?
...You never replied to this question. Please...
Columns UI
Reply #4816
The separators? I don't have any particular objections, but limited time and whatnot, I can't really give a definite answer.
Columns UI
Reply #4817
Ok, first off, I'd like to say that so far, great work on columns UI, it's definitely making using foobar for me way easier, but I have a few problems so far. I have included an image for reference.
Columns UI
Reply #4818
1) I am wondering how I could create two different panels for two different playlists that are independent of each other. Meaning, I am trying to create a panel for a now playing queue where I could queue up songs to be played, much like on windows media player, etc. but when I add columns playlist under vertical splitter, it corresponds with the same playlist that I have selected on the left (in this case my library, or *browser*) which shows up in the main panel by default, and any time I make a change to one, it makes the same change in the other panel.
What you want is not possible, due to the nature of the foobar2000 core.
However, you can drag-and-drop single tracks out of the Media library, or append tracks from one playlist to another playlist by dragging and dropping the files onto a playlist tab or a playlist name in the playlist manager.
2) This is a slightly less important issue, and may just be a problem with me not knowing how to use foobar properly, but the grey arrow that is circled in blue (I drew it in as an example as I usually place it on the genre tab, which was too far to the right - didn't want to stretch out the page with the picture) for some reason keeps disappearing on startup and when I change my selection in the browser panels (above the blue line), which rearranges how I sort my music. How do you stop it from disappearing every time I change my selection in the browser panel?
Every time you select something in the browser panel, the results of your selection are sorted according to the default sort pattern (i think). You can change this with Preferences -> General -> Sort incoming files By...
elevatorladylevitateme
Columns UI
Reply #4819
That is, in fact, perfectly possible - any component is free to access any playlist at any time. Unfortunately as far as I know, all publicly available playlist viewers show only the "active playlist".
Columns UI
Reply #4820
Now that you mention it, I think maybe someone told me that before.
I'm going to bed.
Columns UI
Reply #4821
... can I change the name of the filter's autosend playlist?
... can I display songs with missing tags like browser panel does?
1. No.
2. I don't know what browser panel does, but you can make a separate item for tracks with a missing tag by filtering for $if2(%tagname%,<Missing>).
oh ok...but how do i use the ng playlist feature since playlist artwork only works with it?
Edit your layout in Preferences > Display > Columns UI > Layout, and add NG Playlist instead of Columns Playlist.
If you've never edited your layout, it's probably a good time to learn here.
Columns UI
Reply #4822
Yes I am.
This is no longer an issue in Vista. At least not for me.
Columns UI
Reply #4823
Columns UI 0.3.5.0 released. This adds a new item details panel, a title formatting based item info display.
Unfortunately, it seems to be for the other person. It may be an update to the software that was causing it for you stopped using the problematic type of global hook. Alternatively, it only affected panels below a certain splitter depth. There's hope for SP2, anyway.
Columns UI
Reply #4824
thank you musicmusic  i'll try it right now !
