Topic: Columns UI (Read 4608518 times) previous topic - next topic
0 Members and 8 Guests are viewing this topic.
Columns UI
Reply #3175
Does anyone know why I'm unable to load albumlist into the panel?
I'm stuck with foo_explorer which I personally dont like
Also, my display is:
Horizontal
|-Vertical
| |-explorer tree
| |-albumart
|--Column playlist
How can I put spectrum under the column playlist?
I'm not sure if I understand this question, but this might help
Results in:
exactly!! thanks a bunch
Columns UI
Reply #3177
defining a bunch of colors with a random function could also make something like that, but well, a playlist with too many colors is likely to be.. ugly.. as it is hard to find matching colors, and random colors makes the problem.. unsolvable
(and if you want  to use all possibilities, finding 2^31-1 colors is not that easy )
Columns UI
Reply #3178
is there a way to choose the font for text in buttons toolbar?
Columns UI
Reply #3179
Well, you can control the degree of colouration to a certain extent. You could make them all shades of the same colour, for example.
But yeah, i agree. I wish there was a way you could alternate between two colours for each album. That would rock my box.
amiti, it probably goes by the dialogue font defined in your visual style (which is changeable through Display Properties if you want to mess with it).
Columns UI
Reply #3180
How can I give the background of the first track of an album or disc a different colour? I tried and asked before but got no response and I can't get it to work. Do you have any idea what's going wrong or how it should be done?
Many thanks in advance.
Columns UI
Reply #3182
$ifequal(%tracknumber%,1,colorofthefirstline,other color)
Doesn't work, that's the whole problem. I figured it would be as simple as that as well. Instead I used:
if($strcmp(1,$num(%tracknumber%,1)),
$puts(back,$offset_colour(%_back%,$calculate_blend_target(%_back%),40))
$puts(back-selected,%_selected_back%)
$puts(back-selected-no-focus,%_selected_back_no_focus%)
I tried your suggestion as well, with and without fixed colours but no go.
Columns UI
Reply #3183
lav-chan , Do you mean windows visual style through display properties? i  tried this but it didn't have affect on foobar toolbars.
EDIT:
Sorry . it did work but only after i changed the icon font in the windows display properties.
Thanks for your help
Columns UI
Reply #3184
I tested something like that on a column, and it works
$set_style(text,$rgb(255,0,0),0)
$set_style(back,$ifequal(%tracknumber%,1,$rgb(255,255,255),$rgb(0,0,0)),0)
I could show you a picture but well, useless, be sure that it's not a missing ')' or something like that
Columns UI
Reply #3185
I hope folk don't mind me asking a newb question here. I've been using Foobar2000 for some time and have just recently decided to try Columns UI. My fist attempt went quite well, but I decided to start a fresh from scratch. I therefore deleted my custom layout, but now when I try to start with a blank window, I can't get rid of the menu, seek bar etc. I'm using the latest versions of Foo, and columns etc and even tried uninstalling/installing. All to no avail. Can someone please let me know how I can get that blank window again?
Columns UI
Reply #3189
Right click on the menu/buttons/seekbar you want to remove and use the little menu that appears.
Columns UI
Reply #3190
[request] about $put,$puts,$set_global.
I have already posted something here:
http://www.hydrogenaudio.org/forums/index....showtopic=44923
But having the ability to create variables both global and usable would be nice to avoid declaring variables twice. Once to use them, the other to make them global. (except if I have missed something)
Columns UI
Reply #3191
sorry for off-topic
can anyone point me in direction of track info thread ? somehow I can't find it
Columns UI
Reply #3193
I fixed this by unselecting "show toolbars" in Columns UI>Main>Miscellaneous.
I have another question, is it possible to have tabs or something similar in the Album panel? I want to have a seperate album list for lossless albums and lossy albums/
Thanks in advance
Columns UI
Reply #3194
So how exactly does one add an extra panel? As far as I can recall, right-clicking on the caption title would give me a menu that says 'panels' which would in turn allow me to select as many panels as I'd like. The columns ui wiki says the same thing; however, clicking on what I think is the 'caption title' gives me only the choices of 'show caption' 'lock panel' 'move up/down/' 'close panel'. I can't add album-list-panel.
Columns UI
Reply #3195
The layout system in the new version of Columns UI is different. See the Layout tab in Preferences.
Columns UI
Reply #3197
Is there a way to remove the Active item frame?
And if there is not, is it possible to implement it?
Columns UI
Reply #3198
weird resizing problem: look at the video:
http://eolindel.free.fr/images/bug.avi (3Mo)
two crashes by the way, but i don't know where it come from:
The first, when I desactivated the status bar
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 4EC83166h
Access violation, operation: write, address: 102FFC90h
Call path:
entry=>app_mainloop
Code bytes (4EC83166h):
4EC83126h:  8B EC 51 51 8B 45 0C 8B 40 24 53 56 57 89 55 F8
4EC83136h:  89 4D FC 89 45 0C 8B 4D 08 8B 5D 0C 8B 75 F8 8B
4EC83146h:  7D FC 0F EF FF 0F 6F 1D 10 EF CF 4E 8B 03 8B D0
4EC83156h:  C1 EA 18 83 FA 00 74 45 81 FA FF 00 00 00 75 04
4EC83166h:  89 07 EB 39 0F 6E E0 8B 06 0F 6E C0 0F 60 C7 81
4EC83176h:  F2 FF 00 00 00 0F 6E D2 0F 61 D2 0F 62 D2 0F D5
4EC83186h:  C2 0F FD C3 0F 7F C2 0F 71 D0 08 0F FD C2 0F 71
4EC83196h:  D0 08 0F 67 C0 0F FE C4 0F 7E C2 89 17 83 C7 04
Stack (0012EF74h):
0012EF54h:  00000000 00000000 0000000C BC715FC8
0012EF64h:  0012FAC0 00009CA1 B073BB64 B073BD38
0012EF74h:  01C12D78 01C12DB0 00000001 102FFC90
0012EF84h:  102FFC90 0012EFA4 4EC7AF5C 00000084
0012EF94h:  03DA0060 102FFC90 01C12D60 00000024
0012EFA4h:  0012EFFC 4EC73539 102FFC90 03DA0060
0012EFB4h:  00000084 00000024 00000173 00000000
0012EFC4h:  03DB0078 01C12D60 10130000 01C12D60
0012EFD4h:  10130000 00000004 00000000 00000000
0012EFE4h:  00000084 00000000 00000004 00000000
0012EFF4h:  00000024 03DA0060 0012F04C 4EC736E4
0012F004h:  00001400 03DA0048 03DA4DE8 00000024
0012F014h:  000000FD 00000024 000000FD 000000A8
0012F024h:  00000197 03DA0048 CC010FC7 01C12D60
0012F034h:  00000024 000000FD 00000024 000000FD
0012F044h:  00001400 00000173 0012F070 4EC7390B
0012F054h:  00000001 03DA0048 03DA4DE8 0012F474
0012F064h:  0000009A 01C12D60 03DA4DE8 0012F07C
0012F074h:  4EC73AA5 0012F124 0012F1DC 4EBD4A8F
0012F084h:  00000084 00000000 4EC7EADD 01C127F8
Registers:
EAX: FF000000, EBX: 03DA0060, ECX: 00000084, EDX: 000000FF
ESI: 102FFC90, EDI: 102FFC90, EBP: 0012EF88, ESP: 0012EF74
Crash location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004E0000h
ntdll                            loaded at 7C910000h - 7C9C7000h
kernel32                        loaded at 7C800000h - 7C904000h
COMCTL32                        loaded at 77390000h - 77492000h
msvcrt                          loaded at 77BE0000h - 77C38000h
ADVAPI32                        loaded at 77DA0000h - 77E4C000h
RPCRT4                          loaded at 77E50000h - 77EE1000h
GDI32                            loaded at 77EF0000h - 77F37000h
USER32                          loaded at 77D10000h - 77DA0000h
SHLWAPI                          loaded at 77F40000h - 77FB6000h
SHELL32                          loaded at 7C9D0000h - 7D1F3000h
ole32                            loaded at 774A0000h - 775DD000h
shared                          loaded at 10000000h - 1002A000h
comdlg32                        loaded at 76340000h - 7638A000h
uxtheme                          loaded at 5B090000h - 5B0C8000h
lgscroll                        loaded at 10100000h - 1010E000h
MSVCR71                          loaded at 7C340000h - 7C396000h
MSVCP71                          loaded at 7C3A0000h - 7C41B000h
foo_abx                          loaded at 00A10000h - 00A44000h
foo_albumlist                    loaded at 00A50000h - 00A91000h
foo_autoplaylist                loaded at 00AB0000h - 00AE2000h
foo_browser                      loaded at 00B10000h - 00B48000h
foo_cdda                        loaded at 00B70000h - 00B9D000h
foo_channel_mixer                loaded at 00BC0000h - 00BFA000h
foo_common                      loaded at 00C10000h - 00C49000h
foo_converter                    loaded at 00C70000h - 00CD1000h
foo_dbsearch                    loaded at 00D00000h - 00D59000h
foo_dsp_std                      loaded at 00D80000h - 00DBF000h
foo_freedb2                      loaded at 00DE0000h - 00E20000h
foo_input_shorten                loaded at 00E40000h - 00E6E000h
foo_input_std                    loaded at 00E90000h - 00FA3000h
foo_lnk                          loaded at 00FD0000h - 00FE9000h
foo_masstag                      loaded at 01010000h - 01060000h
foo_msnalt                      loaded at 01080000h - 01099000h
foo_playcount                    loaded at 010C0000h - 010E8000h
foo_rgscan                      loaded at 01110000h - 01154000h
foo_sic                          loaded at 01180000h - 011CB000h
WS2_32                          loaded at 719F0000h - 71A07000h
WS2HELP                          loaded at 719E0000h - 719E8000h
foo_uie_albumart                loaded at 01230000h - 01260000h
gdiplus                          loaded at 4EB80000h - 4ED23000h
foo_uie_console                  loaded at 01290000h - 012AC000h
foo_uie_explorer                loaded at 012D0000h - 0130D000h
foo_uie_trackinfo                loaded at 01330000h - 0135E000h
foo_ui_columns                  loaded at 01380000h - 0141B000h
foo_ui_std                      loaded at 01440000h - 01497000h
foo_unpack                      loaded at 014C0000h - 014EE000h
foo_utils                        loaded at 01510000h - 01549000h
CLBCATQ                          loaded at 76F80000h - 76FFF000h
COMRes                          loaded at 77000000h - 770D4000h
OLEAUT32                        loaded at 770E0000h - 7716C000h
VERSION                          loaded at 77BD0000h - 77BD8000h
SETUPAPI                        loaded at 778E0000h - 779D8000h
appHelp                          loaded at 77B50000h - 77B72000h
cscui                            loaded at 765B0000h - 76606000h
CSCDLL                          loaded at 76590000h - 765AD000h
DSOUND                          loaded at 73E60000h - 73EBC000h
WINMM                            loaded at 76AE0000h - 76B0F000h
wdmaud                          loaded at 72C70000h - 72C79000h
WINTRUST                        loaded at 76BE0000h - 76C0E000h
CRYPT32                          loaded at 779E0000h - 77A76000h
MSASN1                          loaded at 77A80000h - 77A92000h
IMAGEHLP                        loaded at 76C40000h - 76C68000h
msacm32                          loaded at 72C60000h - 72C68000h
MSACM32                          loaded at 77BB0000h - 77BC5000h
midimap                          loaded at 77BA0000h - 77BA7000h
KsUser                          loaded at 73E30000h - 73E34000h
browseui                        loaded at 75F10000h - 7600D000h
ntshrui                          loaded at 76930000h - 76956000h
ATL                              loaded at 76AC0000h - 76AD1000h
NETAPI32                        loaded at 6FEE0000h - 6FF34000h
USERENV                          loaded at 76960000h - 76A15000h
shdocvw                          loaded at 77720000h - 7788E000h
CRYPTUI                          loaded at 76610000h - 76694000h
WININET                          loaded at 77AA0000h - 77B47000h
WLDAP32                          loaded at 76F10000h - 76F3D000h
xpsp2res                        loaded at 20000000h - 202DA000h
MPR                              loaded at 71A60000h - 71A72000h
drprov                          loaded at 75EF0000h - 75EF7000h
ntlanman                        loaded at 71B70000h - 71B7E000h
NETUI0                          loaded at 71C30000h - 71C47000h
NETUI1                          loaded at 71BF0000h - 71C30000h
NETRAP                          loaded at 71BE0000h - 71BE7000h
SAMLIB                          loaded at 71B50000h - 71B63000h
davclnt                          loaded at 75F00000h - 75F09000h
shgina                          loaded at 73CC0000h - 73CD3000h
MSGINA                          loaded at 75900000h - 759F9000h
WINSTA                          loaded at 762F0000h - 76300000h
ODBC32                          loaded at 74730000h - 7476D000h
odbcint                          loaded at 029B0000h - 029C8000h
Secur32                          loaded at 77FC0000h - 77FD1000h
Audiodev                        loaded at 092D0000h - 0934A000h
WMVCore                          loaded at 02E90000h - 030D6000h
WMASF                            loaded at 070D0000h - 0710A000h
dciman32                        loaded at 73B10000h - 73B16000h
DBGHELP                          loaded at 5D3F0000h - 5D491000h
Stack dump analysis:
Address: 4EC7AF5Ch, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EC73539h, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EC736E4h, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EC7390Bh, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EC73AA5h, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EBD4A8Fh, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EC7EADDh, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 77D40467h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 77D1B3B0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 77D1B3A7h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 77D1C331h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "SetRectEmpty" (+0000004Fh)
Address: 77D240B3h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "PrivateExtractIconExW" (+000001D8h)
Address: 77D241E2h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 4EC7397Bh, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EB81580h, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EC8A61Eh, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EBEC0BCh, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EBC49FAh, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 7C920F46h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+000004B7h)
Address: 0045322Ah, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 5B091AF6h, location: "uxtheme", loaded at 5B090000h - 5B0C8000h
Address: 0101F428h, location: "foo_masstag", loaded at 01010000h - 01060000h
Address: 7C91EE18h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "strchr" (+00000117h)
Address: 5B094D8Dh, location: "uxtheme", loaded at 5B090000h - 5B0C8000h
Symbol: "Ordinal44" (+0000016Dh)
Address: 77D18734h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D1D074h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "EnumDisplayMonitors" (+00000111h)
Address: 77D18BD9h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 77D1885Ah, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+00000193h)
Address: 77D1882Ah, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+00000163h)
Address: 7C920732h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 77D1EAF2h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "EnableMenuItem" (+000000C3h)
Address: 7C920738h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C9206ABh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C9206EBh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 012594DCh, location: "foo_uie_albumart", loaded at 01230000h - 01260000h
Address: 10106A10h, location: "lgscroll", loaded at 10100000h - 1010E000h
Symbol: "UninstallScrollHooks" (+00000B30h)
Address: 77D1DABDh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "IsWindowInDestroy" (+00000049h)
Address: 77D1DADFh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "IsWindowInDestroy" (+0000006Bh)
Address: 0133A155h, location: "foo_uie_trackinfo", loaded at 01330000h - 0135E000h
Address: 4EBED505h, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EBD4FE8h, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EB875A4h, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EBD6A81h, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EBA68EBh, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EBBBE3Bh, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Symbol: "GdipDrawImage" (+000000AEh)
Address: 4EBBBEB6h, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Symbol: "GdipDrawImageI" (+00000028h)
Address: 01237525h, location: "foo_uie_albumart", loaded at 01230000h - 01260000h
Address: 77D1B3CCh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000090h)
Address: 013A65AFh, location: "foo_ui_columns", loaded at 01380000h - 0141B000h
Address: 77D70088h, location: "USER32", loaded at 77D10000h - 77DA0000h
Address: 004703DEh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 77D1EB3Eh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "CallNextHookEx" (+0000003Bh)
Address: 77D1BF58h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "SetCursor" (+00000000h)
Address: 10106FCAh, location: "lgscroll", loaded at 10100000h - 1010E000h
Symbol: "UninstallScrollHooks" (+000010EAh)
Address: 0124A186h, location: "foo_uie_albumart", loaded at 01230000h - 01260000h
Address: 01235ADCh, location: "foo_uie_albumart", loaded at 01230000h - 01260000h
Address: 77D188D1h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 77D188DAh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 01235750h, location: "foo_uie_albumart", loaded at 01230000h - 01260000h
Address: 0124A700h, location: "foo_uie_albumart", loaded at 01230000h - 01260000h
Address: 01235794h, location: "foo_uie_albumart", loaded at 01230000h - 01260000h
Address: 77D18816h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D18830h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+00000169h)
Address: 77D1B4C0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 77D1EA9Eh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "EnableMenuItem" (+0000006Fh)
Address: 77D1B4D0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 77D1B50Ch, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 77D1EBF3h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "CallNextHookEx" (+000000F0h)
Address: 7C91EAE3h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 77D1B473h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 77D194D2h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongA" (+00000075h)
Address: 77D1B530h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+000001F4h)
Address: 004CC810h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004AF0D4h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 77D189F0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 77D18A10h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 0042B63Ah, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 77D1DAEAh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 0042C0C0h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004AF7ACh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 7C920E12h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+00000383h)
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004B20F8h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004D11C0h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 7C921538h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C921596h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+00000B07h)
Address: 004D12A0h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004A48E4h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 7C920570h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 7C92056Dh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C927CB7h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlReAllocateHeap" (+000002BAh)
Address: 7C927BF5h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlReAllocateHeap" (+000001F8h)
Address: 7C927BB0h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlReAllocateHeap" (+000001B3h)
Address: 1000D533h, location: "shared", loaded at 10000000h - 1002A000h
Address: 1000D469h, location: "shared", loaded at 10000000h - 1002A000h
Address: 10003C90h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "t_font_description::g_from_font" (+00000030h)
Address: 10003C9Eh, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "t_font_description::g_from_font" (+0000003Eh)
Address: 7C921B09h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlLogStackBackTrace" (+00000025h)
Address: 004D1230h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00483574h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 7C9206F0h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 0048991Fh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00488720h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004B05C8h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 10002D77h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000B7h)
Address: 0049F7FBh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 0042C29Ah, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004CE2A8h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00489035h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00483409h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00483403h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004A48E8h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 004A3045h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 0049F9EFh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 00487605h, location: "foobar2000", loaded at 00400000h - 004E0000h
Version info:
foobar2000 v0.9.1
UNICODE
Additional info:
FLAC decoder 1.1.0  (foo_input_std)
Console panel 0.2  (foo_uie_console)
Channel Mixer 0.9.4  (foo_channel_mixer)
Columns UI 0.1.3 beta 1v5  (foo_ui_columns)
Album Art Panel 0.164a  (foo_uie_albumart)
Common services 0.1  (foo_common)
Play Count 1.9.2  (foo_playcount)
freedb tagger v0.5  (foo_freedb2)
RAR reader 1.1  (foo_unpack)
foosic music database 1.0 beta 7  (foo_sic)
Standard DSP array 1.0  (foo_dsp_std)
Converter 1.0  (foo_converter)
CD Audio decoder 2.0  (foo_cdda)
Shorten decoder 0.4.2a  (foo_input_shorten)
MSN Now Playing (alt) 2.4  (foo_msnalt)
Album List 3.2.0  (foo_albumlist)
Default User Interface 0.9acc  (foo_ui_std)
Masstagger 1.5  (foo_masstag)
MPEG-4 AAC decoder 2.1  (foo_input_std)
Shell link resolver 1.1  (foo_lnk)
ReplayGain Scanner 2.0  (foo_rgscan)
Explorer Tree 1.04.6a  (foo_uie_explorer)
Database search 1.3.1 beta 10  (foo_dbsearch)
Track info panel 0.8  (foo_uie_trackinfo)
ABX comparator 1.3  (foo_abx)
ZIP/GZIP reader 1.0  (foo_unpack)
Music Browser 1.1.2 [Apr  3 2006 - 16:51:34]  (foo_browser)
Standard input array 1.0  (foo_input_std)
Playlist tools 0.5.5  (foo_utils)
The other when I was doing something with my trackinfo panel:
Illegal operation:
Access violation, operation: write, address: 103C5994h
Call path:
entry=>app_mainloop
Stack (0012EED8h):
0012EEB8h:  00000000 00000000 0000000C BC6DEC80
0012EEC8h:  0012FAC0 00009CA1 A61E9B64 A61E9D38
0012EED8h:  018D2D78 018D2DB0 00000001 103C5994
0012EEE8h:  103C5994 0012EF08 4EC7AF5C 00000159
0012EEF8h:  02A20060 103C5994 018D2D60 00000165
0012EF08h:  0012EF60 4EC73539 103C5994 02A20060
0012EF18h:  00000159 00000165 00000211 00000000
0012EF28h:  02A30078 018D2D60 10130000 018D2D60
0012EF38h:  10130000 00000004 00000000 00000000
0012EF48h:  00000159 00000000 00000004 00000000
0012EF58h:  00000165 02A20060 0012EFB0 4EC736E4
0012EF68h:  00001400 02A20048 02A2FD48 00000165
0012EF78h:  00000211 00000165 00000211 000002BE
0012EF88h:  00000369 02A20048 08010FD2 018D2D60
0012EF98h:  00000165 00000211 00000165 00000211
0012EFA8h:  00001400 00000211 0012EFD4 4EC7390B
0012EFB8h:  00000001 02A20048 02A2FD48 018D2D60
0012EFC8h:  018D2D60 02A2FD48 02A2FD48 0012EFE8
0012EFD8h:  4EC73A44 00000159 0012F124 00000159
0012EFE8h:  0012F00C 4EBD4536 00000000 0000002E
Registers:
EAX: FF000000, EBX: 02A20060, ECX: 00000159, EDX: 000000FF
ESI: 103C5994, EDI: 103C5994, EBP: 0012EEEC, ESP: 0012EED8
Loaded modules:
Address: 4EC73A44h, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EBD4536h, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EC7763Fh, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EC0D5BAh, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EC7B8F7h, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 4EC7EAB0h, location: "gdiplus", loaded at 4EB80000h - 4ED23000h
Address: 5B09153Dh, location: "uxtheme", loaded at 5B090000h - 5B0C8000h
Address: 773B3B41h, location: "COMCTL32", loaded at 77390000h - 77492000h
Symbol: "Ordinal384" (+00007D17h)
Address: 01336F74h, location: "foo_uie_trackinfo", loaded at 01330000h - 0135E000h
Address: 7C921E75h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlInitializeCriticalSection" (+00000348h)
Address: 7C920D5Ch, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+000002CDh)
Address: 01018720h, location: "foo_masstag", loaded at 01010000h - 01060000h
Address: 0101310Eh, location: "foo_masstag", loaded at 01010000h - 01060000h
Address: 0048312Dh, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 01016130h, location: "foo_masstag", loaded at 01010000h - 01060000h
Address: 00413C45h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 0049EDD6h, location: "foobar2000", loaded at 00400000h - 004E0000h
Address: 01334121h, location: "foo_uie_trackinfo", loaded at 01330000h - 0135E000h
Address: 77D18B26h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 01387220h, location: "foo_ui_columns", loaded at 01380000h - 0141B000h
Version info:
foobar2000 v0.9.1
UNICODE
Additional info:
Columns UI
Reply #3199
Thanks in advance
Are you talking about Album List?
You can sort your albums inside Album List. Add a new view with this code:
$info(encoding)|%artist%|%album%|%tracknumber%. %title%
It's not exatly the thing you wanted, but it's kinda close
