Originally posted by Hanky
I played around with the ultralowbitrate clips and I was quite amazed. In some of them there was quite a lot of signalclipping (I did not activate the hard-limiter in the decoder). So I decided to run vorbisgain on the files.
This was one of the results:
D:vorbisbackupultralowbitrate>vorbisgain *.ogg
Processing directory '.':
Analyzing files...
Gain | Peak | Scale | New Peak | Track
-11.45 dB | 51988 | 0.27 | 13912 | scar.ogg
-1.29 dB | 25355 | 0.86 | 21856 | ss.ogg
+0.72 dB | 27163 | 1.09 | 29511 | queen.ogg
-7.17 dB | 43151 | 0.44 | 18901 | waitress.ogg
-7.12 dB | 52190 | 0.44 | 22993 | daan.ogg
Couldn't initialize gain analysis (nonstandard samplerate?) for 'scarres4.ogg'
Does this mean that 6kHz sampling rate does not comply to the standard or is Vorbisgain wrong here ?
I use Vorbisgain 0.32 dated 2002-07-24 from RareWares
Replaygain (so also Vorbisgain) has some precomputed weighting filters.
They exist for the following frequencies:
8, 11.025, 12
16, 22.05, 24
32, 44.1, 48 kHz
// for each filter:
// [0] 48 kHz, [1] 44.1 kHz, [2] 32 kHz, [3] 24 kHz, [4] 22050 Hz, [5] 16 kHz, [6] 12 kHz, [7] is 11025 Hz, [8] 8 kHz
const Float_t AYule [9] [11] = {
{ 1., -3.84664617118067, 7.81501653005538,-11.34170355132042, 13.05504219327545,-12.28759895145294, 9.48293806319790, -5.87257861775999, 2.75465861874613, -0.86984376593551, 0.13919314567432 },
{ 1., -3.47845948550071, 6.36317777566148, -8.54751527471874, 9.47693607801280, -8.81498681370155, 6.85401540936998, -4.39470996079559, 2.19611684890774, -0.75104302451432, 0.13149317958808 },
{ 1., -2.37898834973084, 2.84868151156327, -2.64577170229825, 2.23697657451713, -1.67148153367602, 1.00595954808547, -0.45953458054983, 0.16378164858596, -0.05032077717131, 0.02347897407020 },
{ 1., -1.61273165137247, 1.07977492259970, -0.25656257754070, -0.16276719120440, -0.22638893773906, 0.39120800788284, -0.22138138954925, 0.04500235387352, 0.02005851806501, 0.00302439095741 },
{ 1., -1.49858979367799, 0.87350271418188, 0.12205022308084, -0.80774944671438, 0.47854794562326, -0.12453458140019, -0.04067510197014, 0.08333755284107, -0.04237348025746, 0.02977207319925 },
{ 1., -0.62820619233671, 0.29661783706366, -0.37256372942400, 0.00213767857124, -0.42029820170918, 0.22199650564824, 0.00613424350682, 0.06747620744683, 0.05784820375801, 0.03222754072173 },
{ 1., -1.04800335126349, 0.29156311971249, -0.26806001042947, 0.00819999645858, 0.45054734505008, -0.33032403314006, 0.06739368333110, -0.04784254229033, 0.01639907836189, 0.01807364323573 },
{ 1., -0.51035327095184, -0.31863563325245, -0.20256413484477, 0.14728154134330, 0.38952639978999, -0.23313271880868, -0.05246019024463, -0.02505961724053, 0.02442357316099, 0.01818801111503 },
{ 1., -0.25049871956020, -0.43193942311114, -0.03424681017675, -0.04678328784242, 0.26408300200955, 0.15113130533216, -0.17556493366449, -0.18823009262115, 0.05477720428674, 0.04704409688120 }
const Float_t BYule [9] [11] = {
{ 0.03857599435200, -0.02160367184185, -0.00123395316851, -0.00009291677959, -0.01655260341619, 0.02161526843274, -0.02074045215285, 0.00594298065125, 0.00306428023191, 0.00012025322027, 0.00288463683916 },
{ 0.05418656406430, -0.02911007808948, -0.00848709379851, -0.00851165645469, -0.00834990904936, 0.02245293253339, -0.02596338512915, 0.01624864962975, -0.00240879051584, 0.00674613682247, -0.00187763777362 },
{ 0.15457299681924, -0.09331049056315, -0.06247880153653, 0.02163541888798, -0.05588393329856, 0.04781476674921, 0.00222312597743, 0.03174092540049, -0.01390589421898, 0.00651420667831, -0.00881362733839 },
{ 0.30296907319327, -0.22613988682123, -0.08587323730772, 0.03282930172664, -0.00915702933434, -0.02364141202522, -0.00584456039913, 0.06276101321749, -0.00000828086748, 0.00205861885564, -0.02950134983287 },
{ 0.33642304856132, -0.25572241425570, -0.11828570177555, 0.11921148675203, -0.07834489609479, -0.00469977914380, -0.00589500224440, 0.05724228140351, 0.00832043980773, -0.01635381384540, -0.01760176568150 },
{ 0.44915256608450, -0.14351757464547, -0.22784394429749, -0.01419140100551, 0.04078262797139, -0.12398163381748, 0.04097565135648, 0.10478503600251, -0.01863887810927, -0.03193428438915, 0.00541907748707 },
{ 0.56619470757641, -0.75464456939302, 0.16242137742230, 0.16744243493672, -0.18901604199609, 0.30931782841830, -0.27562961986224, 0.00647310677246, 0.08647503780351, -0.03788984554840, -0.00588215443421 },
{ 0.58100494960553, -0.53174909058578, -0.14289799034253, 0.17520704835522, 0.02377945217615, 0.15558449135573, -0.25344790059353, 0.01628462406333, 0.06920467763959, -0.03721611395801, -0.00749618797172 },
{ 0.53648789255105, -0.42163034350696, -0.00275953611929, 0.04267842219415, -0.10214864179676, 0.14590772289388, -0.02459864859345, -0.11202315195388, -0.04060034127000, 0.04788665548180, -0.02217936801134 }
const Float_t AButter [9] [3] = {
{ 1., -1.97223372919527, 0.97261396931306 },
{ 1., -1.96977855582618, 0.97022847566350 },
{ 1., -1.95835380975398, 0.95920349965459 },
{ 1., -1.95002759149878, 0.95124613669835 },
{ 1., -1.94561023566527, 0.94705070426118 },
{ 1., -1.92783286977036, 0.93034775234268 },
{ 1., -1.91858953033784, 0.92177618768381 },
{ 1., -1.91542108074780, 0.91885558323625 },
{ 1., -1.88903307939452, 0.89487434461664 }
const Float_t BButter [9] [3] = {
{ 0.98621192462708, -1.97242384925416, 0.98621192462708 },
{ 0.98500175787242, -1.97000351574484, 0.98500175787242 },
{ 0.97938932735214, -1.95877865470428, 0.97938932735214 },
{ 0.97531843204928, -1.95063686409857, 0.97531843204928 },
{ 0.97316523498161, -1.94633046996323, 0.97316523498161 },
{ 0.96454515552826, -1.92909031105652, 0.96454515552826 },
{ 0.96009142950541, -1.92018285901082, 0.96009142950541 },
{ 0.95856916599601, -1.91713833199203, 0.95856916599601 },
{ 0.94597685600279, -1.89195371200558, 0.94597685600279 }
