Topic: WavPack playback on linux? (Read 3126 times) previous topic - next topic
My windows computers have no problem playing wavpack files, but what can play them on linux?  I haven't been able to figure it out since there are no libs.  Sorry if this is a dumb question.
[a href="index.php?act=findpost&pid=236592"][{POST_SNAPBACK}][/a]
Alley_cat, a long time supporter of the matroska project, has recently coded a TTA plugin for Gstreamer. You might ask him about a Wavpack plugin also. He is often on
#matroska, irc.corecodec.com , and #gstreamer irc.freenode.net ....
Until you get a plugin for your favorite media player, you can write a little script to use the command line tools.
You ought to have a command called 'wavplay' or 'play' on Linux. Look for a program called 'audioplay' on the *BSDs
plug this command into a little script:
#!/bin/sh
# wvplay - play wavpack on command line
for file in "$@"; do
    echo "np: $file"
    wvunpack "$file" - | wavplay -
done
and then
$ wvplay *.wv
There's also a bash script that Speek created here (I'm not sure what the difference is between the two):
http://www.hydrogenaudio.org/forums/index....ndpost&p=222550
Obviously, an XMMS plugin would be ideal. I may be able to do this with a friend who does a lot of development on Linux, but I'm not sure when that might happen. In the meantime anyone is welcome to take the WavPack library and try to do this...
[a href="index.php?act=findpost&pid=236827"][{POST_SNAPBACK}][/a]
There is a xmms-meta-input plugin.
This plugin allows you to write XMMS plugins as Unix programs.
I write a wavpack script and put it in the /usr/lib/xmms/Input/Meta.
Therefore, xmms can play *.wv, but it can't seek music.
However, it's a solution before bryant release the real xmms-plugin.
#!/bin/sh
case "$1" in
play)
wvunpack -q "$2" -
exit 0
isOurFile)
if echo "$2" | grep -q \.[wW][vV];then
exit 0
else
exit -1
fi
esac
exit -1
