Topic: Lossless : stop the madness. (Read 8628 times) previous topic - next topic
When I stopped encoding with lossy to go lossless, I thought : "cool! there won't be any question about quality or transcoding, etc... The Hydrogen forum about lossless must be empty! I'm gonna sleep well"
NNNNNNNNNOOOOOOOOOOOOOOOOOOOOO !!!!
Even here, people are crazy and fight about everything.
What's the fuck????????????
I have a question : I'm using Monkey (fast mode) because I want to get LOSSLESS files, can I sleep peacefully or have I to compare every codec, every preset.......
Sleep in peace. You're safe.
If you like Monkey, use Monkey. I like FLAC, but that is what I like and I'm not willing to convince you to do so.
Most of the time, differences in size aren't whortwhile.
Two bald men, fighting over a comb...
This is HA, we can *always* find something to argue about .
Monkey is great if you're a Windows user.
If you're not a Windows user, then it's less great. Now the source is available, it is possible to compile it under *nix, although not very many people have done so.
If you're mainly a Unix user, and use lossless, then you're almost certainly using FLAC. It's the most cross-platform of all the lossless formats. The downside is that it doesn't compress as well, or as quickly, as Monkey does.
As long as you're either using Monkey or FLAC, then you're okay. They're the only decent lossless formats out there at the moment.
Congratulations, you have just approached to a prox to null compression ratio just...
      ...to sleep peacefully?
Leave the files as WAV.
lame --alt-preset superman --wont-sleep
"Taking a jazz approach and concentrating on live playing, I wanted to use several different rhythm sections and vintage instruments and amps to create a timeless sound that's geared more around musicality and vibe than sonic perfection. The key was to write with specific rhythm sections in mind, yet leave open spaces for soloing." Lee Ritenour
I've got a better idea : Audiocatalyst 128
I should have thought about it before, it is written "cd-quality"
Just another question : It is possible that lossless compress really more in the future or will there only be minors changes?
Which codecs have the most active devellopment?
Yeah, the situation is weird. You can change your codec preference as many times as you want and not loose a bit of information and yet there is so much emotion involved. I remember the days when people argued about codec sound quality. Thanks to lossless compression that's history so we have to fight over something else or we would all live in harmony. Insert smilies to your liking.
Oh! for God's love, no... WMA at 48kbps is labeled as "cd-quality" by Microsoft, but i know better.
Again, if you can encode losslessly 5 CDs into 3CDs, that is fine for me.
If there are any compression improvements, they will probably be minimal. I would believe Monkey's Audio is already nearing the limit of best possible compression.
Monkey's Audio, probably. (Specially because Frank Klemm is helping to develop it)
Followed by Flac.
40% average compression is very satisfactory for me.
Yeah sure, I known it has ~1/2 average, but with such cutting-edge technology like MP3, AAC, Vorbis & Co that brings the minimal compression concept to a least 1/8...
...for non archivial/testing needs Is lossless worth it?
What's the convenience to burn 2 audio CDs into into 1 FLAC compressed CD (incompatible with hardware players), instead of 2 specular audio CDs playable anywhere ?
...you already said why: for archiving. I use FLAC for that, vorbis for eveything else...
...but i will never use again lossy formats for backup.
Error correction...
Backup!
You do backups to store them safely, not to play them anywhere.
And, when you are storing, the less space you use to perform it, the better. So, storing one CD instead of two equals to 50% of space efficiency - you can store twice the CDs in the same place.
And no, lossy simply won't do for backup. At least IMO.
Regards;
Roberto.
I'm more scared of backup medium, not process.
Don't burned cd's have a life of 60-some years and then die on you?
How long do, say, OnStream or DAT tapes last? I'd be more adept to backing up on tape.. as I trust all my data to my OnStream drive.
Is there a medium (not vinyl--hehe) that can be stored away and not deteriorate to uselessness?
Sure in 20 years I'll archive that archive, but still, now with stories of some CDR's falling apart extremely soon, I'm not sure what to trust my most sensitive data to.. For now I'm sticking with my tape drive.
-r
Originally posted by rjamorim
Backup!
Regards;
Roberto.
Backing up 2x on to the same medium you backed up from sounds like suicide to me
yeah, this is why servers usually don't have harddisks in raid arrays - too dangerous for the data
You simply aren't getting my point.
The backup would be used if something happens with the original media. If it gets lost, stolen, it breaks in two, gets too scratched...
Then, you run to your safe and gets the backup, burn it in CD-DA format, and store the backup in the safe again.
*lol*
you can buy 4 identically hd's and an PCI raid controller. 2 disks in use. 2 disks in cellar for archiving.
if you go with raid2 and one disk crashes, you can replace the disk without losing data.
raid0 = 50% data on each disk, double speed but 100% save.
raid2 = 100% data on each disk, single speed but 200% save.
edit: if you run a unix box you can replace one hd without an reboot. just umount, replace, mount, and your beast is ready for you.
Dezibel
There's a useful table  HERE for the longevity of various media.
Note the effects of humidity and temperature - the freezer seems a better place for you back-ups than the safe
ß
That feature is called "Hotswap" and requires hardware support... Unix is hardly the only OS capable of that, just so you know... But as I said, you need the apropriate hardware for that or you'll likely end up killing your harddrive as you "yank" out the cables from it while it's running...
P.S. The soon to be released S-ATA interface will allow hotswapping without any special hardware...
*lol*
you can buy 4 identically hd's ....
that's about the point i wanted to make. you did note the sarcasm, didn't you?
I hadn't said it here yet so I will say it now.
Lossless is the only codec I will use on my recorded tracks because I will never find a another recording of the music played.
As for improving compression, you should see what Monkey's does for the bass guitar tracks with RMS -28dB to -24dB and background noise below -78dB -- it gets about 88% reduction. Not bad considering the audio data is completely intact.
edit: incorrect info can kill sometimes
I sometimes go lossless for four reasons/purposes:
1. Backup of my most valuable music or oldest cd:s. My rare cd:s from mid 80:s and beginning of 90:s are already beginning to get those horrible holes of erosion. Rescue while there is still time.
2. Backup of my live recordings from dat or md.
3. You will have a much safer store on a cd-r than an audio-cd due to the error correction.
4. No matter what will happen with the lossy formats in the coming decades - transcode from lossless to any device will be easier than grabbing the cd:s again and again.
For no other reason than OS compatibility - I use FLAC. Speed, a few bits more here and there are not a big issue.
Emanuel
Emanuel
Same here...  "It's the only way to go"...
