Topic: Speex ist 0.5.1 (Read 3311 times) previous topic - next topic
Speex ist 0.5.1
http://speex.sf.net
Notes: This release brings quality improvements at very low bit-rate (5.7 kbps) and a new post-filter. VBR should also be a bit better though there's still a lot to do. Most of the modes are bit-rate compatible with 0.5.0, with the exception of the very low bit-rate (which is sometimes used in VBR, so expect some glitches). The source (and probably binary) compatibility with 0.5.0 is maintained.
Speex ist 0.5.1
I think this codec would be great to try on vast amount of stuff I have with comedy, interviews, and a bunch of talk-radio type material. Any chance there will be news of a Windows binary before it shows up in Ogg Vorbis? Right now I have a hunch it won't compile with my Borland C++ 3.0.
Speex ist 0.5.1
The sources are too Linux-oriented. Porting them to Windows at the moment would require lots of modifications, that probably wouldn't work in the next release.
Besides, stream compatibility is being broken each new version, so it's not really worth to start encoding now.
Regards;
Roberto.
