Topic: Req: Random pic display plugin/vis (Read 2649 times) previous topic - next topic
One of the cool plugins for WMP is one where you can set a path, and the vis will cycle through the pics in the directory randomly. I was wondering if anyone could create a similar thing for fb2k. I'm not sure if this would fit in better with foo_looks or with a separate vis plugin. I tried looking for a Winamp plugin to use with vis_bacon but I couldn't find one. All I found were just cover art displays.
What for, Gemini? Do you want to have a porn slide show viewer while you're listening to your music?
(in this case JensRex' suggestion should work just fine for you )
[a href="index.php?act=findpost&pid=233928"][{POST_SNAPBACK}][/a]
Hahaha, as a matter of fact....
I remember using ACDSee a couple years ago. I was hoping to have something related to the music player, since it would start/stop with a song. After upgrading to XP, I haven't found the need for ACDSee, since it has a built-in image viewer.
a slideshow-vis with beat-detection would be cool (i.e. the speed and timing at which the images rotate is influenced by the beat of the music - of course this wouldn't work with all kinds of music)
- Lyx
