Topic: About Monkey : can i get mono files (Read 2850 times) previous topic - next topic
Hello
I'm compressing a lot of lot of old mono records and it's a waste of hard disk space to compress them with 2 channels.
Is there any way to tell Monkey Audio to compress just the right or the left channel?
If not, is there another lossless codec that make it?
it will compress mono stuff as mono (well practically speaking, the compression will be far greater - just as lossy encoders with lossless stereo coupling).
I suggest you read this: http://www.monkeysaudio.com/theory.html
btw.: even though the source says that it's mono it not always the case totally.
I suggest you try both with mono and stereo on your mono material then....
Then if there's no big difference stick with stereo.
