Topic: aac 4 linux? (Read 4838 times) previous topic - next topic
aac 4 linux?
does anyone use aac on linux?
which encoder?
...decoder?
...[xmms] plugin?
which license is used in the different aac encoders?
is there an freeware, gpl, bsd... licensed aac encoder?
Dezibel
aac 4 linux?
I never got any AAC decoder working on Linux, so I gave up.
GCP
aac 4 linux?
hm,
sounds not good. is the sound quality much more better than mpc at bitrates 180 - 260 kbs?
Dezibel
aac 4 linux?
Yes. FAAC.
www.audiocoding.com
Quality isn't on par with Psytel AACenc, though.
You can find FAAD (open-source decoder) at audiocoding too.
Regards;
Roberto.
@Garf:
I don't know much about linux, but seems someone found out why FAAD doesn't compiles well on it:
http://www.audiocoding.com/phorum/read.php?f=1&i=1745&t=1737
Regards;
Roberto.
aac 4 linux?
Both are transparent on most cases at these bitrates.
aac 4 linux?
thx so far...
...try out this stuff tomorrow.
good night
Dezibel
aac 4 linux?
This is correct, but what Roberto is avoiding to say here, is that MPC is the leader of the pack at these bitrates. :listen:
aac 4 linux?
Also, I wouldn't recommend using FAAC for serious encoding.  The quality usually isn't even as good as LAME.
MPC is your best bet for high quality (moderate bitrate) encoding on Linux.
Btw, you could probably get PsyTEL AAC to work via Wine though I haven't tried it myself.
aac 4 linux?
You should really put an IMO somewhere there, Nika.
aac 4 linux?
It's a proven fact, IMO.  And my name's not Nika. :eek:
aac 4 linux?
Yes. FAAC.
www.audiocoding.com
Roberto.
FAAC is not usable for archiving. Quality was always below Lame MP3
quality. Some samples were also not transparent at 512 kbps,
where Lame worked well with ca. 240 kbps.
FAAD works well.
The only way to encode AAC under Linux is Wine+Psytel AAC.
But there are also a lot of improvements possible with Psytel AAC
at bitrates around 128 kbps. Encoding with 192 kbps should be secure
for most samples.
--  Frank Klemm
aac 4 linux?
@Garf:
The problem has got nothing to do with libc. The problem is that whoever put the source package together was so clueless as to be a mistake of the Gods to be born. I recommend that this person be battered to death and run over a few times, or the hands cut off, or if neither is possible, (s)he is put in a mental institute and not allowed to within 500 metres of anything that could be programmable anymore again.
And now I'm being nice, even.
GCP
aac 4 linux?
Sorry, Niko. Hit the wrong key.
