For the perfectionnist, what about offset detection,
Ah, yes I forgot to go into details about that. Thanks.
CD text,
Another reminder, thanks again.
gap settings for the cuesheet ?
Right, when you are extracting a whole image that follows automatically, does it not? Or did I forget to include that setting?
Test or not ?
Test of what, exactly? But perhaps I should have postet the second part of my "guide" as well, here we go:
2. RIPPING
2.1 Wipe your CD thoroughly in a radial motion before extraction, using a moist, non-flossing, fine-fibered cloth (such as can be bought for wiping glasses).
2.2. Start ripping your original copy of a compact-disc audio CD at the speed arrived at in 1.2., set in EAC as described in 1.3., by pressing ALT+F7, which copies an image (wav-file) to your harddisk.
If you detect any errors (a row of "lights" in the user-interface light up), stop ripping the CD, and either:
2.2.1 Try another original copy of the CD.
2.2.2 Do not rip the CD
The only exeption to this, is if only the first row lights up, and it happens at the end of the CD, reading into the LEAD-OUT area due to the adjustment of offsets.
You should test that the CD is actually error-free, using another program (such as plextools), also at the constant speed arrived at in 1.2., before you conclude that this is the case.
You now have a CD-image on your harddisk (single wav-file), which you can encode using your favourite lossless encoder. This guide will explain how to use flac.
Accurate rip ?
I am assuming you are referring to the "Accurate-rip" website. I see no reason for having any confidence in that endeavour.
If Plextor drives are considered, why not Plextools instead of EAC ?
Heh. The lowest setting of plextools is "stop ripping after 100 or more errors", which is 100 errors too many. Also, I don't want to limit the "guide" to plextor drives only, and I may well tone down the references to that brand along the way.
Also, the advice of searching another drive if C2 accuracy is <99.9 % is not good. A big scratch can make the most accurate drive loose a lot of C2 reportings if DAEquality fails to synch some intermediate damaged and misplaced parts of audio.
Ah, thanks, I am mostly concerned with factual errors at this time. However, looking at my now include "part 2", considering the approach of "if errors then stop", would it not be safe to assume that if there was a big scratch, errors would show up?
Thanks for your input Pio!
