FLAC 1.1.1-beta1 released
Reply #33 – 2004-08-02 19:46:49
XIPH conception of tag is different of mine ; I need something else than poor and limited informations alla freedb. Other lossless and lossy formats allow this for a long time, and the use of tags with these formats is not enfeoff to the will of one developer. It's a real asset for tags located at the end of the stream. You're mixing metaphors with freedb. I answered to kjoonlee argument, which was according to him a quotation of Xiph.org recommandation: "Vorbis comments are for short comments, such as what you would scribble on a CD-R " ...and so are freedb tags: elementary informations. I think that I have the right to use the tagging system for something else, and to associate consequent informations to an audio files. It works with all audio files around there, without problem. Only exceptions are maybe the "totally free" vorbis and flac format.Other formats may put tags on the end, but the only one that does and plays outside of a PC is MP3 with ID3v1, which is very simple Did you ever heard the name of iPod? Curiously, MP4 tags associated to M4A files generated by iTunes are located on the end. Doesn't seems to be a problem for manufacturer like Apple.What you want requires compromises that are not acceptable for a general purpose codec. Could you then explain me why OptimFROG, WavPack, TTA, MPC, etc... have accepted this "unacceptable" compromise? It sounds to me like a simple feature rather than a compromise or something like that.I'm not sure what you meant by 'enfeoff' but it's not the will of one developer any more than is your request the demand of one user. I suppose that the lossless "streaming" argument, which is the main justification of tags located at the beginning of a file, is also something very popular on this board Tags will stay the way they are in FLAC . I'll see... I'm just surprised that flac officially or semi-officially supports two similar tagging system, which both have the same advantages and the same flaws.
