Topic: FLAC 1.1.1-beta1 released (Read 35521 times) previous topic - next topic
Since it's been so long since the last FLAC release I wanted to have at least one beta before FLAC 1.1.1 comes out.  The usual warning applies: do not use for archival.
The number of changes, fixes, and additions is pretty large.  The current changelog can be dug out of CVS:
http://cvs.sourceforge.net/viewcvs.py/*che...og.html?rev=1.4
Some of the big stuff:
- seeking support in Ogg FLAC, including seekable encoder/decoder interfaces
- callback-based metadata editing (that one's just for you Peter!)
- decoding speed optimizations for PPC thanks to Brady Patterson.  decoding speed on OS X almost doubled.
- many fixes and a lot of new options people have asked for
Things that are still missing:
- final Ogg FLAC bitstream mapping is not quite finished yet, so it's OK to make streams for testing but they might have to be converted with official flac 1.1.1 later to be streamable in ogg tools
- some pending fixes to winamp2 plugins
I have not published the release to the FLAC site.  For downloads go to the sourceforge download page:
http://sourceforge.net/project/showfiles.php?group_id=13478
For this release I have broken up the win32 binary release into two.  The normal one just has binaries/docs and the -dev one has the libraries/DLLs, include files, and API docs.  The other platform binary releases have only flac/metaflac and basic docs since it's much more common to build them from source anyway, or get RPM/Debian/Fink packages.
I ask you all to beat it up and let me know what you find.
Thanks,
Josh
Great news. Just in time for my new 200GB hard drive
flac > schiit modi > schiit magni > hd650
Any change in compression ratio?
No plan for adding a another tagging format (like APEv2, in order to avoid slowness of tag editing or the waste of space introduced by padding)?
[{POST_SNAPBACK}][/a]
Yet another way to tag FLAC == bad. [a href="http://www.hydrogenaudio.org/forums/index.php?showtopic=24581]There is enough mess in this area already.[/url]
Optional backwards-compatible padding of comment block for fast updates == good.
padding is not always sufficient (i.e. when the amount of additionnal datas are really big).
I could imagine that three tagging format is a messy situation, but the two available tagging system are both located on the beginning, which is not the most conveniant place for the basic user (for streaming, it's another story).
For me, it's the worse aspect of flac :/
[a href="index.php?act=findpost&pid=230697"][{POST_SNAPBACK}][/a]
I've noticed that when batch-tagging a lot of FLAC files, it can take a long time, and the hard drive really churns. Is this the reason why?
Does Wavpack handle this differently?
Wavpack uses APEv2 tags, which are written at the end of the file, hence the file does not have to be rewritten completely on tag-updates.
Make sure you add enough padding (--padding=4096 is generally considered sufficient for most users - it's FLAC's default setting) when encoding FLACs.
No, there probably won't be any major compression improvements without breaking forward compatibility (i.e. old decoders still being able to decode it).  I think stability of the format is more important than a few % more compression.  FLAC is making more inroads into distribution and hardware and the stability and low decode complexity are major factors in that.
No.  Tags at the front are better for streaming.  Judicious use of padding almost always makes file rewrites unnecessary.  A few extra K of padding in a multimegabyte file is not much of a waste.
The winamp2 plugin's tag updating does not take care of padding very well though; that's on the TODO list to fix.
Josh
pardon my ignorance, but who is gona stream a FLAC file? ... they are at bet 40% of a WAV ... or i'm missing something?
This tagging issue is not a big issue. normal flac files are large enough so that I always add 32kbyte padding. It is not even noticable. And I am a keen tag user, but this size was always enough. (OT: At the same time I yet to see large number of SW which can display my multiline metadata. Foobar is an exception.)
I definitely wish for simplicity. Id3v2 is enough eyesore to me in FLAC. I'd say now that FLAC is under Xiph umbrella it should use Vorbis tags only and not have yet another tagging system. There are already a number of newbies confused by the presence of 2 tagging.
Thanks Josh for your good work.
Triza
[a href="index.php?act=findpost&pid=230716"][{POST_SNAPBACK}][/a]
The same people who will stream DVDs and HDTV with VLS and VLC?
Any chance we could ever see something like
flac -d --split-by-cue Album.flac
to decode a file and split it by internal cuesheet?
Eric
jeje ... i can't even stream Mp3's on my ADSL connection .. :|
I think it may prove useful in home networks, which have more than enough bandwidth.
Actually ID3v2 is not a part of FLAC.  Some plugins support ID3v2 on FLAC for convenience but it's not required.
That's a nice idea, but will probably also need some way of specifiying how the files should be named.
You can already do this with flac --cue in a little script, i.e. get the # of tracks with, say
metaflac --list file.flac | awk '/number of tracks:/ { print $4 }'
and then do 'flac -d --cue=...' for each one.
Josh
sorry, but, why can't we have a 2 modes stadard, at the front for streaming, and at the end for normal ... and ay yhe front it would be some flag telling the decoder what mode are we using?
It's just that padding is a waste of space. If I really want to be sure to have enough padded space, I need something like 32 or 64 kb/file. It's my usage of tags, at least for some files. On a big library, the amount of padded information could be important: 200...500 MB. I know that HD storage is cheap nowadays, by this kind of waste is specific to flac: OptimFROG, WavPack, TTA, Monkey's Audio offer a more convieniant tagging system.
I uploaded foobar2000 flac decoder which was updated to use new callback based tag editing and OggFLAC tagging was fixed. Thanks JC for the much needed library update.
But why? What does it do that the current setup (with padding) cannot accomplish?
[a href="index.php?act=findpost&pid=230757"][{POST_SNAPBACK}][/a]
cause when you change a tag, you could end up rewriting all the file ... like in ogg
What kind of information do you add to the tags that you need 32-64kB padding?
May I ask what are the pending Winamp plugin fixes?
[a href="index.php?act=findpost&pid=230943"][{POST_SNAPBACK}][/a]
Could be a ripping (EAC) log file, a complete review or article about the composition, the  full libretto, etc...
I have a feature request here, which apparently hasn't been considered for the new version.
Please save away all the metadata chunks in WAV files along with the audio.
Without support for saving away data like that, Flac cannot be used to archive audio in the professional broadcast and film range, which will usualy be in the Broadcast WAV format, which just adds a bunch of chunks to the file.
Flac skips this stuff atm, thereby destroying all the information contained within. This information includes timecode values and various forms of descriptions. Virtualy all the recent audio database software uses meta data in Broadcast WAVs to store information on the specific sound, which it then integrates in to its databases. To rebuild the database in case of loss these applications simpy scans all the Broadcast WAVs for metadata.
Please don't "Skip" all this information. It renders Flac invisible to the professional audio world.
My profound thanks for Flac, regardless.
Tony
Wildcard support for windows is not working yet.
I thought it would be added on the next version (this version  )
[a href="index.php?act=findpost&pid=230949"][{POST_SNAPBACK}][/a]
Just my 2 cents, but you should look in to Matroska if you are storing that much extra data. I've been using it for flac images + log files, cover art, etc. It works out very well esp with foobar as the player.
Eric
