Topic: No subwoofer output with foobar2000 (Read 6757 times) previous topic - next topic
i have just installed a subwoofer into my computer. now i have 2 speakers + 1 subwoofer hooked up. when playing mp3s thru WMP i can hear the bass from the sub and also from playing dvds thru powerdvd.
but when i play my mp3s thru foobar the 2 speakers are the only ones being used and not with the sub. how do i fix this?
i setup my sub where it is connected directly into a dedicated line.
is it something to do with ac3 output?
thanks
Try adding the "Convert stereo to 4 channels" DSP - then it should come out of the sub.
[a href="index.php?act=findpost&pid=227973"][{POST_SNAPBACK}][/a]
i've tried that but there is still no sound coming out. i tried frequency divider but dont know how to configure it
Which one do you use as your output method, DirectSound or waveOut?
Have you tried turning hardware mixing on/off for DirectSound?
[a href="index.php?act=findpost&pid=227988"][{POST_SNAPBACK}][/a]
THANKS SO MUCH. i changed it to output "DirectSound 2.0" and changed my device to my soundcard and allow Hardware mixing.
now it works
thanks ppl
