The problem has been around for a while but it's realy starting to bug me now.
If I drag audio files into the playlist when "Shuffle album 2" is activated and foobar is playing the program crashes every once and a while.
I'm unable to reproduce the crash everytime I want to but it apears that the fastest way I getting it to crash is by playing a file, moving the seekbar almost to the end of the track, wait till the next song starts to play and drag in some audio files in the active playlist.
It won't crash every time but if it doesn't crash after the first or second attempt it will definitely do so after the third try.
I've got two different logs of this problem:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00A6C0AEh
Access violation, operation: read, address: 00000010h
Call path:
playback_core_i::g_thread_func=>playback_core_i::thread_func=>input::seek::run
Code bytes (00A6C0AEh):
00A6C06Eh: 79 6C 00 00 8B F0 85 F6 75 CE 5E C9 C3 8B C6 EB
00A6C07Eh: F9 56 8B F1 8B 4E 04 85 C9 74 08 8B 01 FF 10 83
00A6C08Eh: 66 04 00 5E C3 8B 49 04 85 C9 74 05 8B 01 FF 60
00A6C09Eh: 0C C3 8B 49 04 85 C9 75 05 32 C0 C2 0C 00 8B 01
00A6C0AEh: FF 60 10 B8 90 FD AC 00 C3 56 8B F1 57 8D 46 08
00A6C0BEh: 50 E8 46 6C 00 00 8B F8 59 85 FF 75 18 85 F6 74
00A6C0CEh: 14 8B CE C7 06 B8 3A AB 00 E8 A3 FF FF FF 56 E8
00A6C0DEh: 52 68 04 00 59 8B C7 5F 5E C3 83 C1 08 51 E8 0E
Stack (0157FDE4h):
0157FDC4h: 80559E66 8237E3A8 00000007 81ED5008
0157FDD4h: F3478CF0 00000007 80534504 82124F3C
0157FDE4h: 00A68604 00E40018 00000343 00E44018
0157FDF4h: 10001DE2 00F7F0C0 00F7F00C 8237E3B0
0157FE04h: 81F37978 805ABBC8 E11DF1A0 00000000
0157FE14h: 0157FD00 7FFDC000 0157FE74 00169300
0157FE24h: 0000000E 0157FE68 00169300 00000010
0157FE34h: 0157FE78 10001E6D 00169346 0044410C
0157FE44h: 00000010 10001DE2 0157FE74 10001E17
0157FE54h: 00000343 0157FE78 00437974 0157FED8
0157FE64h: 00000000 00F7F008 0041F4CB 00F7F00C
0157FE74h: 0000003C 0157FFA4 00420225 0157FED8
0157FE84h: 00CD03B8 00F7F008 00F7F008 00439908
0157FE94h: 0043997C 00F7F440 00000000 DA740DA7
0157FEA4h: 4071F740 00BD1FD0 00000020 0000001C
0157FEB4h: 00000001 00439974 00439960 00F8F9F0
0157FEC4h: 00000040 00000024 00000001 00439974
0157FED4h: 00439960 0043B09C 00F90008 00004807
0157FEE4h: 00004807 00000000 00F90008 00000000
0157FEF4h: 00000000 00000000 0043AF90 00000000
Registers:
EAX: 00000000, EBX: 00000000, ECX: 00F7BC98, EDX: 00E40018
ESI: 00E40008, EDI: 00E44018, EBP: 0157FE58, ESP: 0157FDE4
Crash location: "foo_input_std", loaded at 00A60000h - 00B02000h
Loaded modules:
foobar2000 loaded at 00400000h - 00452000h
ntdll loaded at 77F50000h - 77FF7000h
kernel32 loaded at 77E60000h - 77F46000h
USER32 loaded at 77D40000h - 77DCC000h
GDI32 loaded at 7E090000h - 7E0D1000h
ADVAPI32 loaded at 77DD0000h - 77E5D000h
RPCRT4 loaded at 78000000h - 78087000h
ole32 loaded at 771B0000h - 772D4000h
COMCTL32 loaded at 71950000h - 71A34000h
msvcrt loaded at 77C10000h - 77C63000h
SHLWAPI loaded at 70A70000h - 70AD5000h
utf8api loaded at 10000000h - 1000D000h
comdlg32 loaded at 763B0000h - 763F5000h
SHELL32 loaded at 773D0000h - 77BCA000h
foo_ape loaded at 008D0000h - 008F0000h
foo_audioscrobbler loaded at 008F0000h - 00910000h
LIBCURL loaded at 00910000h - 00929000h
WS2_32 loaded at 71AB0000h - 71AC5000h
WS2HELP loaded at 71AA0000h - 71AA8000h
WINMM loaded at 76B40000h - 76B6C000h
foo_cdda loaded at 009C0000h - 009CE000h
foo_clienc loaded at 009D0000h - 009DB000h
foo_console loaded at 009E0000h - 009E7000h
foo_diskwriter loaded at 009F0000h - 00A02000h
foo_flac loaded at 00A10000h - 00A26000h
foo_id3v2 loaded at 00A30000h - 00A60000h
MSVCP60 loaded at 55900000h - 55961000h
foo_input_std loaded at 00A60000h - 00B02000h
MSACM32 loaded at 77BE0000h - 77BF4000h
foo_masstag loaded at 00B10000h - 00B21000h
foo_output_std loaded at 00B30000h - 00B39000h
foo_rgscan loaded at 00B40000h - 00B4B000h
foo_shuffle loaded at 00B50000h - 00B5A000h
foo_ui_std loaded at 00B60000h - 00B77000h
foo_vis_manager loaded at 00B80000h - 00B88000h
foo_wma loaded at 00B90000h - 00BA9000h
WMVCore loaded at 08530000h - 0872D000h
WMASF loaded at 07260000h - 07299000h
OLEAUT32 loaded at 77120000h - 771AB000h
RTSUltraMonHook loaded at 00CB0000h - 00CDE000h
UxTheme loaded at 5AD70000h - 5ADA4000h
RTSUltraMonHookRes loaded at 01370000h - 01373000h
CAPTLIB loaded at 01580000h - 015E3000h
mswsock loaded at 71A50000h - 71A8B000h
DNSAPI loaded at 76F20000h - 76F45000h
winrnr loaded at 76FB0000h - 76FB7000h
WLDAP32 loaded at 76F60000h - 76F8C000h
dsound loaded at 51080000h - 510DA000h
VERSION loaded at 77C00000h - 77C07000h
wdmaud loaded at 72D20000h - 72D29000h
rasadhlp loaded at 76FC0000h - 76FC5000h
wshtcpip loaded at 71A90000h - 71A98000h
msacm32 loaded at 72D10000h - 72D18000h
midimap loaded at 77BD0000h - 77BD7000h
KsUser loaded at 5EF80000h - 5EF84000h
imagehlp loaded at 76C90000h - 76CB2000h
DBGHELP loaded at 6D510000h - 6D58D000h
Stack dump analysis:
Address: 00A68604h, location: "foo_input_std", loaded at 00A60000h - 00B02000h
Address: 10001DE2h, location: "utf8api", loaded at 10000000h - 1000D000h
Symbol: "uCallStackTracker::uCallStackTracker" (+00000000h)
Address: 10001E6Dh, location: "utf8api", loaded at 10000000h - 1000D000h
Symbol: "uCallStackTracker::uCallStackTracker" (+0000008Bh)
Address: 0044410Ch, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 10001E17h, location: "utf8api", loaded at 10000000h - 1000D000h
Symbol: "uCallStackTracker::uCallStackTracker" (+00000035h)
Address: 00437974h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0041F4CBh, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00420225h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00CD03B8h, location: "RTSUltraMonHook", loaded at 00CB0000h - 00CDE000h
Address: 00439908h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043997Ch, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00439974h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00439960h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043B09Ch, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043AF90h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043AFB8h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043AFA4h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 004205D8h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 77E7D33Bh, location: "kernel32", loaded at 77E60000h - 77F46000h
Symbol: "RegisterWaitForInputIdle" (+00000043h)
Address: 77E94809h, location: "kernel32", loaded at 77E60000h - 77F46000h
Symbol: "SetThreadExecutionState" (+00000097h)
Address: 77E83DB8h, location: "kernel32", loaded at 77E60000h - 77F46000h
Symbol: "OpenConsoleW" (+00001966h)
Address: 004205A9h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00905A4Dh, location: "foo_audioscrobbler", loaded at 008F0000h - 00910000h
Address: 10000000h, location: "utf8api", loaded at 10000000h - 1000D000h
Version info:
foobar2000 v0.8.2
UNICODE
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00B81674h
Access violation, operation: read, address: 00000020h
Call path:
WinMain=>app_mainloop=>playlist_callback::on_items_added
Code bytes (00B81674h):
00B81634h: B8 00 E8 A6 0C 00 00 B9 84 51 B8 00 E8 A6 0B 00
00B81644h: 00 B9 5C 51 B8 00 E8 51 0B 00 00 80 3D 28 52 B8
00B81654h: 00 00 74 0C E8 D5 06 00 00 80 25 28 52 B8 00 00
00B81664h: 8B 0D B0 51 B8 00 85 C9 0F 84 53 01 00 00 8B 01
00B81674h: FF 50 20 84 C0 0F 84 46 01 00 00 8B 0D B0 51 B8
00B81684h: 00 8B 01 FF 50 40 DD 5D F0 33 F6 F7 05 4C 51 B8
00B81694h: 00 FC FF FF FF 76 22 A1 44 51 B8 00 51 DD 45 F0
00B816A4h: 51 8B 0C B0 DD 1C 24 E8 2A 02 00 00 A1 4C 51 B8
Stack (0012FDC0h):
0012FDA0h: F4798D64 0012FEBC BF87BCA8 00000286
0012FDB0h: 804F6732 E156D860 000025BF 00000000
0012FDC0h: 0012FE4C 00B815CE 0012FE84 00000001
0012FDD0h: 0012FDBC 005C0073 0012FE04 77D43A50
0012FDE0h: 000E02C6 00000113 0000029A 00000000
0012FDF0h: 00B815CE DCBAABCD 00000000 0012FE4C
0012FE00h: 00B815CE 0012FE6C 77D43B1F 00B815CE
0012FE10h: 000E02C6 00000113 0000029A 00000000
0012FE20h: 0012FF00 0012FEF8 005C1440 00480020
0012FE30h: 00000000 00000000 00000014 00000001
0012FE40h: 00000000 00000000 00000010 00000000
0012FE50h: 00000000 0012FE20 0012F9E8 0012FEBC
0012FE60h: 77D7390A 77D99B68 00000000 0012FECC
0012FE70h: 77D43D79 00000000 00B815CE 000E02C6
0012FE80h: 00000113 0000029A 00000000 005C1454
0012FE90h: 00000001 00000001 00000001 00000000
0012FEA0h: 00000001 0000029A 77D43C01 00000000
0012FEB0h: 00000000 0012FE94 0012F9E8 0012FFB0
0012FEC0h: 77D7390A 77D99B88 FFFFFFFF 0012FF18
0012FED0h: 77D43DDF 0012FEF8 00000000 100038EC
Registers:
EAX: 00000000, EBX: 00000000, ECX: 00F7F008, EDX: 00B8522C
ESI: 000E02C6, EDI: 00B8522C, EBP: 0012FDD8, ESP: 0012FDC0
Crash location: "foo_vis_manager", loaded at 00B80000h - 00B88000h
Loaded modules:
Address: 00B815CEh, location: "foo_vis_manager", loaded at 00B80000h - 00B88000h
Address: 77D43A50h, location: "USER32", loaded at 77D40000h - 77DCC000h
Address: 77D43B1Fh, location: "USER32", loaded at 77D40000h - 77DCC000h
Address: 77D7390Ah, location: "USER32", loaded at 77D40000h - 77DCC000h
Symbol: "CreateAcceleratorTableA" (+0000032Dh)
Address: 77D99B68h, location: "USER32", loaded at 77D40000h - 77DCC000h
Address: 77D43D79h, location: "USER32", loaded at 77D40000h - 77DCC000h
Symbol: "GetMessageW" (+00000125h)
Address: 77D43C01h, location: "USER32", loaded at 77D40000h - 77DCC000h
Address: 77D99B88h, location: "USER32", loaded at 77D40000h - 77DCC000h
Address: 77D43DDFh, location: "USER32", loaded at 77D40000h - 77DCC000h
Symbol: "DispatchMessageW" (+0000000Bh)
Address: 100038ECh, location: "utf8api", loaded at 10000000h - 1000D000h
Symbol: "uDispatchMessage" (+0000000Ah)
Address: 0041247Dh, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 70A71A39h, location: "SHLWAPI", loaded at 70A70000h - 70AD5000h
Symbol: "Ordinal125" (+0000002Bh)
Address: 004110DCh, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00438D25h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00438D50h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043C320h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 77E814C7h, location: "kernel32", loaded at 77E60000h - 77F46000h
Symbol: "GetCurrentDirectoryW" (+00000044h)
Address: 77E91210h, location: "kernel32", loaded at 77E60000h - 77F46000h
Symbol: "OpenConsoleW" (+0000EDBEh)
Address: 00438BF1h, location: "foobar2000", loaded at 00400000h - 00452000h
Version info:
foobar2000 v0.8.2
UNICODE
OS: WinXP (Sp1)
foobar2000: 0.8.2
foo_shuffle: 1.0.24
