Topic: Signal above digital full scale (Read 3333 times) previous topic - next topic
Here is a picture of a signal where the true "analogue" peaks lie between samples...
David.
Yes, and if you use an application such as Adobe Audition to increase the sampling rate there will be samples above 0dB in a 32 bit file, or distorted peaks in a 16 bit file. I actually dealt with this in some detail in the old Syntrillium forum a year or two ago.
This has implications for the designers of CD players. One hopes they are aware the effect and allow the necessary headroom. What about oversampling players? Do they actually create the necessary samples above 0dB?
Alan
Alan
Nice picture. Is this in reference to a particular thread or query? If so, could you post a link.
I would certainly hope so. If the engineer knew what they were doing then they should be aware that there can be peaks in the analogue signal higher than digital 0dB.
Most consumer CD players seem to lowpass at 20kHz. As this effect drops off extremely quickly as you move away from the Nyquist frequency it shouldn't make a big difference to the analogue stage.
btw, the effect doesn't have to reduce as you go much below nyquist - the image I posted shows a sine wave at half nyquist, i.e. fs/4.
David.
[a href="index.php?act=findpost&pid=227791"][{POST_SNAPBACK}][/a]
Oh, right, I suppose it doesn't. It does drop off very quickly after the nyquist limit, but then goes up again near (Fs/2^n). I have attached a graph showing exactly what effect this has, if anybody is interested. What the graph shows is the ratio of max sample to signal peak versus sampling frequency. The wave is a 1024Hz sinusoid and the Nyquist limit is at 512Hz.
