Topic: Problem with foo_continuator and volume (Read 2570 times) previous topic - next topic
I have recently installed foo_dsp_continuator and when I try to change the volume it doesn't change after  more or less 1 sec (as it used to be), but it takes something about 5-7 seconds to hear the different level. When I remove continuator plugin the problem disappears.
Why is that?? Please help me because I really like this plugin.
Think? Why think! We have computers to do that for us. :P
Continuator creates a buffer of audio (see Playback/Status Display) to do its work.  If you're changing the volume inside of FB2K, the delay is due to the fact that Volume Control is in the DSP chain.  Changes in volume are delayed by this buffer before you hear them.
[a href="index.php?act=findpost&pid=226563"][{POST_SNAPBACK}][/a]
Put continuator at the top &  the Volume control at the bottom of the DSP chain. That should fix it.
Thanks a lot rectangle, it helped!!! Foobar focks :]
