Topic: Burning a CD with FLAC (file per song) (Read 2615 times) previous topic - next topic
I am ripping my CD's using EAC and encoding to FLAC.  I am ripping a file per song/track.  I also create a cue sheet for the CD at extraction (using gaps appended to previous track).  So I end up with a flac file for each individual song as well as a cue sheet for the CD. This is working well.
My confusion is the best way to now burn a CD that would be an exact copy of the original.  How would this best be done in EAC?  I assume that I would convert each flac file back to a wav file (I would use Foobar).  Now that I have each track as a wav file what do I do next and how do I utilize the cue file?  Please walk me through the process using EAC.
In addition, is there a better way to do this using a different burn program?  Again I am looking to make an exact copy and have a cue sheet that was generated in EAC using gaps appended
Am I missing something or doing something wrong?  I considered ripping as as single file, but prefer file per song track and want to figure out how to best make that work.
Thanks in advance!
I highly recommend using Burrn (burrrn.net), a simple little program that allows you to make exact copies of a CD from CUE sheets.  I use the EAC non-compliant CUE sheets and it works very well.
It supports almost any file type and does all of the conversion back to WAV automatically.  very, very easy...
Do a search here for "burrrn" for more info...
-Aaron
Thanks Aaron,
I will look into it.  Does it matter if it is file per track or single file (image)?  Have you used Burrrn with file per track and a cue file?
- Andy
Thanks Aaron,
- Andy
[a href="index.php?act=findpost&pid=224182"][{POST_SNAPBACK}][/a]
I have used Burrrn with both file per track and cue AND single image file with cue. Both work great.
