Topic: EAC command line options for FLAC (Read 3783 times) previous topic - next topic
I am encoding to FLAC with EAC, but I would like to increase the amount of compression.  I know that I need to add -8 in the command line, but I'm not sure where.  These are my current command line options:
-T "artist=%a" -T "title=%t" -T "album=%g" -T "date=%y" -T "tracknumber=%n" -T "genre=%m" %s
Where should the -8 go (if this is indeed correct to get the maximum compression)?
-Neuron
--best %s -T title="%t" -T artist="%a" -T date="%Y" -T genre="%m" -T album="%g" -T tracknumber="%n" -T libid="CALU"
EAC095pb5, LAME3.98, freedb, flac 1.2.1, fb2k 0.9.5
Thanks.  I notice that you have put title before artist.  Is that necessary?  Also, I'm getting  a "can't open input file"  error with --best added to my options.
What is libid="CALU"?
Looks to me like a custom tag for library ID ... not necessary for encoding
Here's mine...
%s -6 -T "artist=%a" -T "title=%t" -T "album=%g" -T "comment=EAC: flac 1.1>" -T "genre=%m" -T "date=%y" -T "tracknumber=%n"
xen-uno
edit: ...and order after %s -6 shouldn't matter
PS: Does anyone have a CL for ape's using 3.99 w/ ape2 tags?
No one can be told what Ogg Vorbis is...you have to hear it for yourself
- Morpheus
Here's mine. Works great. --best is the same as -8.
--best -T "artist=%a" -T "title=%t" -T "album=%g" -T "date=%y" -T "tracknumber=%n" -T "genre=%m" %s
Monkey's Audio with APEv2 tags (requires wapet):
3. Set file extension to .ape
4. Locate 'wapet.exe'
5. Use command line %d -t "Artist=%a" -t "Title=%t" -t "Album=%g" -t "Year=%y" -t "Track=%n" -t "Genre=%m" mac.exe %s %d -c4000
note: if mac.exe isn't in search path you need to specify full path for it.
Quoted from...
http://www.saunalahti.fi/~cse/EAC/index.html
Here's mine...
Works great.  thanks
