Topic: apply replaygain (Read 2386 times) previous topic - next topic
apply replaygain
I want to make a program to get track replaygain from a .wav...
How can I calcul it in dB?
For a wav @44100Hz and 16bits per sample (stereo), after the 56th byte (wav header), each 1 of 2 is left byte and right byte?
... DB FD DA FD 5F FD 5F FD ...
Left channel is coding with byte in bold?
apply replaygain
WaveGain already does this, but you d/l the code from Rarewares  'Others' page if you want to see how it's done.
apply replaygain
I want to program it, to understand very good how it works precisely...
Else I use foobar2000...
Is WaveGain opensource?
apply replaygain
Just a hint, in case you missed what john33 said (looks like you did..):
[span style='font-size:12pt;line-height:100%']d/l the code from Rarewares  'Others' page if you want to see how it's done. [/span]
(emphasis mine )
apply replaygain
(emphasis mine )
Arf yes, thanks
I read too fast, and I'm not english, so I didn't understand all
