Topic: listening test at 160 kbps (Read 74620 times) previous topic - next topic
Reply #75
question about vorbis megamix
between q 1 to q 2 and between q 4 to q 5 (e.g. q 1.50 and q 4.75) , what tuning encoder is chosen?
q 1 to q 2 -> aoTuV beta 2? QuantumKnot tune beta 3.2 + aoTuV beta 2? or both marge?
q 4 to q 5 -> QuantumKnot tune beta 3.2 + aoTuV beta 2? Galf Tuned 3 beta 2 + aoTuV beta 2? or both marge?
between q 1 and 2, I expect it to be partial QKTune with the full tunings coming into effect at 2.  Same for q 4 to 5 as well (partial QKTune, partial GT3b2).
Reply #76
So, is it safe to assume that the new Vorbis Megamix can be used outside of testing?
Reply #77
i understood.
thank you, QuantumKnot. you are great!!!!
<name>madoka</name>
Reply #78
I think more listening tests on a range of q values would be needed as Vorbis Megamix may still regress in some ranges for some samples.    But if you feel adventurous, you can always try it (on stuff that you can re-encode later if needed)
Reply #79
I've finished up some tests feature aoTuVb2 -q 4.47 and Megamix -q 4.00. I cut other encoders down to spare time.
Conclusion: I haven't been able to find any regression(i.e. additional hiss) with Megamix at least for these samples at -q4.
I'm impressed with Megamix especially for harpsichord sample(Sarabande, not perfect though).
Anyhow, since I still have trouble with HA's uploader, I uploaded  Ravel_Alborada.flac at my hosting space as well. This is a kind of "sharp attack" sample.
pre-echo_q4_results.zip
Reply #80
I've compiled a linux static megamix binary if anybody wants to try this on linux:
http://www.caddr.com/oggenc
Many thanks to all of you for your work on vorbis!
Reply #81
Considering this tests and my personal ones, it appears that the megamix is indeed not a regression comparate to oaTuVb2 :-)
It also seems that oaTuVb2 + QK is better than oaTuVb2 + GT3b2 (and with less bitrate) ... I've donne several tests at -q5 and oaTuVb2 + QK really works great. I can't ear any hiss problem with it :-) So I really would like to test oaTuVb2 + QK tuned for all quality levels...
oaTuVb2 + QK at -q7 may be transparent for everybody and for everything  and with a little bit more tuning on microattacks, ogg/vorbis will be able to replace MPC ;-)
QuantumKnot, what do you think about that ?
Reply #82
Thanx kuniklo! Goo Goo Dolls' Gutterflower sounds great at q7.
Reply #83
Do you think we can get an oggdropXPd build using the megamix code?
Reply #84
Given some time, I can probably tune all the way up to q 10 but my ears aren't that sensitive to pre-echo at these high bitrates.  It happens that q 2, 3, 4, 5 had serious issues with pre-echo, to the point where I was able to discern quite easily.  Any type of tuning I do at q > 6 would be similar to GT3b2, but I'll be aiming for less bits.  We'll see whether I have some spare time.  By the time I do, aoyumi or Monty will probably have a better version out. hehe
As for Vorbis replacing MPC on things like microattacks, I doubt we'll see that in the foreseeable future.
Reply #85
Sure can.  Sorry, I've been a bit distracted of late with system rebuild and heavy video encoding.  Give me a few hours and I'll see what I can do.
Reply #86
At Rarewares now in P3 and P4 versions.
Reply #88
Thanks for the build. It works fine.
Reply #89
Reply #90
I want to do the download.
But, the connection is failed at a http://www.rarewares.org/ site.
Reply #91
I am expecting the Oggenc2.3 P4.
Because the oggenc-megamix.exe is too slow on my computer
Reply #92
OK, I hear you!!  I'll do it soon.
Reply #93
Thank you!!!!
Reply #94
Done.  ICL 7.1 compiles now at Rarewares.
Reply #95
I get it.    it works fine.
Thank you!!
Reply #96
The "about" box reports vorbis Post Release 1.0.1 CVS with OggDrop Megamix. Didn't know if that's OK.
flac > schiit modi > schiit magni > hd650
Reply #97
If you ever get bored john33  you can update the quality management mode slider control to go down to -2 since the current batch of encoders recognize this quality level.
Reply #98
Yeah, that's OK. I was in a hurry and forgot to update the box. I assume the vendor string says the right thing?
I'll update the box and reload in the next couple of hours.  Thanks for letting me know.
Reply #99
  Why the song using oggdropXPd is not the same size as the one using Oggenc2.3 P4 or oggenc-megamix.exe.
I see the song's size with Foobar.
