Topic: How do I, .ac3 for DVD projects (Read 5368 times) previous topic - next topic
Hi All,
I know this kinda off topic for this forum, but I'll still take the liberty of posting
my question for the Audio Experts.
I'm about to buy myself some hardware to capture footage for DVD projects.
The final file format for the dvd authoring software is Mpeg2, having mpeg audio,
which is actually converted from .avi file after capture.
What I need to do is, get .ac3 audio to put it into the dvd project, whereas, I get
mpeg audio out of my capture device.
Question, how do I get the .ac3 audio. What hardware or software do I require ?
Any and all the help will be greatly appreciated.
dvdguy_2002
First, capture it with a soundcard capable of performing multichannel recording. (Or any good soundcard able to record at 48kHz, if you intend to use stereo streams)
Then, encode it with SonicFoundry's Softencode, or DigiGram multichannel encoder, or yet Surcode Dolby Digital. All of them use the same AC3 encoding libraries. (6.2.2)
Regards;
Roberto.
Edit: Other idea:
Capture everything to AVI.
In your MPEG2 encoder, set it to encode video only - that should generate a .M2V file.
Then, use avi2wav to separate a .wav stream from the original .avi
Encode the .wav stream with one of the programs mentioned.
And then create a .vob with a DVD authoring program, multiplexing the .m2v with the .ac3 file.
Thaknx for the prompt reply Roberto !
Do the soft encoders mentioned work under Win2k or do they need to be installed
under Win98se ?
What audio capture hardware would you recommend, as I am yet to buy one.
Best Regards.
dvdguy_2002
under Win98se ?
They work in my Win2k.
I'm clueless. I rarely do audio capture, and my SBlive works fine for what I want.
The reason I asked the question about what OS supports the encoders is that
I got myself Sonic Foundry's Soft Encode 1.0 off the net and the Readme.wri file
says, it is for Win95 and NT
Anybody else, please......
dvdguy_2002:rolleyes:
PS :  The date of the file is of 1997 and 1998.
        Does anybody know of any upgrade for Win2k ?
It works perfectly fine on my 2K. Are you experiencing problems to install it?
They only produced version 1.0, and then development was abandoned. You can't find it anymore on SonicFoundry's page. So, no, no updates.
Thank Roberto !!
Yes, what's happening is that the download folder has this instruction :COPY README.WRI TO THE *ROOT* OF THE PARTITION FROM WHICH
    YOU INSTALL
Even if I do or don't copy this file, it tends to fail encoding. I have ripped an Audio CD
and am using .WAV file, into each of the six channels to test it.
Tested on Win98se and Win2k..................
Whatz happening....please lemme know.
Regards.
dvdguy_2002
IMO, the best video related forum is http://forum.doom9.org/ .
There you can find a capture forum, DVD transcoding forum and a audio forum that relates directly to DVD and much more. Many of the Hydrogenaudio members are posting and helping there too.
A note, read the FAQ's, Q&A's and make a forum search before posting as there is a high possibility that every question you have is already answered.
And many of Doom9's members are going on Dimbrom's nerves, here  .
Ookie.
"Stop making me older, start making me new"
I would bet you need a sampling rate of 48kHz. Just a guess.
@Ookami: Stop stealing our users, willya?
Roberto I'll give it a try and get back to you.
Thanks a zillion.
As for you, Ookie. Keep your nose out of my post if you don't plan to help.
Rather call yourself Pokie.
dvdguy_2002
Thanks again for all the help, Roberto, I got the thing to work.
Keeping my fingers crossed. Don't need any mis-sync probs.
Regards.
dvdguy_2002
Heh. No problem.
Good luck. You gonna need it with such an attitude.
Thanks a zillion.
dvdguy_2002
Well, Ookami, I hope you noticed I was just joking. That was the main reason of the ":D" there.
Of course, I can't speak for dvdguy here. But it seems to me he was joking too.
Friends?
