Topic: power supply question (Read 2400 times) previous topic - next topic
Trust the answers on this site more than tech support at Gateway (bleh- never make that mistake again); so I read here about power supplies/heat sinks/fans. Antec was mentioned for power supply, along with Zalman for heat sink/fans. I checked and discovered my system (which I stupidly bought as a package deal) has 200 watt power supply- told 300 watt (seen re: Antec and others) would fry the motherboard. May I assume I have a cheap motherboard/chipset and what they say is true? Would you recommend replacing it- any suggestions. Oh, sorry- told it's Pentium III/1000MHz/Intel Family 6 Model 8 997/ Bios: American Megatrends/ told chipset 82815- not sure if that's correct. Anyway- any help would be most appreciated, as usual- thanks again- cadabra3
p.s. Any rough idea on cost? Thanks.
If you get no computer freeze, blue screen or some damaged components (HDD or CDROM drives suddenly going down), it means that you Power Supply is OK
The problem may occur if you add components such as HDD, CDROM or CDRW drives.
You can also check the power given by your motherboard with software as Motherboard Monitor 5, PC probe, etc. and then check if anything is going wrong.
If you decide to change the PS, just make sure the motherboard is not  proprietary concerning the plugs (I read some problem on DELL computers), and that the size is OK.
cheers,
A 300W PSU won't fry your motherboard! What do they think, that the 300W are forced onto your mobo or something? :drink: It only requests the power that it needs.
Anyways, a PIII 1 GHz is not very pretentious. A 200W PSU should normally do the trick. If your system runs stable with it, there's one thing you should remember: Never change a winning team.
True for computers
Soccer ain't the same thing, we now know that in France
Hi Citay !
