Topic: PPHS resamples failure (Read 3378 times) previous topic - next topic
I have an MP3 file of the cd Tuning Beats 2004 with cue file. When playing this file, I get the following error when the track changes from track 4 to track 5:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 019F1CE0h
Access violation, operation: write, address: 00000000h
Call path:
playback_core_i::g_thread_func=>playback_core_i::thread_func=>dsp::run
Code bytes (019F1CE0h):
019F1CA0h:  18 DD 1B 0F 8C A3 FE FF FF 8B 44 24 1C 33 DB 85
019F1CB0h:  FF 7E 50 8B 4C 24 3C 89 4C 24 20 EB 03 8D 49 00
019F1CC0h:  33 C0 39 44 24 14 7E 25 EB 06 8D 9B 00 00 00 00
019F1CD0h:  8B 56 34 8B 14 9A D9 04 82 8D 14 FD 00 00 00 00
019F1CE0h:  DD 19 83 C0 01 03 CA 3B 44 24 14 7C E3 8B 4C 24
019F1CF0h:  20 83 C3 01 83 C1 08 3B DF 89 4C 24 20 7C C1 8B
019F1D00h:  44 24 1C 3B 44 24 28 0F 8C 03 FD FF FF 5F 5E 32
019F1D10h:  C0 5B 8B E5 5D C2 04 00 CC CC CC CC CC CC CC CC
Stack (06F5FD70h):
06F5FD50h:  00000000 000004FE 0000000E 0000049E
06F5FD60h:  00000000 000004FE 0000000E 0194F7F0
06F5FD70h:  019BF628 018F9CA8 042B13C4 0196027F
06F5FD80h:  0000000B 06F5FDBC 00000002 0000000B
06F5FD90h:  00000000 01967AE8 0000000B 00000002
06F5FDA0h:  00000000 00000000 00000008 00000000
06F5FDB0h:  00437FD7 00000000 019F23D8 019BF628
06F5FDC0h:  0422DC28 00000000 06F5FDE4 0040AC79
06F5FDD0h:  06F5FEFC 018FBB64 00000000 00000000
06F5FDE0h:  0422DC28 06F5FE70 0040AB2F 0000003C
06F5FDF0h:  06F5FEFC 018FBB64 00000000 06F5FE28
06F5FE00h:  00000000 042B13C0 00000000 00000005
06F5FE10h:  00000004 0422DC28 00000050 004448B4
06F5FE20h:  00000000 06F5FE44 00000000 00000000
06F5FE30h:  0109001F 0000AC44 11B13A25 41F6C282
06F5FE40h:  B7CEF0B1 A8EABCEC 00420F57 04295568
06F5FE50h:  0000000B 00000002 0000AC44 06F5FED8
06F5FE60h:  06F5FEFC 00420F22 06F5FED8 00000000
06F5FE70h:  06F5FFA4 0042033D 06F5FEFC 018FBB64
06F5FE80h:  00000000 00000004 042B13C0 042B13C0
Registers:
EAX: 00000000, EBX: 00000000, ECX: 00000000, EDX: 00000010
ESI: 018F9CA8, EDI: 00000002, EBP: 06F5FDB4, ESP: 06F5FD70
Failed to get module/symbol info.
Version info:
foobar2000 v0.8.2
UNICODE
When I use SSRC or no resampler, the problem does not occur -> It must be a problem with PPHS.
my DSP List:
Resampler (PPHS)
Gap Killer
Convolver
Volume Control
Advanced Limiter
do you have PPHS resampler v0.6 (or newer?)? i used to get a crash that looked something like this with v0.5
Thanks, problem solved with PPHS 0.6!
