Topic: Lame 3.96 crashes on --vbr-mtrh (Read 13082 times) previous topic - next topic
I'm using eac + lame 3.96, compile from rarewares.org. Lame.exe crashes when I use this command line:
--preset 112 -b 80 --vbr-mtrh --athaa-sensitivity 1 -q 1 --ignore-tag-errors --tc "v3.96p112b80a-vbrmtrh-s1q1" --tt "%t" --ta "%a" --tl "%g" --tn "%n" --tg "%m" %s %d
Its because of the --vbr-mtrh switch. Same problem with the alias. lame.exe crashes often immediately I've once seen it encoding a part, then crashing.
I'm on w2ksp3.
It works good here.
C:\>lame --preset 112 -b 80 --vbr-mtrh --athaa-sensitivity 1 -q 1 "Foreigner - H
art Turns To Stone.wav"
LAME version 3.96 MMX  (http://www.mp3dev.org/)
CPU features: MMX (ASM used), SSE, SSE2
Using polyphase lowpass filter, transition band: 17960 Hz - 18494 Hz
Encoding Foreigner - Hart Turns To Stone.wav
      to Foreigner - Hart Turns To Stone.wav.mp3
Encoding as 44.1 kHz VBR(q=4) j-stereo MPEG-1 Layer III (ca. 10x) qval=1
    Frame          |  CPU time/estim | REAL time/estim | play/CPU |    ETA
10422/10424 (100%)|    0:21/    0:21|    0:21/    0:21|  12.463x|    0:00
32 [  14] *
80 [    4] %
96 [    6] %
112 [  51] %
128 [  248] %**
160 [ 5642] %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%*************************
192 [ 4226] %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%*************
224 [  208] %%*
256 [  23] %
320 [    3] %
average: 173.3 kbps  LR: 6761 (64.85%)  MS: 3664 (35.15%)
Writing LAME Tag...done
ReplayGain: -3.5dB
C:\>
Did you try Mitiok's compile?
test your memory & cpu/system cooling
On very rare occasions, LAME 3.96 crashes right at the end of a song. It has happened 2 or 3 times out of maybe 50 CD's. But when it happens, it crashes on approx. 8 out of 10 songs. It's when I use "--preset fast standard -Y" (which I almost always use). If I switch back to 3.90.3 it runs just fine. I haven't fiddled around with other command lines.
I have tried different compiles, I have even tried 3.97 alpha 1, but they all behave similarly (except for 3.90.3). I have also ripped with both EAC and CDex. No difference.
I'm running Win XP, SP 1, 2.0 GHz AMD processor.
//From the barren lands of the Northsmen
Same Problem with Mitioks compile. I've tested:
1: Shorter paths, lower drive letter, _ instead of blanks in paths: Same problem,
2: If I replace -preset 112 by "-V 6" lame doesnt crash!
3: If I replace -preset 112 by "-abr 112" it also crashes.
4: If I leave --athaa, -b 80 or -q 1 out, it crashes the same.
--> There must be some problem abr vs. --vbr-new
Command line, reminder:
So with fast standard you are also using the new vbr method!
*Does this happen with all your files or just some specific files?
*Does this happen if you ommit all the tag related parameters?
Maybe you could state where the programs stops (ASM listig).
Is that what you need?
I don't know if this is helping someone, but it's not helping me...
Yes.
Hmmm. Tried another CD: Doesnt happen there!
So first I thought its a problem about file names and paths. But what I did then: I extracted the "bad" file by EAC to wav. Then renamed it to a.wav and tried again: lame crashes. But:
HEY! I was able to split (extract the beginning of the track with a wave editor)  the "bad" wave file to the first 150 kilobytes: Yippie, it causes the same crash, test it and get it from: http://autechre.de/etc/lamecrash.wav
My idea is, its because of the silence in the beginning...
No problem here, tried two different builds.
Indeed, it crashed on my PC, too. Removing the tag related arguments didn't solve the problem. LAME encoded the file correctly only after removing the --vbr-mtrh switch.
By the way, I used the RW build.
lame --preset 112 --vbr-new lamecrash.wav lamecrash.mp3
Win2000SP3: Crash
Win98: Crash. It made the OS unusable.
"Lame --vbr-new" is crashing on this wav when using 3.96 provided by Mitiok
Did you try --preset 112 --vbr-new ???
Do the 97. have the same symptoms.?
Gabriel, it doesn't seem to be a question of the compile. I just compiled a lame.exe with vc++6, same crash.
msvc++ compile of current sf.net cvs: same crash.
(Its "LAME version 3.97 (alpha 1, May 26 2004 11:12:35)")
the link is broken, I can't see any pic
anyway. I'll have a look at this later this evening
Yes, I've deleted it as the embedding here took so much space and because it was worthless to Gabriel. I'm not at home so I cant upload it now... The wave file will be more important though
Yes. Please do not remove the wave file.
No, I only cropped the last part of it, its now just 20 kb and still causing the crash.
would you like to try this one?
lame test compile
link removed
