Topic: Chapter in matroska file (Read 2634 times) previous topic - next topic
I try create my matroska file  two ways:
1. All songs as separate audio track.
2. All songs in single audio track with chapters.
I create mka from mp3  with mkvtoolnix ver 8.9. My OS is Windows XP + SP1.
In ZoomPlayer and Media Player Classic I can select track or chapter. But when I play mka in Foobar it only first track or chapter available.
Where is my error?
Big thanks space.
I found my error - format of my chapter file was xml, when I write it as cue I can get mka chapter in FB2000.
Ummm.... That shouldn't be your error.  The chapters produced by an XML file and a CUE sheet should be identical in a Matroska file.
I create chapter file manually in mkvtoolnix and save it as xml file.  Then add this chapter file in mka - not part in FB.
If I use chapter file as cue created in EAC and import in to mka - I see part in FB.
