Topic: trayicon balloon (Read 2569 times) previous topic - next topic
trayicon balloon
I'd like to read the name of the artist on the tooltip ballon foobar can open on song change, is this possible? Also, how to shorten its delay?
thx
trayicon balloon
Foobar/ preferences / title formatting / system tray
[%artist% - ]$if2(%title%,%_filename_ext%)
Music is my first love.
trayicon balloon
If it is possible at all, you'd probably have to tinker with Windows's theme settings to do that. (In other words, you'd have to use the same method that's used when you change the colours of the default UI.)
trayicon balloon
Just a thought, but have you considered using the "On-Screen Display" plugin (foo_osd) instead?
Get it here: kode54's Foobar2000 plug-ins
I personally have foo_looks visible at all times, and hence I don't need this kind of thing anymore, but I used to use foo_osd and found it great for my needs. Albumart support would make it perfect though
trayicon balloon
ok, thanks for your answers. The solution was not far away
