Topic: TTA (Read 40629 times) previous topic - next topic
TTA
Reply #50
Correct me if I'm wrong, but there are two ways for checking files:
- full decoding.
- CRC or MD5 verification.
CRC verification for TTA does not require full decoding.
I will add the "verify" command into the TTA encoder also.
-- Alexander
TTA
Reply #51
Great format, then
TTA
Reply #52
Also included in my latest special installer.
Hey case,
Any chance you will make an discwriter plugin (like your Monkey's Audio and FLAC) for easy converting to TTA?
Neksus
TTA
Reply #53
Are we all looking at moving away from FLAC or APE to TTA?  TTA definitely looks promising.  It's current lack of hardware support is only a small limitation for me, and I see that is moving in the right direction as well.  Are there many of you thinking of making the switch in the future?
TTA
Reply #54
Use the foo_clienc, Luke.
here's a commandline you can use:
-e -s -o %d %s
A riddle is a short sword attached to the next 2000 years.
TTA
Reply #55
-e -s -o %d %s
Thanks works perfect!!!
Neksus
