Topic: How to get Faac encoder to work with foo (Read 2664 times) previous topic - next topic
You need to change the default CLIEnc settings for FAAC, as the command line syntax has changed.
In Preferences, under Components/Diskwriter choose the output preset FAAC -q100, hit edit and enter "-w -q 100 -c 16000  - -o %d" to the parameters. Do the same with the -q150 preset, substituting  q100 with q150. Follow the same steps for any presets you created.
And you should check the FAAC help (type faac --help in the command line in the folder of faac.exe)
(the output file syntax has changed, AFAIK)
Life is Real...
(But not in audio :) )
