Topic: Speex codec (Read 5187 times) previous topic - next topic
Speex codec
Hello guys,
Has somebody had any experience with Speex codec? I have some questions about that. I would really appreciate your help
Speex codec
Just ask the questions.
Speex codec
And please don't double-post again.
Speex codec
I do
Speex codec
Can we have the latest unstable version (1.1.5) for windows ?? In http://www.rarewares.org , only the 1.1.4 is available.
Speex codec
I am sorry, I am a newbie on this forum and did not notice a forum dedicated to codecs.
Actually, I would like to show you what I do in my application and would really appreaciate if you point me the spot where I am wrong.
I am sorry for my previous post. I made a mistake assuming that I get mu-law data. No. I get linear PCM, 8 bits per second, signed.  So the sequence of my actions is the following:
void CompressAndDecompress (const char* cData, int iLength = /*160*/)
      vector <short> vecLinearPCMdata
    // Speex needs linear PCM, 16 bit per sample
    // Convert my signed 8 bit to signed 16 bits
    for (i = 0; i < iLength; i++)
        short cTemp =  (short)  (cData >> 8);
        short_buffer.push_back ( cTemp);
  // now we have 160  samples. Encode the frame
    //  array to keep encoded frame
  char cEncodedFrame [38];
    speex_bits_reset(&bits);
      speex_encode(state, &short_buffer [0], &bits);
    int nbBytes = speex_bits_write(&bits, cEncodedFrame, 38);
    /// now decode the frame
        short  cDecodedData [160];
        char  cLinearPCM8Bits [160];
        speex_bits_read_from (&dec_bits, cEncodedFrame, 38);
        speex_decode (speex_dec, &dec_bits, cDecodedData );
          for (int j=0; j < 160; j++)
                // convert each sample back to signed 8 bits PCM
                cLinearPCM8Bits [j] = (char) (cDecodedData [j] >> 8) ;
As a result,  decompressed data does not match original data.  They are totally different and I can't play them.  Where am I wrong?
Speex codec
I have the same problem,
i am trying to add to my application the speex,i get stream of audio of wideband(16khz) and each smaple have 16 bit, as i understood from the manual is that speex get one frame at the time to encode , (one frame for wide band is 320 sample, mean 640 bit), after encode i send it on tcp\ip to the other size and then take the stream i got from the encoder and do decode.
i see that the buf i got after decoder has many zero , and not like the stream before.
i use quality=10 and stiil it sound bad!!!
what do i do wrong?
is it write that the encoder of wideband get frame at size 640 bit , and put them in float array of 320, and in decoder i get array of float of 320 and put them into 640 bit, each 4 bit insert to 2 bit of short?
i would be greatfull if someone who understand the code behind the speex could help me with this.
Thanks,
Ayelet
