Topic: WavPack - Foobar issues (Read 5578 times) previous topic - next topic
Hi!
Is there a history of Foobar 0.81 refusing to play WavPack 3.97 files? I've tried using the lossless compression, I've tried the hybrid compression, and I've tried about every switch available in WavPack, but Foo won't play the file (Error opening file). It plays everything else just fine though...
So, does Foobar support WavPack, or have I downloaded a buggy WavPack encoder? Or is it a problem with the newly released 0.81 version?
Jurg
Just compressed a standard 44/16 wav file with wavpack 3.97 using multi frontend with the -h switch. Plays back flawlessly in fb2k 0.8.1 here (XP sp1). You do have foo_wavpack.dll, don't you?
WavPack support in the core was dropped some time ago, see post above for the solution.
I have the full Foobar version, so that wasn't the problem... Anyway, found the solution in the mean time though... I use EAC to rip, and then call wavpack.exe from within EAC to do the encoding... You just have to tell EAC not to add an ID3 tag to the .wv file. Seems to screw up the file somehow... <g>
Thanks Garf! Thanks TeddyBear!
Jurg
And it's actually just ID3v2 tags that mess up WavPack files. ID3v1 is okay.
So I guess this means that you could actually tag a wavpack file with a combo of ape2 + id3v1(.1) ...?
