Topic: TagScanner 4.9 (Read 115918 times) previous topic - next topic
TagScanner 4.9
Firstly, I want to say how great this tagger is  - it just gets better and better.
One thing I'd like to see though - would it be possible to add an option to write an image to the ID3v2 tag in the 'TAG Processor' - that way all files from an album could be tagged with the same image at the same time. I'd love it if this could be done.
Cheers
TagScanner 4.9
Wonderful program, very useful ... it makes me save a lot of time dealing with tags and file names ....
THANK YOU VERY MUCH!!!!
A little bug ... with build 6 I tried to remove a track number with Tag Editor, but I couldn't .... I tried both save and autosave, but track was still there ...
In "Music renamer" first format is "%7. %1 - %2" instead "%7 - %1 - %2": is it wanted? If so, can you also add "%7 - %1 - %2"?
Can I suggest two little features?
1. could you make List maker pane customizabile so that is possible to choose which columns view in the pane?
For example I'd like to see immediately also birtate of each file ....
2. could add Rescan button to List maker please?
Claudio
TagScanner 4.9
Another little bug of "Dev alpha 6".
In "LIST MAKER" I changed field order to produce an Excel list.
After closing and reopening the program, this setting has been lost.
Claudio
TagScanner 4.9
First: thank ya 4 da best tagger in da world!
Then: i'd like to make my tags using up TWO levels folder name. for example to place the year in tag
  • 1993=???
    • BAND1=%U
      • Album1=%D
      • Album2=%D
  • 1994=???
    • BAND2=%U
      • Album3=%D
thnx
TagScanner 4.9
TagScanner 4.9 Development alpha 7
+ Path field now rereaded only after click Rescan button(or Enter key) (like explorer address bar)
+ Editor: Some correction on folder renaming from menu
+ More accurate APE-tag reading
+ Some corrections in freedb support
http://www.rialnet.ru/~serega/files/tagscan490.zip
Coming soon multilanguage interface.
TagScanner 4.9
I was just wondering, is it possible implement so that you can search on stuff like artist name and album name on freedb to get tags in Tagscanner?
(in other words something like the web-based search at the freedb.org site http://freedb.org/freedb_search.php )
TagScanner 4.9
Maybe
TagScanner 4.9
Reply #32
Ok, thanks for considering
Maybe
TagScanner 4.9
Hi! like everybody here i LOVE this program..really the best one i found!
a little thing that could be really great is a simple option that could put all tags "Every First Up" when I take them from freedb.org or just be able to apply it to all the files in the TagEditor... for now i need to renames files.. and then generate tag from filename to get it...
hope you'll understand my english is not really good
thanks a lot!
niclap
TagScanner 4.9
Reply #34
With "alpha 7" I tried to simply rename files with original file name ("%N") but changing case with "Every First Up".
It didn't change files with no tag!!!
Claudio
TagScanner 4.9
Reply #35
and i forgot...
it's simple but really disturb me... when I click in the path area... could the "text" be all selected... else I need to select it and delete... I would like just to click and paste my directory path in!
am I the only one who don't like that??
Vote TagScanner for 2004!
TagScanner 4.9
Reply #36
Use Generator, click Reset Values, select Case change mode and click Generate...enjoy result
Rightclick autoselect text
TagScanner 4.9
Reply #37
TagScanner 4.9 Development alpha 8
+ Program now is Multilanguage! included Russian and English modules
+ Editor: Operations with tags from context menu (Copy,Cut,Paste)
+ FIX: Freedb: Program don't write Vorbis comments
+ Processor: some changes in interface
Need translators.
TagScanner 4.9
Reply #38
it's what i do for now.. :/
aniway
just a little thing more:
add something like the "replace underscore with spaces" but with " / " to be replace with " - " ... good idea?
If you need french translator I can give a try!
TagScanner 4.9
Reply #39
I planed to include fully functional Word replacer module.
I can include French language in next release
TagScanner 4.9
Reply #40
Ok I'll check if I can have it done for the end of the week
TagScanner 4.9
Reply #41
I have send you an email with the french file...
TagScanner 4.9
Reply #42
I'll be happy to translate it to the infamous language Norwegian. I'll do it when you are sure the file is finished (e.g. there will be no more changes to it until 4.9 is out) so that I don't have to translate it in several turns..
TagScanner 4.9
Reply #43
Just wanted to say thanks and keep up the good work Tarantul
Been using this program since 4.7 (I think) tho I haven't tested the
4.9 alphas yet, I tried a few other programs a while back, but since
I found this one I have been sticking with it.
Gonna be testing 4.9 soon.
TagScanner 4.9
Reply #44
Thanks Tarantul.
I have a little suggestion ... can you add double-byte support to the program?
The tags just show junk characters when browsing UTF or SHIFT-JIS or BIG5, can you add support to this?
Thanks again.
Hong Kong - International Joke Center (after 1997-06-30)
TagScanner 4.9
Reply #46
Thanks Tarantul.
Thanks again.
Supports decoding of ID3v2 UTF16 tags and APE/OGG UTF8 tags.
Program can show tags only in ANSI mode.
TagScanner 4.9
Reply #48
+ Freedb: Search in database
+ Freedb: Manual query for albums
woot woot woot!
I'm experiencing a small visual bug:
See the "X files selected". (WinXP @ 1400x1050)
Anyways, thanks for including this mate! Seems to work like a charm.
TagScanner 4.9
Reply #49
Tarantul: This is looking better and better. Any chance you could add the option to insert an ID3v2 image in the Tag Processor? Please
