Topic: Multiformat @ 128kbps - test discussion (Read 55153 times) previous topic - next topic
How about increasing from 12 samples to 18?
hm would this help the final results? if not i would avoid this, as 10 samples are already enough to listen to imho
Again, people would not be expected to listen to all 18 samples.  This should probably be made very clear in the test instructions, though, so listeners don't kill themselves.
ff123
Headline: "Roberto's Listening Test claim another victim!"
WMA Standard????
Finally!!! Too cool. I'm curious to see how much better my iTunes purchased songs are than the same offering from Napster and hoping I made the right decision in ditching my Creative products (WMA) for Apple's (AAC) line of DAPs.
VQF 128
  Was that a joke??? Does ANYONE use this codec??
ATRAC3
Very interesting 6th choice as sony Connect debuts in weeks.
OK, so I can consider that the vast majority wants Atrac3?
In this case, the codec list will be:
-Musepack
-Apple AAC
-Vorbis
-WMA Std.
-Lame
-Atrac3
I want to make clear I'm not sure yet I will be able to provide Atrac3 encodings. I have SonicStage2 installed, but I didn't tried yet doing encoding -> decoding. Input from people experienced with it will be hugely appreciated.
Regards;
Roberto.
Probably too late now but I just wanted to put my hand up for atrac as well.
One question:  Will MPC, like the other VBR codecs to be tested, be tested at the quality that gives a bitrate closest to 128 kbps as well?  In your very first post, you seem to have just put quality 4 for musepack.
great to see people also want atrac3
rjamorim can you plz add mp3 when you write lame. cause i showed your last multiformat test at 128 to some newbies and they believed mpc was mp3
Reply #34
To decode .omg (encrypted atrac3) files:
- encode the samples
- RENAME or CHANGE LOCATION of the ORIGINAL samples. If you don't do that, Sonic Stage will play the original file, and not the encoded one.
- Play the sample(s) with Sonic Stage and capture the stream with Total Recorder.
I've tried to capture the decoded stream through foobar2000 or Adobe Audition. I don't know why, but there was a slight parasite noise VISIBLE in high frequencies. No problems with Total Recorded. Problem with Windows mixer?
There's a possible problem: the offset. You have to find it for each sample (or to cut exactly the stream). Maybe Java ABC/HR could do this automatically. Otherwise, it will be painful (especially with more than 12 samples).
Reply #35
Or burn *.omg files into AudioCD then rip 'em. It's still hassle in this way though.
Reply #36
ATRAC3 should be "The one".
But what do you think about this sample? I can't be sure tho if it is good "problem" sample.
Reply #37
how about using wma 9 Pro as the 6th competitor? this way we can see what the Pro really makes...I mean it's the newest encoder from MS.
Reply #38
hm rjamorim already said that "The main reason I'm not planning to include WMA Pro is that it has not changed since the 128kbps test."
i think it would make much more sense to test a new codec than testing the same codec again
Reply #39
Additionally to what bond said, wma9 standard is supported by some portable players (and wma9pro is not), so the results can help ppl to choose what player to buy. Or do you suggest to ditch some other codec and include wma9pro additionally? In this case - what encoder would you suggest to be replaces with wma9pro (and why do you think wma9pro is more interesting)?
Reply #40
It makes no sense whatsoever to include WMA Pro. Since MusePack is in both tests and also unchanged since, you can compare the results with the previous test and see how WMA Pro compares.
(And if you wonder, it makes more sense to have MusePack as reference since it won the last test)
Reply #41
I'll save Roberto the trouble of replying:
[span style='font-size:21pt;line-height:100%']Musepack didn't win.[/span]
Just nitpicking, of course. I agree with you that it doesn't make sense to include WMA Pro.
Over thinking, over analyzing separates the body from the mind.
Reply #42
Lol, I remembered the result wrong. OF COURSE AAC was also at the top
Edit: The text says 'big tie for first place', but I assume that was written before the error margins were corrected.
Reply #43
Aree!?! When was this update done? And how could there be such a big change? Were the analysis that messed up before?
Reply #44
There was a bug in the calculation of the error margins, several of the old test results got updated. The relative positions didn't change, but the results are much more significant now.
Reply #45
http://www.hydrogenaudio.org/forums/index....ndpost&p=190675
Edit, more here:
http://www.hydrogenaudio.org/forums/index....ndpost&p=190827
Reply #46
Good point. AFAIK Roberto didn't change the text after the margins were corrected.
From the second link in my previous post:
At the Extension test, it seems Vorbis and WMAPro are no longer tied to AAC and MPC, and now share second place. I'll leave it to others to discuss.
Reply #47
If the new version of LAME is used (3.96) then which setting will be used:
[span style='font-size:12pt;line-height:100%']--preset 128 or -V 5[/span]
3.96b1 -V 5 > 3.90.3 --ap 128 :: Quizas :: tigre :: 0x verified so far
3.96b1 --p 128 < 3.90.3 --ap 128 :: Quizas :: tigre :: 0x verified so far
On this sample -V5 is better, but it hasnt been tested very much.
Reply #48
Changing the text at the 128kbps test is a problem. Even after the error margins were corrected, all the 4 fist places overlap, if even a little. I would eyeball that Musepack is better than Vorbis and WMA Pro.. But Musepack isn't first place alone, as it is obviously tied to iTunes. And, for it's turn, iTunes is tied to Vorbis and WMA Pro. So there you have it...
And, to clarify: I still maintain Musepack didn't win - alone. At least, Musepack and iTunes AAC both won.
Reply #49
I think that we should lower the bitrate of MPC compared to the last test! In the last test MPC got a bitrate of 146.1 and that's a big difference to 128 I think. I think that the average bitrate of all test samples should be between 125 and 130!
Big_Berny
