Topic: Compiling foo_rgscan (Read 3222 times) previous topic - next topic
I've been taking my first steps in using the SDK for the last week or so. My first planned project is merely a small helper components for replaygain which will check for track gain information as each track is played. If it doesn't exist, I stop the playback, do the replaygain and then restart the playback.
I'm having no troubles getting the callback and start/stop working, but when I try to compile the foo_rgscan project (to get myself an import library to use) there's an error stopping the build in the custom build step.
I guessed this was something to do with the NASMW assembler, so I got a copy of that and put in various paths but with no luck.
Anybody got any suggestions on how to build foo_rgscan?
Alternatively, is there a better way to use the replaygain functionality than by linking against the lib file?
[a href="index.php?act=findpost&pid=193634"][{POST_SNAPBACK}][/a]
I'm a brand new fb2k developer and I just ran into this problem trying to build rg_scan. I believe that Visual Studio ignores the system enviornment path and uses its own. I fixed this problem by modifying the custom build step to run
<my_path_to_nasmw>\nasmw.exe
Hope this helps someone else...
Dave
As an alternative, you can include the directory where nasmw resides in you executable search path in Visual Studio. Add it under Extras/Options/Directories/Executable files (or similar).
