Topic: Request for a quick listening test (Read 14276 times) previous topic - next topic
We are testing couple of coding modes for 32, 40, 48 and 64 kb/s bit-rates and similar VBR presets, and I would like to get community feedback on couple of possible modes:
Test archive contains 10 samples, encoded with various encoding modes at
24, 32, 40, 48 and 64 kb/s  - LC AAC @64 is used as "anchor"
Test archive is 27 MB:
http://www.audiocoding.com/bigtest.rar
Codec list (encrypted - password will be provided in 15 days):
http://www.audiocoding.com/codecs.rar
Just download the bigtest.rar, unpack it to a directory - and click on 'decode.bat'
Please use Java ABC/HR with the config files as described:
http://www.hydrogenaudio.org/forums/index....ndpost&p=192426
Send the results to this address:  idimkovic (AT) nero DOT com
Thanks in advance!
First of all, thanks to Ivan for giving us the opportunity to have a glance at the latest development in AAC.
For convenience, I've made some config files, which you can use with ff123's ABC/HR app or with ABC/HR for Java. Just unzip them in the same folder as the decode.bat. These config files contain offset and gain correction, which is quite significant with some samples (offsets are corrected by up to 35ms, gain up to 2dB).
Schnofler,
Thanks a lot for your work!
Please note that the native windows abc/hr cannot correct for gain, only for offsets.
ff123
Edit:  I wonder why there would be such a big difference in gain?
Yes, I was surprised, too. I checked the values with Replaygain, and it produced pretty similar results. On some samples this is very noticeable (compare the reference with codec C on sample 7, for example; the reference is clearly louder, replaygaining yields track gains of -2.5dB vs. +0.8dB).
Schnofler,
No problem, ABC/HR-Java does this almost automatically.
I will explain at the end of the test
Schnofler,
If there are tracks which are clearly louder, it is probably best to stick with abchr-java.  Typically louder sounds better, all else being equal.
ff123
True - please use Java version for the test, as some new algos do have these issues >at the moment<
Argh.. Looks like I messed up again. ABC/HR-Java doesn't read the gain values correctly from config txt-files (xml and encrypted configs work fine).
There are two ways to correct this: use the xml configs from the zip at the end of this post, or get a new ABC/HR-Java version here. This is a development version, and I didn't have time to test it properly, so there might be some bugs. For those who encountered program freezes in Roberto's AAC test, this version might help (reports are welcome, although I will open a thread about this when I release a new proper version).
This is not related directly to the request.  It's about the included aacdec.exe app.
channel configuration -- all the monos get made into stereo
when going from adif to adts using
  aacdec -a sample1_A_aacdec.aac  sample1_codecA.aac
\tmp\aac_tmp>comp s1_cA_faad.aac    sample1_A_aacdec.aac
        Comparing s1_cA_faad.aac and sample1_A_aacdec.aac...
Compare error at OFFSET 3
file1 = 40
file2 = 80
Compare error at OFFSET 21
file1 = 40
file2 = 80
Compare error at OFFSET 39
file1 = 40
file2 = 80
Compare error at OFFSET 1C8
file1 = 40
file2 = 80
Compare error at OFFSET 278
file1 = 40
file2 = 80
Compare error at OFFSET 32F
file1 = 40
file2 = 80
Compare error at OFFSET 3CE
file1 = 40
file2 = 80
Compare error at OFFSET 489
file1 = 40
file2 = 80
Compare error at OFFSET 533
file1 = 40
file2 = 80
Compare error at OFFSET 5DD
file1 = 40
file2 = 80
10 mismatches - ending compare
faad used:
*********** Ahead Software MPEG-4 AAC Decoder V2.0 RC3
Build: Feb  5 2004
aacdec used (included in that package):
*********** Ahead Software MPEG-4 AAC Decoder V2.1 beta
Build: Mar  1 2004
Yup... good observation
Hmm, the -a switch might be broken on these files. I'll have to check.
Menno
Thanks for the config files, schnofler. They're very helpful.
<bugreport>
The program crashes on me from time to time, though, so I have to save my sessions midway, because I can rarely complete a session without a crash (or two). This is ABC/HR v0.4b3 SE, 16 Jan. I'll play a sample, and the sample will cut out. At this point, I can save my session, close the window, open ABC/HR again, and load the session, and continue playing all the samples. If I press play a second time, though, the window stops responding, and I have to kill it with Task Manager. This is on a dual-CPU machine running Windows XP Pro, SP1, running Sun's VM version 1.4.2_03-b02. Soundcard is TBSC with 4193 drivers. What else can I tell you? It doesn't happen immediately, only after playing a few dozen times. It happened on almost every clip, regardless of the time slider position. It never happened when I played the reference, but then again, 90% of my play time was with the compressed versions.
EDIT: problem resolved with ABC/HR v0.4b4.
</bugreport>
I have a question about my sample rating procedure:
On one sample, a certain artifact (such as stereo collapse) makes a big difference in the overall impression of the sample, and on another, the artifact doesn't hurt the sample's overall feel much. Although the artifact is clearly audible in both cases, I mark the affected test clip way down on the first sample and only a little on the second. Is this the proper way to rate samples, by how pleasant they are to listen to (in comparison to the reference), or should I be going strictly by the audibility of artifacts? Basically, I'm weighting the importance of each artifact differently for each sample.
PS?
PS?
Definitely
Erm... PS = Parametric Stereo. The new low bitrate enhancement tool being standardized into MPEG4 AAC.
...and beeing incorporated into FAAD2
Already done  Check the CVS.
Menno
Results sent!
Wanted to make sure:
this means FAAD2 derived filters will definitely play back HE-AAC+PS,
as in CoreAAC will handle it with the benefits
I can't wait! (well i can a little)
I think so - after all the grading scale is how annoying it sounds, not how many artifacts you can identify.
Okay, thanks for the feedback, Garf. I wasn't sure whether to grade purely on the sample's closeness to the original ("this sample sounds closest to the original, except the hi-hat artifact is so annoying!"), or to allow the "enjoyment factor" to affect my grading as well ("it sounds a bit lo-fi, but I'd prefer that my encodings resemble this sample more than the other samples").
woohoo! i'm digging 2, if not 3 of the samples...  have these *always* been the samples? (or at least as of late? ..late being the last 2-3 tests)
edit: all done. that was a really fun test
Some of them were in the other tests, most of these seem new ones from Ivan.
this should be interesting. i like doing 1CD rips, but for longer movies, i have to use AAC-HE, which unfortunately destroys a lot of the surround type info, IIRC (from my personal experiences). i could hear in some of these tests with just a 2 speaker (headphone) setup how some preserved the sound field. i guess that's why it's called Parametric Stereo
